Are you Planning for RaspberryPi 0 W
ccnet
Post by ccnet »
As RaspberryPi 0 W is a $10 computer , it is more suitable for thin client , are you planning for it ?
Re: Are you Planning for RaspberryPi 0 W
Yes.
ccnet
Post by ccnet »
Dear aka,
Right now we are using 30 Clients (Raspberry Pi 3 Model B using winterminal software) , We have Corei-7 with 16 Gb RAM and 256 Gb SSD as Server running windows 2012 Server but due to high price $35 (Pi) + $20 (for the case and accessories) + TAX it calculates to approx $70 for each client, to reduce the budget we tried OrangePi ( from China @ $15) its CPU got overheated and in country like India weather conditions are not suitable for overheated components. Also as we are running non profit organization for children, we don't have Air Conditioners installed in our Labs, So we are searching for a cheap and good solution and then I found RaspberryPi 0 W with the same radio chip for Wifi and Bluetooth as of Pi 3 Model B , so I asked you, feeling nice to hear "Yes" from you.
Again many thanks for this project, it is really a game changer for the education of third world country's and there Students .
Waiting for the solution for Pi 0 W.
