Display TFT 3.5"
marcostelecom
Display TFT 3.5"
Post by marcostelecom »
I need to use an 3.5 Inch RPi Display Touch - XPT2046 (480x320).
Success in raspbian strech 2017/09. I do
apt-get install fbi
Edit /usr/share/X11/xorg.conf.d/99-fbturbo.conf
change the line in the file:
Option "fbdev" "/dev/fb0"
to
Option "fbdev" "/dev/fb1"
And add the line to config.txt
dtoverlay=piscreen,speed=16000000,rotate=90
Then, the linux text console still in HDMI, but X use the TFT display.
The question: how can I do the same in the watware for RPI ?
Log in wtware in RPI with display connected:
WTware 5.6.22/RPi supervisor.
[        KERNEL] [    0.000221] console [tty0] enabled
[        KERNEL] [    0.000251] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000383] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000391] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001288] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001623] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001631] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001655] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003168] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003175] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003725] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003731] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004276] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.004282] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004359] Brought up 4 CPUs
[        KERNEL] [    0.004369] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004373] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004376] CPU: Virtualization extensions available.
[        KERNEL] [    0.004913] devtmpfs: initialized
[        KERNEL] [    0.014597] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[        KERNEL] [    0.014978] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.014993] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.015478] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.016010] NET: Registered protocol family 16
[        KERNEL] [    0.017852] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.028009] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.111166] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.113500] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.113622] usbcore: registered new interface driver hub
[        KERNEL] [    0.113709] usbcore: registered new device driver usb
[        KERNEL] [    0.120144] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-17 15:19
[        KERNEL] [    0.122430] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.137346] NET: Registered protocol family 2
[        KERNEL] [    0.137917] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.138026] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.138210] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.138296] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138337] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138512] NET: Registered protocol family 1
[        KERNEL] [    2.243363] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.277660] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.277673] io scheduler noop registered
[        KERNEL] [    2.277679] io scheduler deadline registered (default)
[        KERNEL] [    2.287068] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.287107] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.318070] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.338488] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.338667] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.339592] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.346728] zram: Added device: zram0
[        KERNEL] [    2.346773] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.574446] Core Release: 2.80a
[        KERNEL] [    2.574455] Setting default values for core params
[        KERNEL] [    2.574482] Finished setting default values for core params
[        KERNEL] [    2.774830] Using Buffer DMA mode
[        KERNEL] [    2.774836] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.774840] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.774845] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.774871] Dedicated Tx FIFOs mode
[        KERNEL] [    2.775415] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    2.775439] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.775439] Non-periodic Split Transactions
[        KERNEL] [    2.775439] Periodic Split Transactions
[        KERNEL] [    2.775439] High-Speed Isochronous Endpoints
[        KERNEL] [    2.775439] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.775445] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.775489] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397d28
[        KERNEL] [    2.775498] WARN::hcd_init_fiq:460: FIQ ASM at 0x8039808c length 36
[        KERNEL] [    2.775508] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    2.775563] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    2.775594] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.775624] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    2.775668] Init: Port Power? op_state=1
[        KERNEL] [    2.775671] Init: Power Port (0)
[        KERNEL] [    2.775847] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    2.775858] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.775865] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    2.775872] usb usb1: Manufacturer: Linux 4.9.65 dwc_otg_hcd
[        KERNEL] [    2.775879] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    2.776609] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.776645] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.777300] dwc_otg: FIQ enabled
[        KERNEL] [    2.777304] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.777308] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.777321] Module dwc_common_port init
[        KERNEL] [    2.777687] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.779070] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.779542] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    2.780592] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    2.783061] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    2.785485] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    2.785595] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.786336] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.786341] usbhid: USB HID core driver
[        KERNEL] [    2.788836] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    2.793693] [vc_sm_connected_init]: start
[        KERNEL] [    2.801008] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.801288] NET: Registered protocol family 17
[        KERNEL] [    2.801428] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.801991] registered taskstats version 1
[        KERNEL] [    2.806201] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    2.882448] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    2.884561] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.884565] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    2.942487] of_cfs_init
[        KERNEL] [    2.942541] of_cfs_init: OK
[        KERNEL] [    2.954440] Freeing unused kernel memory: 5120K
[        KERNEL] [    2.995570] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    2.999565] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.001070] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.002519] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    3.003772] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.050972] random: fast init done
[        KERNEL] [    3.114632] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.202472] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.202616] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.250981] Block device 254:0. No action.
