OpenVPN Linux ip link set failed: could not execute external program
jeremy
Post by jeremy »
Everything seems to setup fine with OpenVPN on a Pi 4 until this line and then it exits with a fatal error.
21-13-11-991| [SYSLOG] <29>Aug 16 01:13:12 openvpn[886]: TUN/TAP device tun0 opened
21-13-11-992| [SYSLOG] <29>Aug 16 01:13:12 openvpn[886]: /sbin/ip link set dev tun0 up mtu 1500
21-13-11-996| [SYSLOG] <27>Aug 16 01:13:12 openvpn[886]: Linux ip link set failed: could not execute external program
21-13-11-997| [SYSLOG] <29>Aug 16 01:13:12 openvpn[886]: Exiting due to fatal error
mattphillips27
Re: OpenVPN Linux ip link set failed: could not execute external program
Post by mattphillips27 »
I have the same error, did you work out a fix for it?
Show me full log.
mattphillips27
aka wrote: Fri Aug 23, 2019 5:17 pmShow me full log.
Can I email it to you directly? I emailed on Friday the logs to the support email but not heard anything yet.
Did you try your OpenVPN config on linux? Show me your openvpn config and openvpn output on linux.
