Youtube
ahonma
Youtube
Post by ahonma »
I got 4x RPI3+ running WinTerminals.
The only issue so far that is people on my neck complaining about using YOUTUBE.
What options do I have to deal with this problem?
- any server setting to optimize performance?
- running locally?
- using a different browser/player?
Thank you,
Aleks
Re: Youtube
ahonma wrote:
Wed Mar 06, 2019 12:37 am
If YOUTUBE quality is important, the only solution is local playback on x86 with Windows.
2012R2 or newer Windows Servers out of box work the best way. You can broke it, not optimize. Check these lines in WTware log: viewtopic.php?f=2&t=47542 It's the best video codec we have now.
- running locally?
Better than over RDP. But locally on x86 with Windows even better.
No.
ahonma
Re: Youtube
Post by ahonma »
Adding a GPU to the server wouldn't do any difference?
So the issue is the RPi actually processing the incoming frames and not the server generating them?
Is it possible do set something like to press F-xx and open chromium locally?
Re: Youtube
ahonma wrote:
Thu Mar 07, 2019 5:45 pm
Look at server CPU usage when clients run video. If you got 100% server CPU, then GPU may help. If CPU usage is less than 100%, then GPU (and remotefx instead of default codec) can make things worse.
Add to wtware config:
next screen
application chrome
Reboot and press Win-RightArrow. Or Win-2. Or move mouse to right bottom corner to pop up wtware menu.
https://wtware.com/docs5/chrome.html
