Language Spanish in Chrome
jaumeg3
Post by jaumeg3 »
Hello!
We are thinking about buying some licenses to update the previous versions of our thin clients so they can use the google chrome browser. We are testing this solution but we have a problem. Althought I'm putting in the configuration:
keyboard = es
language = es
when i try to write "@", i can't write it with the common combination of keys. I have to put the english keys combination in order to write the symbols.
Please, some help?
Thanks!
Re: Language Spanish in Chrome
Are you talking about local chrome browser running on raspberry or chrome in rdp session running on terminal server and displaying on raspberry?
What is "english key combination"?
jaumeg3
Post by jaumeg3 »
Hi!
I'm talking about local chrome browser running on raspberry. When i want to put the "@",
in the spanish keyboard we use : "AltGr" + 2
but, in order to put the @ when i'm using wtware, i have to put (like in english keyboard): "Shift" + 2.
Thanks!
Try this build:
http://wtware.com/testing/201805050733.zip
In config:
language=es,default
duri3
Post by duri3 »
Hi
I have the same problem with Swiss keyboard (DE-CH). Is it possible to fix that too?
Thanks!
In config:
language=de-ch,default
