Unable to upgrade from 5.8.22 to 5.8.26
SimonJ
Post by SimonJ » Thu Sep 13, 2018 4:37 am
I am unable to upgrade to the latest version.
I have connected via Web Browser, updated by Bulk, used Terminal boots by network, non-WTware DHCP, used Curl.exe and the only way I can is by replacing the USB stick.
I will send a Word attachment of my results to support@wtware.com.
Hope you can help.
Simon J
Re: Unable to upgrade from 5.8.22 to 5.8.26
Post by akatik » Thu Sep 13, 2018 11:52 am
You should use only one way from enlisted, which corresponds to your terminal. If you terminal boot by network with our DHCP, do only the actions described in Terminal boots by network
Please, determine which way you need for your terminal and then send me to support@wtware.com all performed actions from one this way and results.
SimonJ
Post by SimonJ » Tue Sep 18, 2018 6:49 am
We have decided to go with Boot by USB and using static IP addresses. The old HP Thin Clients did not have enough memory to load by Network.
Thank you for your quick reply and support.
Post by akatik » Tue Sep 18, 2018 9:59 am
Network boot requires the same memory as local disk boot.
