TI-GO
Mauro Sollar
TI-GO
Post by Mauro Sollar »
Thin Client: https://www.ti-go.com/
We have a little issue when we try to install WTware using USB procedure.
The system starts well and works well but when we start the install
procedure we got the follow message:
*Hard Disk not found .Disk should be attached to IDE0 as Master. IDE
should be enable in Bios*
My device uses a SSD disk labeled as MCBLK1.
Could you help me to fix this error?
Thanks.
Re: TI-GO
Are you using the latest Wtware version?
Mauro Sollar
Re: TI-GO
No, I tried with version 5.8.8
Re: TI-GO
When you see the error on screen, pres Esc to get command line.
Then take a log (the last case "Directly from terminal, when terminal failed to connect to network"): https://wtware.com/docs5/logs.html
And send it to me.
Mauro Sollar
Re: TI-GO
we took the logs, see below:
WTware 5.8.10/UEFI supervisor.
[ KERNEL] [ 0.000000] Linux version 4.14.30 (aka@c18) (gcc version 7.3.0 (Debian 7.3.0-12)) #6 SMP PREEMPT Fri Mar 30 05:55:24 EDT 2018
[ KERNEL] [ 0.000000] Command line:
[ KERNEL] [ 0.000000] KERNEL supported cpus:
[ KERNEL] [ 0.000000] Intel GenuineIntel
[ KERNEL] [ 0.000000] AMD AuthenticAMD
[ KERNEL] [ 0.000000] x86/fpu: x87 FPU will use FXSAVE
[ KERNEL] [ 0.000000] e820: BIOS-provided physical RAM map:
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008efff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000000008f000-0x000000000008ffff] ACPI NVS
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000090000-0x000000000009dfff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000020200000-0x00000000787e3fff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000787e4000-0x000000007affffff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007b000000-0x000000007b976fff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007b977000-0x000000007bbb1fff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007bbb2000-0x000000007bbb2fff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007bbb3000-0x000000007bbb3fff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007bbb4000-0x000000007bbb6fff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007bbb7000-0x000000007bbb7fff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007bbb8000-0x000000007c7fffff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007cc00000-0x000000007cc49fff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007cc4a000-0x000000007ccb6fff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007ccb7000-0x000000007cdb6fff] ACPI NVS
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007cdb7000-0x000000007cdf6fff] ACPI data
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000007cdf7000-0x000000007cdfffff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000e00f8000-0x00000000e00f8fff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000ffd00000-0x00000000ffffffff] reserved
[ KERNEL] [ 0.000000] NX (Execute Disable) protection: active
[ KERNEL] [ 0.000000] efi: EFI v2.40 by INSYDE Corp.
[ KERNEL] [ 0.000000] efi: ACPI 2.0=0x7cdf6014 ESRT=0x7b9a0718 SMBIOS=0x7bb6a000
[ KERNEL] [ 0.000000] random: fast init done
[ KERNEL] [ 0.000000] SMBIOS 2.7 present.
[ KERNEL] [ 0.000000] DMI: Insyde BayTrail/Type2 - Board Product Name, BIOS BayTrail.5.04.42.0052 10/29/2014
[ KERNEL] [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ KERNEL] [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ KERNEL] [ 0.000000] e820: last_pfn = 0x7ce00 max_arch_pfn = 0x400000000
[ KERNEL] [ 0.000000] MTRR default type: uncachable
[ KERNEL] [ 0.000000] MTRR fixed ranges enabled:
[ KERNEL] [ 0.000000] 00000-9FFFF write-back
[ KERNEL] [ 0.000000] A0000-FFFFF write-protect
[ KERNEL] [ 0.000000] MTRR variable ranges enabled:
[ KERNEL] [ 0.000000] 0 base 0FFD00000 mask FFFC00000 write-protect
[ KERNEL] [ 0.000000] 1 base 000000000 mask F80000000 write-back
[ KERNEL] [ 0.000000] 2 base 07E000000 mask FFE000000 uncachable
[ KERNEL] [ 0.000000] 3 base 07D000000 mask FFF000000 uncachable
[ KERNEL] [ 0.000000] 4 base 07CE00000 mask FFFE00000 uncachable
[ KERNEL] [ 0.000000] 5 base 07C800000 mask FFFC00000 uncachable
[ KERNEL] [ 0.000000] 6 disabled
[ KERNEL] [ 0.000000] 7 disabled
[ KERNEL] [ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ KERNEL] [ 0.000000] esrt: Reserving ESRT space from 0x000000007b9a0718 to 0x000000007b9a0750.
