Toggling between audio outputs?
jazzldazzl
Post by jazzldazzl »
Dear All,
Is it possible to configure wtware to toggle onthefly between audio devices - HDMI, 3,5" jack, bluetooth and USB audio?
Re: Toggling between audio outputs?
No.
jazzldazzl
aka wrote: Sat Sep 21, 2019 9:43 amNo.
Thanks, so multiple audio outputs to choose from in device manager is not possible? Example: I use a headset connected on the 3,5" jack, and then decide the rest of the house should know what I´m listening to, and choose the output to be bluetooth streaming to the amplifier instead.
WTware is for boring office work. There are many media player distributions for Raspberry. I use OpenELEC on Raspberry in my car.
jazzldazzl
+1 for Openelec, although I´m more into Libreelec. Anyway, is it possible to send this command to wtware while it´s running:
amixer cset numid=3 1
and then
amixer cset numid=3 2
Then it should be doable. right? If in Raspbian, this can be done on the fly. Just dunno how to send commands to wtware when it´s running, only how to modify the config files.
