OpenVPN Auto Login?
Bootalito
OpenVPN Auto Login?
Post by Bootalito »
Is there a way to configure OpenVPN with the credentials for automatic login so the user does not have to enter them? Such as use the configuration file?
Re: OpenVPN Auto Login?
http://wtware.com/docs5/openvpn.html
"Rename tested configuration file to openvpn.cfg and place it to configs directory on boot disk..."
Bootalito
Post by Bootalito »
I think I figured it out but something is still wrong. In the OpenVPN.cfg file I added the following line:
auth-user-pass pass.txt
auth-user-pass was already there, I just added " pass.txt". I added a file called pass.txt with the username and password on two different lines, but I'm getting a WTWare error:
ERROR: INTERNAL ERROR
WTWare 5.8.50/RPi
File: initrdConfig.cpp
Line 439
initrdConfig.cpp Line 439 is "openvpn did not understand your config and did not start".
More details in log: https://wtware.com/logs.html
Also try this line:
auth-user-pass /bootmedia/configs/pass.txt
Bootalito
Post by Bootalito »
It's been a while, but I just wanted to respond to help other people out in the future that aka's solution was the final solution
with pass.txt being a two line text file with the OpenVPN auth user name on the first line and the password on the second line.
i.e.
OpenVPNUserName
SomeComplexPassword
I can confirm that WTWare 5.8.50/Rpi is working very well providing remote access for our office manager connecting to a pfsense router (v2.4.4-RELEASE-p3) via OpenVPN configured in the most secure way humanly possible (4096bit DH paramter, AES-256-GCM, only available in the most recent version of OpenVPN, using mode: "SSL/TLS + User Auth" with TLS key mode "TLS Encryption and Authentication". The raspberry pi is mounted to the back of a monitor via a VESA mount.
If the devs would like, I could provide a full write up with screen shots and pictures that they could use to update the documentation (especially the OpenVPN documentation page, which is really lacking) on how to provide a fully secure remote access station for an employee. Please let me know if this is something WTWare would find useful and I'll make some time to provide
Bootalito wrote:
Fri Jan 17, 2020 2:31 am
It would be very great, we'll appreciate such work. Thank you.
Bootalito
Post by Bootalito »
I created a tutorial on how to create a remote access station for a small business. I targeted the language for other small dental offices such as ours, so it may need some heavy tweaking if you decide to integrate the content into your online documentation. But I give you full permission to use the content.
OpenDocument Text file (sorry I use Libreoffice...it should only be a little mangled if opened in Word):
https://drive.google.com/open?id=1SFuLO ... ggXR-w5hfP
pdf format
https://drive.google.com/open?id=15ETUS ... 6sq0HZiwAq
Bootalito wrote:
Thu Feb 13, 2020 6:39 am
pdf format
Unable to download it. Something wrong with sharing permission.
Bootalito
Post by Bootalito »
I think its fixed now.