[ KERNEL] [ 0.000000] Base memory trampoline at [ffff880000098000] 98000 size 24576
[ KERNEL] [ 0.000000] BRK [0x0218d000, 0x0218dfff] PGTABLE
[ KERNEL] [ 0.000000] BRK [0x0218e000, 0x0218efff] PGTABLE
[ KERNEL] [ 0.000000] BRK [0x0218f000, 0x0218ffff] PGTABLE
[ KERNEL] [ 0.000000] BRK [0x02190000, 0x02190fff] PGTABLE
[ KERNEL] [ 0.000000] BRK [0x02191000, 0x02191fff] PGTABLE
[ KERNEL] [ 0.000000] BRK [0x02192000, 0x02192fff] PGTABLE
[ KERNEL] [ 0.000000] early_memtest: # of tests: 1
[ KERNEL] [ 0.000000] 0x0000000000010000 - 0x000000000008f000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x0000000000090000 - 0x0000000000098000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x0000000000100000 - 0x0000000001000000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x0000000002193000 - 0x0000000020000000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x0000000020200000 - 0x00000000763ed000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x00000000777e4000 - 0x0000000078508000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x000000007b020000 - 0x000000007b6b0018 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x000000007b6b06d8 - 0x000000007b975000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x000000007cc00000 - 0x000000007cc4a000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x000000007cdf7000 - 0x000000007cdf8000 pattern 0000000000000000
[ KERNEL] [ 0.000000] Secure boot disabled
[ KERNEL] [ 0.000000] ACPI: Early table checksum verification disabled
[ KERNEL] [ 0.000000] ACPI: RSDP 0x000000007CDF6014 000024 (v02 INSYDE)
[ KERNEL] [ 0.000000] ACPI: XSDT 0x000000007CDCD188 0000B4 (v01 INSYDE INSYDE 00000003 01000013)
[ KERNEL] [ 0.000000] ACPI: FACP 0x000000007CDF1000 00010C (v05 INSYDE INSYDE 00000003 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: DSDT 0x000000007CDDC000 00F019 (v02 INSYDE INSYDE 00000003 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: FACS 0x000000007CDB5000 000040
[ KERNEL] [ 0.000000] ACPI: UEFI 0x000000007CDF5000 000236 (v01 INSYDE INSYDE 00000001 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: UEFI 0x000000007CDF3000 000042 (v01 INSYDE INSYDE 00000000 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: DBG2 0x000000007CDF2000 000072 (v00 INSYDE INSYDE 00000003 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: HPET 0x000000007CDF0000 000038 (v01 INSYDE INSYDE 00000003 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: LPIT 0x000000007CDEF000 000104 (v01 INSYDE INSYDE 00000003 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: APIC 0x000000007CDEE000 00006C (v03 INSYDE INSYDE 00000003 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: MCFG 0x000000007CDED000 00003C (v01 INSYDE INSYDE 00000003 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: SLIC 0x000000007CDEC000 000176 (v01 INSYDE INSYDE 00000003 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: SSDT 0x000000007CDDA000 000763 (v01 INSYDE CpuPm 00003000 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: SSDT 0x000000007CDD9000 000290 (v01 INSYDE Cpu0Tst 00003000 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: SSDT 0x000000007CDD8000 00017A (v01 INSYDE ApTst 00003000 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: EM_1 0x000000007CDD7000 000029 (v00 INSYDE INSYDE 00000005 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: OEM1 0x000000007CDD6000 000040 (v01 INSYDE INSYDE 00000005 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: PIDV 0x000000007CDD5000 0000DC (v02 INSYDE INSYDE 00000002 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: RSCI 0x000000007CDD4000 00002C (v00 INSYDE INSYDE 00000000 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: FPDT 0x000000007CDD3000 000044 (v01 INSYDE INSYDE 00000002 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: CSRT 0x000000007CDDB000 00014C (v00 INSYDE INSYDE 00000005 ACPI 00040000)
[ KERNEL] [ 0.000000] ACPI: Local APIC address 0xfee00000
[ KERNEL] [ 0.000000] Zone ranges:
[ KERNEL] [ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ KERNEL] [ 0.000000] DMA32 [mem 0x0000000001000000-0x000000007cdfffff]
[ KERNEL] [ 0.000000] Normal empty
[ KERNEL] [ 0.000000] Movable zone start for each node
[ KERNEL] [ 0.000000] Early memory node ranges
[ KERNEL] [ 0.000000] node 0: [mem 0x0000000000001000-0x000000000008efff]
[ KERNEL] [ 0.000000] node 0: [mem 0x0000000000090000-0x000000000009dfff]
[ KERNEL] [ 0.000000] node 0: [mem 0x0000000000100000-0x000000001fffffff]
[ KERNEL] [ 0.000000] node 0: [mem 0x0000000020200000-0x00000000787e3fff]
[ KERNEL] [ 0.000000] node 0: [mem 0x000000007b000000-0x000000007b976fff]
[ KERNEL] [ 0.000000] node 0: [mem 0x000000007bbb2000-0x000000007bbb2fff]
[ KERNEL] [ 0.000000] node 0: [mem 0x000000007bbb4000-0x000000007bbb6fff]
[ KERNEL] [ 0.000000] node 0: [mem 0x000000007bbb8000-0x000000007c7fffff]
[ KERNEL] [ 0.000000] node 0: [mem 0x000000007cc00000-0x000000007cc49fff]
[ KERNEL] [ 0.000000] node 0: [mem 0x000000007cdf7000-0x000000007cdfffff]
[ KERNEL] [ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000007cdfffff]
[ KERNEL] [ 0.000000] On node 0 totalpages: 498582
[ KERNEL] [ 0.000000] DMA zone: 64 pages used for memmap
[ KERNEL] [ 0.000000] DMA zone: 21 pages reserved
[ KERNEL] [ 0.000000] DMA zone: 3996 pages, LIFO batch:0
[ KERNEL] [ 0.000000] DMA32 zone: 7928 pages used for memmap
[ KERNEL] [ 0.000000] DMA32 zone: 494586 pages, LIFO batch:31
[ KERNEL] [ 0.000000] x86/hpet: Will disable the HPET for this platform because it's not reliable
[ KERNEL] [ 0.000000] Reserving Intel graphics memory at 0x000000007d000000-0x000000007effffff
[ KERNEL] [ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ KERNEL] [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-86
[ KERNEL] [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ KERNEL] [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ KERNEL] [ 0.000000] ACPI: IRQ0 used by override.
[ KERNEL] [ 0.000000] ACPI: IRQ9 used by override.
[ KERNEL] [ 0.000000] Using ACPI (MADT) for SMP configuration information
[ KERNEL] [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ KERNEL] [ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ KERNEL] [ 0.000000] e820: [mem 0x7f000000-0xe00f7fff] available for PCI devices
[ KERNEL] [ 0.000000] Booting paravirtualized kernel on bare hardware
[ KERNEL] [ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ KERNEL] [ 0.000000] setup_percpu: NR_CPUS:4 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[ KERNEL] [ 0.000000] percpu: Embedded 41 pages/cpu @ffff88007b400000 s127960 r8192 d31784 u524288
[ KERNEL] [ 0.000000] pcpu-alloc: s127960 r8192 d31784 u524288 alloc=1*2097152
[ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 490569
[ KERNEL] [ 0.000000] Kernel command line: quiet
[ KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ KERNEL] [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ KERNEL] [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ KERNEL] [ 0.000000] Memory: 1903532K/1994328K available (8200K kernel code, 370K rwdata, 1484K rodata, 2908K init, 340K bss, 90796K reserved, 0K cma-reserved)
[ KERNEL] [ 0.000000] Kernel/User page tables isolation: enabled
[ KERNEL] [ 0.000000] Preemptible hierarchical RCU implementation.
