microsd encryption
Webjom
microsd encryption
Post by Webjom »
it is possible to encrypt sdcard and protect it from cloning? I want the system flash to be protected from cloning so it can't be copied.
Re: microsd encryption
No. If someone has physical access to SD, it can be copied.
Webjom
Post by Webjom »
Security issue resolved? After upgrading to 5.8.87 microSD is not recognizable in the win system. It is OK. Excellent work. Is microSD recognizable in linux? If I needed to return flash to flood.
Webjom wrote: Tue Nov 12, 2019 1:21 pm Security issue resolved? After upgrading to 5.8.87 microSD is not recognizable in the win system. It is OK.
It is damaged microSD, or microSD reader, or win system. Raspberry boot SD is unencrypted FAT32. Raspberry hardware can not boot from encrypted media.
