Multiple Shell
ppaetschke
Multiple Shell
Post by ppaetschke »
Hi Forum,
i am currently evaluating the WTWare solution on RaspberryPI for our production environment.
So far everything is straight formward and working as expected.
I now have th request to run two Apps which are pusblished via RemoteDesktop (Firefox and another java application).
I there a way to start multiple remote apps using the shell command?
Should it work if i use the following config:
server=rdp:192.168.11.31
shell=||FireFox
shell=||otherapp
Thanks,
Patrick
Re: Multiple Shell
shell=||FireFox
next screen
shell=||otherapp
Switch between them with Win-arrows, Win-1 and Win-2 or from popup menu in right corner.