[ KERNEL] [ 0.000000] Tasks RCU enabled.
[ KERNEL] [ 0.000000] NR_IRQS: 4352, nr_irqs: 1024, preallocated irqs: 16
[ KERNEL] [ 0.000000] Console: colour dummy device 80x25
[ KERNEL] [ 0.000000] console [tty0] enabled
[ KERNEL] [ 0.004000] tsc: Detected 1332.800 MHz processor
[ KERNEL] [ 0.004000] Calibrating delay loop (skipped), value calculated using timer frequency.. 2665.60 BogoMIPS (lpj=5331200)
[ KERNEL] [ 0.004000] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.004000] ACPI: Core revision 20170728
[ KERNEL] [ 0.028437] ACPI: 4 ACPI AML tables successfully acquired and loaded
[ KERNEL] [ 0.029463] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ KERNEL] [ 0.029476] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ KERNEL] [ 0.029817] CPU: Physical Processor ID: 0
[ KERNEL] [ 0.029820] CPU: Processor Core ID: 0
[ KERNEL] [ 0.029829] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ KERNEL] [ 0.029832] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ KERNEL] [ 0.029845] mce: CPU supports 6 MCE banks
[ KERNEL] [ 0.029855] CPU0: Thermal monitoring enabled (TM1)
[ KERNEL] [ 0.029861] process: using mwait in idle threads
[ KERNEL] [ 0.029867] Last level iTLB entries: 4KB 48, 2MB 0, 4MB 0
[ KERNEL] [ 0.029870] Last level dTLB entries: 4KB 128, 2MB 16, 4MB 16, 1GB 0
[ KERNEL] [ 0.029873] Spectre V2 : Mitigation: Full generic retpoline
[ KERNEL] [ 0.030106] Freeing SMP alternatives memory: 20K
[ KERNEL] [ 0.034893] smpboot: Max logical packages: 1
[ KERNEL] [ 0.035911] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ KERNEL] [ 0.075622] TSC deadline timer enabled
[ KERNEL] [ 0.075627] smpboot: CPU0: Intel(R) Atom(TM) CPU Z3735F @ 1.33GHz (family: 0x6, model: 0x37, stepping: 0x8)
[ KERNEL] [ 0.088026] Performance Events: PEBS fmt2+, 8-deep LBR, Silvermont events, 8-deep LBR, full-width counters, Intel PMU driver.
[ KERNEL] [ 0.088055] ... version: 3
[ KERNEL] [ 0.088057] ... bit width: 40
[ KERNEL] [ 0.088059] ... generic registers: 2
[ KERNEL] [ 0.088062] ... value mask: 000000ffffffffff
[ KERNEL] [ 0.088064] ... max period: 0000007fffffffff
[ KERNEL] [ 0.088066] ... fixed-purpose events: 3
[ KERNEL] [ 0.088068] ... event mask: 0000000700000003
[ KERNEL] [ 0.096011] Hierarchical SRCU implementation.
[ KERNEL] [ 0.112010] smp: Bringing up secondary CPUs ...
[ KERNEL] [ 0.140026] x86: Booting SMP configuration:
[ KERNEL] [ 0.140029] .... node #0, CPUs: #1 #2 #3
[ KERNEL] [ 0.196162] smp: Brought up 1 node, 4 CPUs
[ KERNEL] [ 0.196162] smpboot: Total of 4 processors activated (10662.40 BogoMIPS)
[ KERNEL] [ 0.196754] devtmpfs: initialized
[ KERNEL] [ 0.196754] PM: Registering ACPI NVS region [mem 0x0008f000-0x0008ffff] (4096 bytes)
[ KERNEL] [ 0.196754] PM: Registering ACPI NVS region [mem 0x7ccb7000-0x7cdb6fff] (1048576 bytes)
[ KERNEL] [ 0.196754] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ KERNEL] [ 0.196754] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 0.196754] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.196754] NET: Registered protocol family 16
[ KERNEL] [ 0.200039] cpuidle: using governor ladder
[ KERNEL] [ 0.200054] cpuidle: using governor menu
[ KERNEL] [ 0.200097] ACPI: bus type PCI registered
[ KERNEL] [ 0.200279] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000)
[ KERNEL] [ 0.200325] PCI: not using MMCONFIG
[ KERNEL] [ 0.200329] PCI: Using configuration type 1 for base access
[ KERNEL] [ 0.206301] ACPI: Added _OSI(Module Device)
[ KERNEL] [ 0.206304] ACPI: Added _OSI(Processor Device)
[ KERNEL] [ 0.206307] ACPI: Added _OSI(3.0 _SCP Extensions)
[ KERNEL] [ 0.206310] ACPI: Added _OSI(Processor Aggregator Device)
[ KERNEL] [ 0.228414] ACPI: Dynamic OEM Table Load:
[ KERNEL] [ 0.228435] ACPI: SSDT 0xFFFF880077128000 000501 (v01 PmRef Cpu0Ist 00003000 INTL 20130117)
[ KERNEL] [ 0.229073] ACPI: Dynamic OEM Table Load:
[ KERNEL] [ 0.229090] ACPI: SSDT 0xFFFF880077128800 000433 (v01 PmRef Cpu0Cst 00003001 INTL 20130117)
[ KERNEL] [ 0.230345] ACPI: Dynamic OEM Table Load:
[ KERNEL] [ 0.230361] ACPI: SSDT 0xFFFF88007704E200 00015F (v01 PmRef ApIst 00003000 INTL 20130117)
[ KERNEL] [ 0.230942] ACPI: Dynamic OEM Table Load:
[ KERNEL] [ 0.230957] ACPI: SSDT 0xFFFF8800783E6A80 00008D (v01 PmRef ApCst 00003000 INTL 20130117)
[ KERNEL] [ 0.234939] ACPI: Interpreter enabled
[ KERNEL] [ 0.234977] ACPI: (supports S0 S5)
[ KERNEL] [ 0.234981] ACPI: Using IOAPIC for interrupt routing
[ KERNEL] [ 0.235073] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000)
[ KERNEL] [ 0.242328] [Firmware Info]: PCI: MMCONFIG at [mem 0xe0000000-0xe3ffffff] not reserved in ACPI motherboard resources
[ KERNEL] [ 0.242333] PCI: not using MMCONFIG
[ KERNEL] [ 0.242341] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ KERNEL] [ 0.247023] ACPI: Power Resource [USBC] (on)
[ KERNEL] [ 0.247882] ACPI: Power Resource [WWPR] (off)
[ KERNEL] [ 0.256268] ACPI: Power Resource [PLPE] (on)
[ KERNEL] [ 0.269729] ACPI: Power Resource [CLK0] (on)
[ KERNEL] [ 0.270616] ACPI: Power Resource [P28X] (off)
[ KERNEL] [ 0.270733] ACPI: Power Resource [P18X] (off)
[ KERNEL] [ 0.279992] ACPI: Power Resource [P28P] (off)
[ KERNEL] [ 0.280123] ACPI: Power Resource [P18P] (off)
[ KERNEL] [ 0.280244] ACPI: Power Resource [P28T] (off)