[          pfac] [    3.292186] Run /sbin/initrd.
[          pfac] [    3.292293] Ok, PID 601.
[        initrd] [    3.295332] WTware shell 5.6.22/RPi
[        KERNEL] [    3.432708] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.432720] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.433524] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.433621] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.752467] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.882688] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    3.882699] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.982466] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.116543] usb 1-1.2: New USB device found, idVendor=2188, idProduct=0ae1
[        KERNEL] [    4.116554] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[        KERNEL] [    4.116561] usb 1-1.2: Product: USB OPTICAL MOUSE
[        KERNEL] [    4.122021] input: USB OPTICAL MOUSE  as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:2188:0AE1.0001/input/input0
[        KERNEL] [    4.122847] hid-generic 0003:2188:0AE1.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.472466] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[        KERNEL] [    4.636415] usb 1-1.3: New USB device found, idVendor=1a2c, idProduct=2d23
[        KERNEL] [    4.636426] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.636434] usb 1-1.3: Product: USB Keyboard
[        KERNEL] [    4.636441] usb 1-1.3: Manufacturer: USB
[        KERNEL] [    4.647381] input: USB USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:1A2C:2D23.0002/input/input1
[        KERNEL] [    4.713586] hid-generic 0003:1A2C:2D23.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-3f980000.usb-1.3/input0
[        KERNEL] [    4.723956] input: USB USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1A2C:2D23.0003/input/input2
[        KERNEL] [    4.852984] hid-generic 0003:1A2C:2D23.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keyboard] on usb-3f980000.usb-1.3/input1
[        initrd] [    5.280491] Load ethernet drivers.
[        initrd] [    5.284088] modprobe smsc95xx.
[        KERNEL] [    5.293968] smsc95xx v1.0.5
[        KERNEL] [    5.385861] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:aa:fa:2b
[        KERNEL] [    5.386078] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    5.474256] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        KERNEL] [    7.866307] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[        initrd] [    9.080595] 00000080:000000000000000073746172742E656C66000000000000000000000000000000  ........start.elf...............
[        initrd] [   11.470085] dhcp: server address 10.11.0.30.
[        initrd] [   11.470572] Use default TFTP prefix for Raspberry network boot.
[        initrd] [   11.470643] TFTP binary "5.6.22/", configs prefix "", using "/" slash.
[        KERNEL] [   20.752555] random: crng init done
[        initrd] [   21.479258]       diskDevice.cpp (  744): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[        initrd] [   21.479348]          bootWay.cpp (   88): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[        initrd] [   21.479422]          bootWay.cpp (   94): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[        initrd] [   21.479496]           initrd.cpp (  248): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[        initrd] [   21.499522] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   21.499952] Run /sbin/httpd.
[          pfac] [   21.500093] Ok, PID 644.
[         httpd] [   21.504767] HTTP Server, WTware 5.6.22/RPi
[        initrd] [   21.610354] USB: 1a2c:2d23 China Resource Semico Co., Ltd.
[        initrd] [   21.610490] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   21.610567] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   21.610639] USB: 2188:0ae1 .
[        initrd] [   21.610708] [TFTP] Download config file Everyone/source.wtc from 10.11.0.30.
[        initrd] [   21.613858] [TFTP] It is not WTware5 TFTP server.
[        initrd] [   21.629696] [TFTP] Download config file Everyone/list.wtc from 10.11.0.30.
[        initrd] [   21.639755] [TFTP] Download config file Terminals/B8.27.EB.AA.FA.2B/config.wtc from 10.11.0.30.
| user=usertest
| sound=on, hw:1:0
| skin=Papel
| microphone=on
| server=--new--
| bpp=16
[        initrd] [   21.653251] [TFTP] Download config file Everyone/all.wtc from 10.11.0.30.
| domain=domaintest.local
| keyboard=pt-br
| language=pt-br,default
| skin=sample
| sound=on, hw:1:0
| keyboard=pt-br
| skin=Papel
| sound=on, hw:1:0
| user=usertest
| microphone=on
| server=--new--
| bpp=16
[        initrd] [   21.659738] Hostname: "wtwB827XXXXXXXX".
