SSL_ERROR_SYSCALL on Fresh Installation
i7one9
Post by i7one9 »
I am testing out WTware on Raspberry Pi 3B+'s in a call center environment. I have a fresh install of Windows Server 2016 (Desktop Experience) and am able to RDP from the Pi's to the server. However, the Pi's are continuously losing connection to the server. Pasted below is a section from a WTware terminal log file:
[ pfac] [ 1752.002220] Ok, PID 901.
[ rdpclient 901] [ 1752.009639] RDP Terminal Client, WTware 5.8.50/RPi, pipe 23, pid 901.
[ rdpclient 901] [ 1752.010331] Use /lib/ui32.so.
[ rdpclient 901] [ 1752.011637] Set connect_timeout = 60.
[ rdpclient 901] [ 1752.011889] Redirect sound.
[ rdpclient 901] [ 1752.012214] Make RDP session with 172.16.1.180, port 3389.
[ rdpclient 901] [ 1752.012288] No username.
[ rdpclient 901] [ 1752.012349] No password.
[ rdpclient 901] [ 1752.012413] No PIN.
[ rdpclient 901] [ 1752.012476] No domain.
[ rdpclient 901] [ 1752.012538] No shell.
[ rdpclient 901] [ 1752.012599] No directory.
[ rdpclient 901] [ 1752.012664] Window: 1376x900@24.
[ rdpclient 901] [ 1752.012729] PFlags 0x0000002F.
[ rdpclient 901] [ 1752.012791] Keyboard 00000409:00000000.
[ rdpclient 901] [ 1752.012852] My hostname "wtwB827EBCC2C0F".
[ rdpclient 901] [ 1752.012918] TCP: connecting to 172.16.1.180:3389.
[ rdpclient 901] [ 1752.014477] TCP: connection with 172.16.1.180:3389 established.
[ rdpclient 901] [ 1752.014723] Turn keepalive on.
[ rdpclient 901] [ 1752.015683] Free ram after buffers allocation: 923852 KB.
[ rdpclient 901] [ 1752.023449] Reconnect with TLS/SSL enabled.
[ rdpclient 901] [ 1752.023571] TCP: reconnecting to 172.16.1.180:3389.
[ rdpclient 901] [ 1752.024403] TCP: connection with 172.16.1.180:3389 established.
[ rdpclient 901] [ 1752.024467] Turn keepalive on.
[ rdpclient 901] [ 1752.031263] Server supports GFX Pipeline.
[ rdpclient 901] [ 1752.031336] TLS.
[ rdpclient 901] [ 1752.031396] SSL/TLS.
[ rdpclient 901] [ 1752.069363] Enable font smoothing and Desktop Composition.
[ rdpclient 901] [ 1752.072460] RDP5 encryption (X.509).
[ rdpclient 901] [ 1752.293965] GFX codec.
[ rdpclient 901] [ 1752.526869] SessionId 0x00000002: LUCER\INT100.
[ rdpclient 901] [ 1752.617330] Run 4 tile threads.
[ rdpclient 901] [ 1832.630271] SSL_ERROR_SYSCALL
[ gm] [ 1832.630422] TSClient (sessionId 23, pid 901) gracefully end.
[ rdpclient 901] [ 1832.630479] TCP/IP connection lost. Reconnect to 172.16.1.180.
[ rdpsnd] [ 1832.638963] Link lost.
[ pfac] [ 1832.639752] Process pid 901 terminated, status 00000009.
[ gm] [ 1832.641337] Free ram before fork terminal client /sbin/rdpclient (session 24): 924456 Kb.
Any help is greatly appreciated.
Re: SSL_ERROR_SYSCALL on Fresh Installation
Server broke connection without any comments to client. Some information may be in server events. If no, something should be fixed somewhere. From ethernet switch power source to servicepacks on server. Server doesn't tell us what is wrong so I can not specify more precisely.