[ KERNEL] [ 0.280367] ACPI: Power Resource [P18T] (off)
[ KERNEL] [ 0.280486] ACPI: Power Resource [P1XT] (off)
[ KERNEL] [ 0.283429] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ KERNEL] [ 0.283442] acpi PNP0A08:00: _OSC: OS supports [ASPM ClockPM Segments MSI]
[ KERNEL] [ 0.283565] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[ KERNEL] [ 0.283574] acpi PNP0A08:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[ KERNEL] [ 0.283992] PCI host bridge to bus 0000:00
[ KERNEL] [ 0.283999] pci_bus 0000:00: root bus resource [io 0x0070-0x0077]
[ KERNEL] [ 0.284000] pci_bus 0000:00: root bus resource [io 0x0000-0x006f window]
[ KERNEL] [ 0.284015] pci_bus 0000:00: root bus resource [io 0x0078-0x0cf7 window]
[ KERNEL] [ 0.284020] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ KERNEL] [ 0.284024] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ KERNEL] [ 0.284029] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ KERNEL] [ 0.284033] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[ KERNEL] [ 0.284038] pci_bus 0000:00: root bus resource [mem 0x7d000001-0x7f000000 window]
[ KERNEL] [ 0.284042] pci_bus 0000:00: root bus resource [mem 0x80000000-0x90effffe window]
[ KERNEL] [ 0.284046] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed40fff window]
[ KERNEL] [ 0.284051] pci_bus 0000:00: root bus resource [bus 00-ff]
[ KERNEL] [ 0.284068] pci 0000:00:00.0: [8086:0f00] type 00 class 0x060000
[ KERNEL] [ 0.284262] pci 0000:00:02.0: [8086:0f31] type 00 class 0x030000
[ KERNEL] [ 0.284284] pci 0000:00:02.0: reg 0x10: [mem 0x90400000-0x907fffff]
[ KERNEL] [ 0.284299] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff pref]
[ KERNEL] [ 0.284313] pci 0000:00:02.0: reg 0x20: [io 0x1000-0x1007]
[ KERNEL] [ 0.284341] pci 0000:00:02.0: BAR 2: assigned to efifb
[ KERNEL] [ 0.284500] pci 0000:00:03.0: [8086:0f38] type 00 class 0x048000
[ KERNEL] [ 0.284519] pci 0000:00:03.0: reg 0x10: [mem 0x90000000-0x903fffff]
[ KERNEL] [ 0.284715] pci 0000:00:14.0: [8086:0f35] type 00 class 0x0c0330
[ KERNEL] [ 0.284743] pci 0000:00:14.0: reg 0x10: [mem 0x90e00000-0x90e0ffff 64bit]
[ KERNEL] [ 0.284819] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ KERNEL] [ 0.284971] pci 0000:00:16.0: [8086:0f37] type 00 class 0x0c0380
[ KERNEL] [ 0.284994] pci 0000:00:16.0: reg 0x10: [mem 0x90800000-0x909fffff]
[ KERNEL] [ 0.285005] pci 0000:00:16.0: reg 0x14: [mem 0x90e2a000-0x90e2afff]
[ KERNEL] [ 0.285075] pci 0000:00:16.0: PME# supported from D0 D3hot
[ KERNEL] [ 0.285229] pci 0000:00:1a.0: [8086:0f18] type 00 class 0x108000
[ KERNEL] [ 0.285266] pci 0000:00:1a.0: reg 0x10: [mem 0x90d00000-0x90dfffff]
[ KERNEL] [ 0.285283] pci 0000:00:1a.0: reg 0x14: [mem 0x90c00000-0x90cfffff]
[ KERNEL] [ 0.285405] pci 0000:00:1a.0: PME# supported from D0 D3hot
[ KERNEL] [ 0.285561] pci 0000:00:1f.0: [8086:0f1c] type 00 class 0x060100
[ KERNEL] [ 0.285777] pci_bus 0000:00: on NUMA node 0
[ KERNEL] [ 0.286603] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ KERNEL] [ 0.286800] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ KERNEL] [ 0.286996] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ KERNEL] [ 0.287191] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ KERNEL] [ 0.287384] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ KERNEL] [ 0.287578] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ KERNEL] [ 0.287772] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ KERNEL] [ 0.287968] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ KERNEL] [ 0.292202] ACPI: \: failed to evaluate _DSM (0x1001)
[ KERNEL] [ 0.294472] acpi 80860F09:00: Device [PWM1] is in always present list
[ KERNEL] [ 0.303299] ACPI: bus type USB registered
[ KERNEL] [ 0.303356] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.303386] usbcore: registered new interface driver hub
[ KERNEL] [ 0.303437] usbcore: registered new device driver usb
[ KERNEL] [ 0.303500] pps_core: LinuxPPS API ver. 1 registered
[ KERNEL] [ 0.303503] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ KERNEL] [ 0.303516] PTP clock support registered
[ KERNEL] [ 0.303588] Registered efivars operations
[ KERNEL] [ 0.313229] PCI: Using ACPI for IRQ routing
[ KERNEL] [ 0.313235] PCI: pci_cache_line_size set to 64 bytes
[ KERNEL] [ 0.313268] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ KERNEL] [ 0.313275] e820: reserve RAM buffer [mem 0x0008f000-0x0008ffff]
[ KERNEL] [ 0.313279] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ KERNEL] [ 0.313283] e820: reserve RAM buffer [mem 0x787e4000-0x7bffffff]
[ KERNEL] [ 0.313287] e820: reserve RAM buffer [mem 0x7b977000-0x7bffffff]
[ KERNEL] [ 0.313290] e820: reserve RAM buffer [mem 0x7bbb3000-0x7bffffff]
[ KERNEL] [ 0.313293] e820: reserve RAM buffer [mem 0x7bbb7000-0x7bffffff]
[ KERNEL] [ 0.313297] e820: reserve RAM buffer [mem 0x7c800000-0x7fffffff]
[ KERNEL] [ 0.313301] e820: reserve RAM buffer [mem 0x7cc4a000-0x7fffffff]
[ KERNEL] [ 0.313305] e820: reserve RAM buffer [mem 0x7ce00000-0x7fffffff]
[ KERNEL] [ 0.313759] clocksource: Switched to clocksource refined-jiffies
[ KERNEL] [ 0.313759] pnp: PnP ACPI init
[ KERNEL] [ 0.313759] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
