WTWARE don't boot
bcarme95
WTWARE don't boot
Post by bcarme95 »
I followed this procedure to prepare my SD card :
https://linuxhint.com/raspberry_pi_thin_client/
but nothing happens to the connection of the raspberry, no boot
I used the SD card or I had raspbian installed that worked well so it does not come from the SD card.
Thanks for your help
Re: WTWARE don't boot
Did you use Raspberry 2/3/3b+? WTware will not run on older Pi.
bcarme95
Post by bcarme95 »
I had formatted the SD card with version 5.0 of SDformater, with version 4 everything works
Thank you
