Display issue
RayHerring
Display issue
Post by RayHerring »
Having issues with a single display that needs to support multiple screen resolutions to a W2008 terminal server.
If I use my HP ThinClient to remote into this server, everything works perfectly, the screen is at the native 1920x1200 and if I go to 'Remote Desktop Services Manager' and go to 'remote control' a session that has a 1920x1080 screen it works 100%.
However, when I use the RPi3 (running Winterminal 5.6.22, apparently newer versions aren't free anymore?), I log onto the terminal server, right click the desktop and go to 'Screen Resolution' and the only supported resolution is the 1920x1200, when I go to remote control a session that has a 1920x1080 resolution it comes back with an error message of 'Server requires 1920x1080 resolution' (or something like that), I click on 'OK' and it kicks me out of the terminal server and back to the screen where I choose what terminal server I want to connect to.
I have tried the 'display' setting in the WTWare configuration file, have also tried setting multiple hdmi_modes, 1 for the 1920x1200 resolution and another for the 1920x1080 resolution. Neither solution has worked thus far.
Re: Display issue
Send me to support@wtware.com terminal log file: http://wtware.com/logs.html
RayHerring
Re: Display issue
Sorry about the lengthy time between replies.
Will get the info for you tomorrow.