[ KERNEL] [ 0.313759] system 00:01: [io 0x0680-0x069f] has been reserved
[ KERNEL] [ 0.313759] system 00:01: [io 0x0400-0x047f] has been reserved
[ KERNEL] [ 0.313759] system 00:01: [io 0x0500-0x05fe] has been reserved
[ KERNEL] [ 0.313759] system 00:01: [io 0x0600-0x061f] has been reserved
[ KERNEL] [ 0.313759] system 00:01: [io 0x164e-0x164f] has been reserved
[ KERNEL] [ 0.313759] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ KERNEL] [ 0.313759] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[ KERNEL] [ 0.318271] pnp: PnP ACPI: found 3 devices
[ KERNEL] [ 0.327570] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ KERNEL] [ 0.327602] clocksource: Switched to clocksource acpi_pm
[ KERNEL] [ 0.327624] pci_bus 0000:00: resource 4 [io 0x0070-0x0077]
[ KERNEL] [ 0.327629] pci_bus 0000:00: resource 5 [io 0x0000-0x006f window]
[ KERNEL] [ 0.327634] pci_bus 0000:00: resource 6 [io 0x0078-0x0cf7 window]
[ KERNEL] [ 0.327638] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ KERNEL] [ 0.327643] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ KERNEL] [ 0.327647] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ KERNEL] [ 0.327652] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000fffff window]
[ KERNEL] [ 0.327657] pci_bus 0000:00: resource 11 [mem 0x7d000001-0x7f000000 window]
[ KERNEL] [ 0.327661] pci_bus 0000:00: resource 12 [mem 0x80000000-0x90effffe window]
[ KERNEL] [ 0.327665] pci_bus 0000:00: resource 13 [mem 0xfed40000-0xfed40fff window]
[ KERNEL] [ 0.327846] NET: Registered protocol family 2
[ KERNEL] [ 0.327846] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ KERNEL] [ 0.327846] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ KERNEL] [ 0.327846] TCP: Hash tables configured (established 16384 bind 16384)
[ KERNEL] [ 0.327846] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ KERNEL] [ 0.327846] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ KERNEL] [ 0.327846] NET: Registered protocol family 1
[ KERNEL] [ 0.327846] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ KERNEL] [ 0.327846] PCI: CLS 64 bytes, default 64
[ KERNEL] [ 0.872635] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x133626f6b26, max_idle_ns: 440795214178 ns
[ KERNEL] [ 0.872692] clocksource: Switched to clocksource tsc
[ KERNEL] [ 0.873944] simple-framebuffer simple-framebuffer.0: framebuffer at 0x80000000, 0x408000 bytes, mapped to 0xffffc90001800000
[ KERNEL] [ 0.873951] simple-framebuffer simple-framebuffer.0: format=a8r8g8b8, mode=1366x768x32, linelength=5504
[ KERNEL] [ 0.883880] Console: switching to colour frame buffer device 170x48
[ KERNEL] [ 0.893476] simple-framebuffer simple-framebuffer.0: fb0: simplefb registered!
[ KERNEL] [ 0.894378] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ KERNEL] [ 0.900242] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ KERNEL] [ 0.900249] io scheduler noop registered
[ KERNEL] [ 0.900252] io scheduler deadline registered (default)
[ KERNEL] [ 0.900548] intel_idle: MWAIT substates: 0x33000020
[ KERNEL] [ 0.900551] intel_idle: v0.4.1 model 0x37
[ KERNEL] [ 0.900950] intel_idle: lapic_timer_reliable_states 0xffffffff
[ KERNEL] [ 0.901131] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ KERNEL] [ 0.901177] ACPI: Power Button [PWRF]
[ KERNEL] [ 0.910357] [Firmware Bug]: No valid trip found
[ KERNEL] [ 0.910876] hpet: number irqs doesn't agree with number of timers
[ KERNEL] [ 0.910951] Linux agpgart interface v0.103
[ KERNEL] [ 0.911813] zram: Added device: zram0
[ KERNEL] [ 0.911825] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ KERNEL] [ 0.911827] ehci-pci: EHCI PCI platform driver
[ KERNEL] [ 0.911869] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ KERNEL] [ 0.911877] ohci-pci: OHCI PCI platform driver
[ KERNEL] [ 0.911907] uhci_hcd: USB Universal Host Controller Interface driver
[ KERNEL] [ 0.912246] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ KERNEL] [ 0.912261] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ KERNEL] [ 0.913369] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00009810
[ KERNEL] [ 0.913378] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ KERNEL] [ 0.913599] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ KERNEL] [ 0.913605] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 0.913609] usb usb1: Product: xHCI Host Controller
[ KERNEL] [ 0.913613] usb usb1: Manufacturer: Linux 4.14.30 xhci-hcd
[ KERNEL] [ 0.913617] usb usb1: SerialNumber: 0000:00:14.0
[ KERNEL] [ 0.913911] hub 1-0:1.0: USB hub found
[ KERNEL] [ 0.913938] hub 1-0:1.0: 6 ports detected
[ KERNEL] [ 1.437141] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ KERNEL] [ 1.437169] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ KERNEL] [ 1.437654] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ KERNEL] [ 1.437659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 1.437663] usb usb2: Product: xHCI Host Controller
[ KERNEL] [ 1.437667] usb usb2: Manufacturer: Linux 4.14.30 xhci-hcd
[ KERNEL] [ 1.437671] usb usb2: SerialNumber: 0000:00:14.0
[ KERNEL] [ 1.437969] hub 2-0:1.0: USB hub found
[ KERNEL] [ 1.437993] hub 2-0:1.0: 1 port detected
[ KERNEL] [ 1.438402] i8042: PNP: No PS/2 controller found.