[         httpd] [   22.004805] Reread settings.
[         httpd] [   22.004945] Everyone can control terminal by HTTP.
[            gm] [   22.009306] WTware session manager 5.6.22/RPi.
[            gm] [   22.010761] Add keyboard event2: USB USB Keyboard.
[            gm] [   22.010851] Add keyboard event1: USB USB Keyboard.
[            gm] [   22.080109] EV_REL flag found. Add mouse event0: USB OPTICAL MOUSE .
[            gm] [   22.080312] Display mode: 1920x1080, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   22.098838] Framebuffer device found.
[            gm] [   22.098919] LINELENBYTES 3840
[            gm] [   22.098995] VLEN 4147200
[            gm] [   22.118164] Use /lib/ui16.so.
[            gm] [   22.118702] [TFTP] Download config file Graphic/Papel/menu.png from 10.11.0.30.
[            gm] [   22.157209] [TFTP] Download config file Graphic/Papel/popup.png from 10.11.0.30.
[            gm] [   22.165360] [TFTP] Download config file Graphic/Papel/saver.png from 10.11.0.30.
[            gm] [   22.187227] [TFTP] Download config file Graphic/Papel/wait.png from 10.11.0.30.
[            gm] [   22.305303] [TFTP] Download and unpack file 5.6.22/pi2/localboot/packages/pi2-alsa from 10.11.0.30.
[            gm] [   22.904681] modprobe snd-bcm2835.
[            gm] [   22.924626] modprobe snd-usb-audio.
|   0: [ 0]   : control
|  33:        : timer
[        KERNEL] [   22.944947] usbcore: registered new interface driver snd-usb-audio
[            gm] [   22.944432] /dev/snd/pcmC0D1p character device.
[            gm] [   22.944533] /dev/snd/pcmC0D0p character device.
[            gm] [   22.944652] /dev/snd/controlC0 character device.
[            gm] [   22.944761] /dev/snd/timer character device.
[            gm] [   22.944891] Preconfigure ALSA.
[            gm] [   23.055488] Nobody can control terminal by VNC.
[      rdpaudin] [   25.976626] Caught signal SIGSEGV.
[          pfac] [   25.977328] Process pid 674 terminated, status 00000000.
[        rdpsnd] [   25.982220] Caught signal SIGSEGV.
[          pfac] [   25.982318] Process pid 673 terminated, status 00000000.
[            gm] [   38.257031] Run '/sbin/resolver 0x349d48 dns [192.168.24.74]', log '', env '', pid ''.
[          pfac] [   38.257387] Run /sbin/resolver 0x349d48 dns [192.168.24.74].
[          pfac] [   38.257737] Ok, PID 678.
[          pfac] [   38.261690] Process pid 678 terminated, status 00000000.
[            gm] [   38.263907] 192.168.24.74 => 192.168.24.74.
[            gm] [   38.280382] Free ram before fork terminal client /sbin/rdpclient (session 1): 924688 Kb.
[            gm] [   38.280606] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   38.280865] Run /sbin/rdpclient 1.
[          pfac] [   38.281124] Ok, PID 679.
[ rdpclient 679] [   38.288475] RDP Terminal Client, WTware 5.6.22/RPi, pipe 1, pid 679.
[ rdpclient 679] [   38.290142] Use /lib/ui16.so.
[ rdpclient 679] [   38.291341] Redirect sound.
[ rdpclient 679] [   41.292615] rdpclient-rdpsnd.cpp (  572): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 679] [   41.292745] rdpclient-vchans.cpp (   67): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 679] [   41.292829] Make RDP session with 192.168.24.74, port 3389.
[ rdpclient 679] [   41.293030]  Username: "usertest".
[ rdpclient 679] [   41.293114]  No password.
[ rdpclient 679] [   41.293192]  No PIN.
[ rdpclient 679] [   41.293268]  Domain: "domaintest.local".
[ rdpclient 679] [   41.293344]  No shell.
[ rdpclient 679] [   41.293420]  No directory.
[ rdpclient 679] [   41.293495]  Window: 1920x1080@16.
[ rdpclient 679] [   41.293570]  PFlags 0x0000002F.
