Windows login reconnect every 20 seconds.
Kaoth
Post by Kaoth »
I am new and have a question. Everything works as it should for me. But is it correct that after starting, when the login screen from the terminal server is displayed and not immediately logs one that the connection separates approximately every 20 seconds and reconnects? This is quite stupid, because the screen hangs in the meeting room. If you then logged in, then everything runs.
I'm grateful for every tip.
I have two versions in use and both are the same. Once version 5.4.32 and once 5.6.24.
Re: Windows login reconnect every 20 seconds.