[ KERNEL] [ 1.438406] hv_vmbus: registering driver hyperv_keyboard
[ KERNEL] [ 1.438499] mousedev: PS/2 mouse device common for all mice
[ KERNEL] [ 1.438664] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 1.438783] input: PC Speaker as /devices/platform/pcspkr/input/input1
[ KERNEL] [ 1.439114] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[ KERNEL] [ 1.439154] rtc_cmos 00:00: alarms up to one month, y3k, 242 bytes nvram
[ KERNEL] [ 1.439194] intel_pstate: Intel P-state driver initializing
[ KERNEL] [ 1.439454] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 1.439595] hv_vmbus: registering driver hid_hyperv
[ KERNEL] [ 1.439806] usbcore: registered new interface driver usbhid
[ KERNEL] [ 1.439808] usbhid: USB HID core driver
[ KERNEL] [ 1.440185] NET: Registered protocol family 17
[ KERNEL] [ 1.440597] sched_clock: Marking stable (1440010085, 0)->(1444143229, -4133144)
[ KERNEL] [ 1.441386] rtc_cmos 00:00: setting system clock to 2018-04-04 09:37:13 UTC (1522834633)
[ KERNEL] [ 1.449195] Freeing unused kernel memory: 2908K
[ KERNEL] [ 1.449200] Write protecting the kernel read-only data: 12288k
[ KERNEL] [ 1.450887] Freeing unused kernel memory: 2028K
[ KERNEL] [ 1.454828] Freeing unused kernel memory: 564K
[ KERNEL] [ 1.772458] usb 1-2: new high-speed USB device number 2 using xhci_hcd
[ pfac] [ 1.795714] Run /sbin/initrd.
[ pfac] [ 1.795787] Ok, PID 765.
[ initrd] [ 1.796893] WTware 5.8.10/UEFI shell.
[ initrd] [ 1.797566] Load font 'ter-c28b.psf', console 97x27.
[ initrd] [ 1.814808] [UEFI] Boot0000.
[ initrd] [ 1.815739] 00000000:0700000001000000520045004600490020005500530042002000440065007600 ........R.E.F.I. .U.S.B. .D.e.v.
[ initrd] [ 1.815798] 00000020:69006300650020002800470065006E006500720069006300200046006C006100 i.c.e. .(.G.e.n.e.r.i.c. .F.l.a.
[ initrd] [ 1.815839] 00000040:7300680020004400690073006B002900000002010C00D041030A000000000101 s.h. .D.i.s.k.)........A........
[ initrd] [ 1.815879] 00000060:0600001403050600010003050600010003050600030004012A00010000000008 .......................*.......
[ initrd] [ 1.815919] 00000080:0000000000000058EA000000000022D7B41F0000000000000000000000000101 .......X......"................
[ initrd] [ 1.815960] 000000a0:7FFF04005243 ...RC
[ initrd] [ 1.815999] [UEFI] EFI USB Device (Generic Flash Disk).
[ initrd] [ 1.816061] [UEFI] Skip type 2, subtype 1, length 12.
[ initrd] [ 1.816101] [UEFI] Skip type 1, subtype 1, length 6.
[ initrd] [ 1.816141] [UEFI] Looks like USB boot.
[ initrd] [ 1.816181] USB boot.
[ KERNEL] [ 1.923983] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610
[ KERNEL] [ 1.924000] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ KERNEL] [ 1.924069] usb 1-2: Product: USB2.0 Hub
[ KERNEL] [ 1.925631] hub 1-2:1.0: USB hub found
[ KERNEL] [ 1.927002] hub 1-2:1.0: 4 ports detected
[ KERNEL] [ 2.224478] usb 1-2.1: new high-speed USB device number 3 using xhci_hcd
[ KERNEL] [ 2.329900] usb 1-2.1: New USB device found, idVendor=05e3, idProduct=0718
[ KERNEL] [ 2.329918] usb 1-2.1: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[ KERNEL] [ 2.329929] usb 1-2.1: Product: USB Storage
[ KERNEL] [ 2.329939] usb 1-2.1: SerialNumber: 000000000033
[ KERNEL] [ 2.412492] usb 1-2.2: new high-speed USB device number 4 using xhci_hcd
[ KERNEL] [ 2.515951] usb 1-2.2: New USB device found, idVendor=05e3, idProduct=0610
[ KERNEL] [ 2.515969] usb 1-2.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ KERNEL] [ 2.515980] usb 1-2.2: Product: USB2.0 Hub
[ KERNEL] [ 2.517934] hub 1-2.2:1.0: USB hub found
[ KERNEL] [ 2.519043] hub 1-2.2:1.0: 4 ports detected
[ KERNEL] [ 2.604412] usb 1-2.4: new high-speed USB device number 5 using xhci_hcd
[ KERNEL] [ 2.720317] usb 1-2.4: New USB device found, idVendor=0b95, idProduct=772b
[ KERNEL] [ 2.720335] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 2.720346] usb 1-2.4: Product: AX88772C
[ KERNEL] [ 2.720357] usb 1-2.4: Manufacturer: ASIX Elec. Corp.