[ rdpclient 679] [   41.293645]  Keyboard 00000416:00000000.
[ rdpclient 679] [   41.293720]  My hostname "wtwB827XXXXXXXX".
[ rdpclient 679] [   41.293795] TCP: connecting to 192.168.24.74:3389.
[ rdpclient 679] [   41.320032] TCP: connection with 192.168.24.74:3389 established.
[ rdpclient 679] [   41.320124] Turn keepalive on.
[ rdpclient 679] [   41.320903] Free ram after buffers allocation: 924424 KB.
[ rdpclient 679] [   41.564944] Process RDP server certificate.
[ rdpclient 679] [   41.565123] RDP4 encryption.
[ rdpclient 679] [   81.037132] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000004.
[ rdpclient 679] [   81.723877] SessionId 0x00000004: DOMAINTEST\administrador.
[ rdpclient 679] [  106.312998] Sound version: 6.
[ rdpclient 679] [  106.313182] ADPCM sound compression.
[ rdpclient 679] [  106.313264] Sound redirection: 44100 frames per second.
[ rdpclient 679] [  106.560656] rdpclient-rdpsnd.cpp (  420): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 679] [  106.560862] Caught signal SIGSEGV.
[          pfac] [  106.563672] Process pid 679 terminated, status 00000000.
[            gm] [  106.563749] Caught signal SIGPIPE.
[            gm] [  106.563829]  TSClientSession.cpp (  346): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[            gm] [  106.564098] Ask server address.
The log (dmesg) from raspbian:
pi@raspberrypi:~ $ dmesg
[    0.000000] Linux version 4.9.26v7-aufs (max@lynx) (gcc version 4.8.4 (Buildroot 2015.02-g34f9ed3-dirty) ) #1 SMP Tue May 9 20:14:03 CEST 2017
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 215180
[    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  elevator=deadline bootmenutimeout=10 datadev=mmcblk0p2 qmap=us
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 825056K/868352K available (8192K kernel code, 535K rwdata, 2396K rodata, 1024K init, 802K bss, 35104K reserved, 8192K cma-reserved)
[    0.000341] Console: colour dummy device 80x30
[    0.001187] console [tty0] enabled
[    0.001236] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001306] pid_max: default: 32768 minimum: 301
[    0.001648] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001691] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002820] Disabling cpuset control group subsystem
[    0.003009] CPU: Testing write buffer coherency: ok
[    0.003080] ftrace: allocating 25844 entries in 76 pages
[    0.064151] CPU0: update cpu_capacity 1024
[    0.064214] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.064311] Setting up static identity map for 0x100000 - 0x100034
[    0.066462] CPU1: update cpu_capacity 1024
[    0.066470] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.067132] CPU2: update cpu_capacity 1024
[    0.067139] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.067764] CPU3: update cpu_capacity 1024
[    0.067771] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.067856] Brought up 4 CPUs
[    0.068026] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.068055] CPU: All CPU(s) started in HYP mode.
[    0.068081] CPU: Virtualization extensions available.
