Second Monitor does not sleep
bnicholas
Post by bnicholas »
I am trying to get the monitors connected to my raspberry pi4 to both sleep. I have the line "sleep=15,standby" in my configuration file. The first monitor goes to sleep correctly, however, the second monitor stays on. The monitors connected with micro-hdmi to dvi cables.
Re: Second Monitor does not sleep
bnicholas
Post by bnicholas »
Logs were emailed last week, have you had a chance to look at this issue?
Thanks!
Please, resend your e-mail to support@wtware.com
bnicholas
Post by bnicholas »
Email was sent again yesterday.
bnicholas
Post by bnicholas »
This build does not boot at all. Using the same config it does not even get to the initial boot where I can hit "delete" to get into the initial set-up. If I switch back to the previous version with the same config it boots correctly.
Please try this: http://wtware.com/testing/201910132136.zip
If it does not get to "Press Del to enter Setup", possibly something is wrong with SD card. Reformat it with SD formatter https://www.sdcard.org/downloads/formatter/ and reinstall wtware. Config file is read later than it writes "press del".
bnicholas
Post by bnicholas »
That version worked. Thanks!