[ KERNEL] [ 2.720367] usb 1-2.4: SerialNumber: 00006A
[ KERNEL] [ 2.820418] usb 1-2.2.2: new low-speed USB device number 6 using xhci_hcd
[ KERNEL] [ 2.928529] usb 1-2.2.2: New USB device found, idVendor=046d, idProduct=c31c
[ KERNEL] [ 2.928547] usb 1-2.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 2.928558] usb 1-2.2.2: Product: USB Keyboard
[ KERNEL] [ 2.928568] usb 1-2.2.2: Manufacturer: Logitech
[ KERNEL] [ 2.939433] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.2/1-2.2.2/1-2.2.2:1.0/0003:046D:C31C.0001/input/input2
[ KERNEL] [ 2.998516] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:14.0-2.2.2/input0
[ KERNEL] [ 3.006360] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.2/1-2.2.2/1-2.2.2:1.1/0003:046D:C31C.0002/input/input3
[ KERNEL] [ 3.065006] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:14.0-2.2.2/input1
[ KERNEL] [ 3.144419] usb 1-2.2.3: new low-speed USB device number 7 using xhci_hcd
[ KERNEL] [ 3.251783] usb 1-2.2.3: New USB device found, idVendor=046d, idProduct=c077
[ KERNEL] [ 3.251801] usb 1-2.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 3.251812] usb 1-2.2.3: Product: USB Optical Mouse
[ KERNEL] [ 3.251822] usb 1-2.2.3: Manufacturer: Logitech
[ KERNEL] [ 3.256568] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.2/1-2.2.3/1-2.2.3:1.0/0003:046D:C077.0003/input/input4
[ KERNEL] [ 3.256828] hid-generic 0003:046D:C077.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:14.0-2.2.3/input0
[ KERNEL] [ 3.336424] usb 1-2.2.4: new high-speed USB device number 8 using xhci_hcd
[ initrd] [ 3.393103] Load ISO 9660 and UDF CDROM filesystem drivers.
[ initrd] [ 3.393182] modprobe udf.
[ initrd] [ 3.400875] modprobe isofs.
[ initrd] [ 3.409625] Load UTF8 charset.
[ initrd] [ 3.409689] modprobe nls_cp437.
[ initrd] [ 3.417819] modprobe nls_utf8.
[ initrd] [ 3.426929] Load VFAT filesystem driver.
[ initrd] [ 3.426994] modprobe fat.
[ initrd] [ 3.431837] modprobe vfat.
[ initrd] [ 3.435905] Load usb storage driver.
[ initrd] [ 3.435972] modprobe scsi_mod.
[ KERNEL] [ 3.443105] SCSI subsystem initialized
[ initrd] [ 3.444333] modprobe usb-storage.
[ initrd] [ 3.450248] modprobe sd_mod.
[ KERNEL] [ 3.449333] usb-storage 1-2.1:1.0: USB Mass Storage device detected
[ KERNEL] [ 3.449588] scsi host0: usb-storage 1-2.1:1.0
[ KERNEL] [ 3.449752] usbcore: registered new interface driver usb-storage
[ KERNEL] [ 3.855353] usb 1-2.2.4: New USB device found, idVendor=058f, idProduct=6387
[ KERNEL] [ 3.855371] usb 1-2.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 3.855382] usb 1-2.2.4: Product: Mass Storage
[ KERNEL] [ 3.855392] usb 1-2.2.4: Manufacturer: Generic
[ KERNEL] [ 3.855402] usb 1-2.2.4: SerialNumber: 12624E2D
[ KERNEL] [ 3.856807] usb-storage 1-2.2.4:1.0: USB Mass Storage device detected
[ KERNEL] [ 3.862080] scsi host1: usb-storage 1-2.2.4:1.0
[ KERNEL] [ 4.478874] scsi 0:0:0:0: Direct-Access USB TO I DE/SATA Device 0016 PQ: 0 ANSI: 4
[ KERNEL] [ 4.481021] sd 0:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B)
[ KERNEL] [ 4.481027] sd 0:0:0:0: [sda] 0-byte physical blocks
[ KERNEL] [ 4.481741] sd 0:0:0:0: [sda] Test WP failed, assume Write Enabled
[ KERNEL] [ 4.482929] sd 0:0:0:0: [sda] Asking for cache data failed
[ KERNEL] [ 4.482934] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ KERNEL] [ 4.486852] sd 0:0:0:0: [sda] Attached SCSI disk
[ KERNEL] [ 4.512565] FAT-fs (sda): unable to read boot sector
[ KERNEL] [ 4.664986] FAT-fs (sda): unable to read boot sector
[ KERNEL] [ 4.816660] FAT-fs (sda): unable to read boot sector
[ KERNEL] [ 4.894963] scsi 1:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4
[ KERNEL] [ 4.897205] sd 1:0:0:0: [sdb] 15360000 512-byte logical blocks: (7.86 GB/7.32 GiB)
[ KERNEL] [ 4.897931] sd 1:0:0:0: [sdb] Write Protect is off
[ KERNEL] [ 4.897936] sd 1:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ KERNEL] [ 4.898991] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ KERNEL] [ 4.903499] sdb: sdb1
[ KERNEL] [ 4.906647] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[ KERNEL] [ 4.969186] FAT-fs (sda): unable to read boot sector
[ KERNEL] [ 4.970972] FAT-fs (sdb): invalid media value (0xb9)
[ KERNEL] [ 4.970976] FAT-fs (sdb): Can't find a valid FAT filesystem
[ initrd] [ 4.975661] Success: first USB disk mounted to /bootmedia.
[ initrd] [ 5.043098] Cache package files: auto.
[ initrd] [ 5.043287] WTpassword present: 3dbf760e11a15f52629a4b249a21adc7.
[ initrd] [ 5.043444] Disable cache package files.
[ initrd] [ 5.043595] Unpack /bootmedia/packages/uefi-lib.
[ initrd] [ 5.762750] /lib/modules/4.14.30/kernel/fs/isofs/isofs.ko already exist. Overwrite.
[ initrd] [ 5.767834] /lib/modules/4.14.30/kernel/fs/udf/udf.ko already exist. Overwrite.
