Linphone not pulling in custom config
effin_dead_again
Post by effin_dead_again »
All,
I'm trying to get Linphone to pull in a custom config to set some parameters necessary for my SIP server but it doesn't seem to be pulling the file in and setting the settings. The only way I know how to confirm this is to run a command to list a parameter I specifically defined in the linphone config and see that the parameter is undefined according to linphone.
Here's my terminal config line:
SIP=0000:0000@<HOST_REDACTED>, config:linphone.wtc
Here's whats in my linphone.wtc file:
[sip]
media_encryption=srtp
use_ipv6=0
[rtp]
audio_rtp_port=5004
video_rtp_port=0
nortp_timeout=0
audio_jitt_comp=60
video_jitt_comp=60
audio_adaptive_jitt_comp_enabled=1
video_adaptive_jitt_comp_enabled=1
[video]
enabled=0
show_local=0
[audio_codec_0]
mime=opus
rate=8000
channels=1
enabled=1
[audio_codec_1]
mime=speex
rate=8000
channels=1
enabled=1
[audio_codec_2]
mime=PCMU
rate=8000
enabled=1
[audio_codec_5]
mime=1015
rate=8000
enabled=1
[sound]
The file has been placed in C:\Program Data\WTWare\Everyone
I see in the log that the file is being downloaded:
[            gm] [   19.076803] [TFTP] Download config file Everyone/linphone.wtc from <REDACTED>.
/--- FILE "/.linphonerc" -----------------------
| [sip]
| use_ipv6=0
| [rtp]
| audio_rtp_port=5004
| video_rtp_port=0
| nortp_timeout=0
| audio_jitt_comp=60
| video_jitt_comp=60
| [video]
| enabled=0
| show_local=0
| [audio_codec_0]
| mime=opus
| rate=8000
| channels=1
| enabled=1
| [audio_codec_1]
| mime=speex
| rate=8000
| channels=1
| enabled=1
| [audio_codec_2]
| mime=PCMU
| rate=8000
| enabled=1
| [audio_codec_5]
| mime=1015
| rate=8000
| enabled=1
| [sound]
| ringer_dev_id=ALSA: Sennheiser SC60 Control
| playback_dev_id=ALSA: Sennheiser SC60 Control
| capture_dev_id=ALSA: Sennheiser SC60 Control
But when I run the command param sip use_ipv6 I get the output:
current value: (undef)
This means that linphonec never read the value in which means it's not reading the file in. Any ideas?
Re: Linphone not pulling in custom config
There is no ipv6 in wtware at all. Kernel compiled without ipv6.
effin_dead_again
You've completely missed the point. I am trying to convey that linphonec is not pulling in the configuration that I am specifying in the config file. It is getting downloaded from the server but it is not getting applied to linphonec. The command I ran was a test to see if liphonec was pulling in the value I set in the config file that was specified. It is not using the values in the config file despite clearly downloading them from the server.
Here is the manual about logs: https://wtware.com/logs.html
No words "remove everything interesting and leave only few lines".
effin_dead_again
Attached.
Just an FYI, you are about half of a centimeter away from me buying another solution if you can't get that gnarly attitude under control. Perhaps you should change your auto-response to be something like: "The logs you have provided do not have enough information for us to research your issue. Please review the manual about logs here: https://wtware.com/logs.html and provide the full log output for our review."
It appears to me that linphonec isn't looking for the .linphonerc file in the location you are placing it but I am not familiar enough with the internals of WTWare to know any better. I will await your response.
wtware-log.txt
(115.07 KiB) Downloaded 1054 times
We'll use your text as auto-response. Thank you.
There are no .linphonerc files other than the one that printed in log. Lot of errors in lines with [ SIP] mark comes from your (what is not gnarly form of the word "incorrect"?) config.
effin_dead_again
I figured out the issue, but it was not because of an error in my config, but rather the lack of one option in the SIP section: ipv6_migration_done=1
Here is the config file that ultimately worked for me:
[audio_codec_0]
mime=opus
rate=48000
channels=1
enabled=1
[audio_codec_1]
mime=speex
rate=8000
channels=1
enabled=1
[audio_codec_2]
mime=SILK
rate=16000
channels=1
enabled=1
[audio_codec_3]
mime=BV16
rate=8000
channels=1
enabled=1
[audio_codec_4]
mime=GSM
rate=8000
channels=1
enabled=1
[audio_codec_5]
mime=G722
rate=8000
channels=1
enabled=1
[audio_codec_6]
mime=PCMU
rate=8000
channels=1
enabled=1
[audio_codec_7]
mime=PCMA
rate=8000
channels=1
enabled=1
[net]
adaptive_rate_control=1
mtu=0
[sip]
use_ipv6=0
[rtp]
nortp_timeout=0
[sound]
echocancellation=1
remote_ring=/usr/local/share/sounds/linphone/rings/ringback.wav
local_ring=/usr/local/share/sounds/linphone/rings/oldphone.wav
You can consider this issue resolved.