[ KERNEL] [ 5.775146] random: crng init done
[ initrd] [ 6.108926] PCI: C 06 8086:0f00 Bridge Intel Corporation Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register.
[ initrd] [ 6.108991] PCI: C 04:80 8086:0f38 Multimedia controller Multimedia controller Intel Corporation Atom Processor Z36xxx/Z37xxx Series Camera ISP.
[ initrd] [ 6.109034] PCI: C 10:80 8086:0f18 Encryption controller Encryption controller Intel Corporation Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine.
[ initrd] [ 6.109075] PCI: C 03 8086:0f31 Display controller Intel Corporation Atom Processor Z36xxx/Z37xxx Series Graphics & Display.
[ initrd] [ 6.109116] PCI: C 0c:03 8086:0f35 Serial bus controller USB controller Intel Corporation Atom Processor Z36xxx/Z37xxx, Celeron N2000 Series USB xHCI.
[ initrd] [ 6.109156] PCI: C 06:01 8086:0f1c Bridge ISA bridge Intel Corporation Atom Processor Z36xxx/Z37xxx Series Power Control Unit.
[ initrd] [ 6.109197] PCI: C 0c:03 8086:0f37 Serial bus controller USB controller Intel Corporation Atom Processor Z36xxx/Z37xxx Series OTG USB Device.
[ initrd] [ 6.131299] USB: 046d:c31c Logitech, Inc. Keyboard K120.
[ initrd] [ 6.131363] USB: 05e3:0718 Genesys Logic, Inc. IDE/SATA Adapter.
[ initrd] [ 6.131405] USB: 0b95:772b ASIX Electronics Corp. AX88772B.
[ initrd] [ 6.131446] USB: 046d:c077 Logitech, Inc. M105 Optical Mouse.
[ initrd] [ 6.131486] USB: 05e3:0610 Genesys Logic, Inc. 4-port hub.
[ initrd] [ 6.131526] USB: 058f:6387 Alcor Micro Corp. Flash Drive.
[ initrd] [ 21.822119] Start Setup.
[ initrd] [ 25.688100] Unpack /bootmedia/packages/uefi-setup.
[ initrd] [ 25.710961] Load IDE bus driver.
[ initrd] [ 25.711034] modprobe libata.
[ KERNEL] [ 25.720499] libata version 3.00 loaded.
[ initrd] [ 25.724439] modprobe ahci.
[ initrd] [ 25.732190] ATA module ahci.ko loaded.
[ initrd] [ 25.732370] modprobe mmc_block.
[ initrd] [ 25.741322] modprobe sdhci-pci.
[ KERNEL] [ 25.746797] sdhci: Secure Digital Host Controller Interface driver
[ KERNEL] [ 25.746801] sdhci: Copyright(c) Pierre Ossman
[ initrd] [ 25.748266] modprobe sdhci-acpi.
[ KERNEL] [ 25.752121] mmc0: SDHCI controller on ACPI [INT33BB:00] using ADMA
[ KERNEL] [ 25.774578] mmc1: SDHCI controller on ACPI [80860F14:00] using ADMA
[ initrd] [ 25.796055] modprobe sdhci-pltfm.
[ KERNEL] [ 25.793590] byt_gpio INT33FC:00: [Firmware Bug]: pin 38 forcibly re-configured as GPIO
[ KERNEL] [ 25.794704] mmc2: SDHCI controller on ACPI [80860F14:02] using ADMA
[ KERNEL] [ 25.800494] sdhci-pltfm: SDHCI platform and OF driver helper
[ initrd] [ 25.802472] Load HDD drivers.
[ initrd] [ 25.802706] modprobe sd_mod.
[ KERNEL] [ 25.815392] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[ KERNEL] [ 25.817319] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 25.818873] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 25.822958] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[ KERNEL] [ 25.941056] mmc1: new DDR MMC card at address 0001
[ KERNEL] [ 25.942116] mmcblk1: mmc1:0001 BIWIN 29.1 GiB
[ KERNEL] [ 25.942369] mmcblk1boot0: mmc1:0001 BIWIN partition 1 4.00 MiB
[ KERNEL] [ 25.942444] mmcblk1boot1: mmc1:0001 BIWIN partition 2 4.00 MiB
[ KERNEL] [ 25.942589] mmcblk1rpmb: mmc1:0001 BIWIN partition 3 4.00 MiB
[ KERNEL] [ 25.943610] mmcblk1: p1
[ hotplug] [ 25.945223] Block device 179:1. No action.
[ hotplug] [ 25.946453] Block device 179:16. No action.
[ KERNEL] [ 25.946685] mmc0: new high speed SDIO card at address 0001
[ hotplug] [ 25.947452] Block device 179:8. No action.
[ hotplug] [ 25.948862] Block device 179:0. No action.
[ hotplug] [ 25.949262] Block device 179:24. No action.
[ KERNEL] [ 46.515603] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ KERNEL] [ 46.517503] UDF-fs: error (device sda): udf_read_tagged: read failed, block=256, location=256
[ KERNEL] [ 46.517530] UDF-fs: error (device sda): udf_read_tagged: read failed, block=512, location=512
[ KERNEL] [ 46.517599] UDF-fs: error (device sda): udf_read_tagged: read failed, block=256, location=256
[ KERNEL] [ 46.517618] UDF-fs: error (device sda): udf_read_tagged: read failed, block=512, location=512
[ KERNEL] [ 46.517667] UDF-fs: error (device sda): udf_read_tagged: read failed, block=256, location=256
[ KERNEL] [ 46.517685] UDF-fs: error (device sda): udf_read_tagged: read failed, block=512, location=512
[ KERNEL] [ 46.517732] UDF-fs: error (device sda): udf_read_tagged: read failed, block=256, location=256
[ KERNEL] [ 46.517750] UDF-fs: error (device sda): udf_read_tagged: read failed, block=512, location=512
[ KERNEL] [ 46.517753] UDF-fs: warning (device sda): udf_fill_super: No partition found (1)
[ KERNEL] [ 46.519108] isofs_fill_super: bread failed, dev=sda, iso_blknum=16, block=32
[ KERNEL] [ 46.519693] FAT-fs (sda): unable to read boot sector