[    0.068829] devtmpfs: initialized
[    0.080326] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.080648] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.080709] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.081283] xor: measuring software checksum speed
[    0.173566]    arm4regs  :  1020.000 MB/sec
[    0.273650]    8regs     :   660.400 MB/sec
[    0.373733]    32regs    :   529.200 MB/sec
[    0.473819]    neon      :  1158.800 MB/sec
[    0.473848] xor: using function: neon (1158.800 MB/sec)
[    0.473883] pinctrl core: initialized pinctrl subsystem
[    0.474833] NET: Registered protocol family 16
[    0.476952] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.485765] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.485813] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.485989] Serial: AMBA PL011 UART driver
[    0.487870] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.488426] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.734421] raid6: int32x1  gen()    98 MB/s
[    0.904364] raid6: int32x1  xor()    88 MB/s
[    1.074730] raid6: int32x2  gen()   139 MB/s
[    1.244799] raid6: int32x2  xor()   105 MB/s
[    1.415026] raid6: int32x4  gen()   172 MB/s
[    1.585149] raid6: int32x4  xor()   115 MB/s
[    1.755607] raid6: int32x8  gen()   164 MB/s
[    1.925639] raid6: int32x8  xor()   111 MB/s
[    2.095839] raid6: neonx1   gen()   364 MB/s
[    2.265962] raid6: neonx1   xor()   364 MB/s
[    2.436136] raid6: neonx2   gen()   594 MB/s
[    2.606300] raid6: neonx2   xor()   507 MB/s
[    2.776496] raid6: neonx4   gen()   758 MB/s
[    2.946665] raid6: neonx4   xor()   558 MB/s
[    3.116929] raid6: neonx8   gen()   667 MB/s
[    3.287071] raid6: neonx8   xor()   484 MB/s
[    3.287099] raid6: using algorithm neonx4 gen() 758 MB/s
[    3.287127] raid6: .... xor() 558 MB/s, rmw enabled
[    3.287154] raid6: using intx1 recovery algorithm
[    3.287437] bcm2835-dma 3f007000.dma: DMA legacy API manager at b580f000, dmachans=0x1
[    3.289365] SCSI subsystem initialized
[    3.289548] usbcore: registered new interface driver usbfs
[    3.289658] usbcore: registered new interface driver hub
[    3.289788] usbcore: registered new device driver usb
[    3.297089] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-04-27 17:27
[    3.298490] clocksource: Switched to clocksource arch_sys_counter
[    3.346294] VFS: Disk quotas dquot_6.6.0
[    3.346404] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    3.346672] FS-Cache: Loaded
[    3.346945] CacheFiles: Loaded
[    3.359259] NET: Registered protocol family 2
[    3.360181] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    3.360318] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    3.360528] TCP: Hash tables configured (established 8192 bind 8192)
[    3.360640] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    3.360707] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    3.360941] NET: Registered protocol family 1
[    3.361370] RPC: Registered named UNIX socket transport module.
[    3.361402] RPC: Registered udp transport module.
[    3.361429] RPC: Registered tcp transport module.
[    3.361456] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.361721] Trying to unpack rootfs image as initramfs...
[    3.361751] Skipping 64-byte uInitrd header...
[    4.443307] Freeing initrd memory: 12704K (ae398000 - af000000)
[    4.447090] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    4.449574] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    4.465664] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    4.466222] FS-Cache: Netfs 'nfs' registered for caching
[    4.467233] NFS: Registering the id_resolver key type
[    4.467292] Key type id_resolver registered
[    4.467319] Key type id_legacy registered
[    4.468905] aufs 4.9-20170410
[    4.470310] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    4.470457] io scheduler noop registered
[    4.470487] io scheduler deadline registered (default)
[    4.470774] io scheduler cfq registered
[    4.476715] BCM2708FB: allocated DMA memory f4910000
[    4.476766] BCM2708FB: allocated DMA channel 0 @ b580f000
[    4.535061] Console: switching to colour frame buffer device 240x67
[    4.570480] bcm2835-rng 3f104000.rng: hwrng registered
[    4.570751] vc-cma: Videocore CMA driver
[    4.570867] vc-cma: vc_cma_base      = 0x00000000
[    4.571000] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    4.571149] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    4.571505] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    4.572269] [drm] Initialized
[    4.587271] brd: module loaded
[    4.596572] loop: module loaded
[    4.596707] Loading iSCSI transport class v2.0-870.
[    4.597384] usbcore: registered new interface driver smsc95xx
[    4.597569] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    4.823795] Core Release: 2.80a
[    4.823903] Setting default values for core params
[    4.824074] Finished setting default values for core params
[    5.024600] Using Buffer DMA mode
[    5.024706] Periodic Transfer Interrupt Enhancement - disabled
[    5.024873] Multiprocessor Interrupt Enhancement - disabled
[    5.025034] OTG VER PARAM: 0, OTG VER FLAG: 0
[    5.025168] Dedicated Tx FIFOs mode
[    5.025621] WARN::dwc_otg_hcd_init:1060: FIQ DMA bounce buffers: virt = 0xb4904000 dma = 0xf4904000 len=9024
[    5.025918] FIQ FSM acceleration enabled for :
[    5.026519] dwc_otg: Microframe scheduler enabled
[    5.026564] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x806c96d4
[    5.026740] WARN::hcd_init_fiq:460: FIQ ASM at 0x806c9a34 length 36
[    5.026925] WARN::hcd_init_fiq:486: MPHI regs_base at 0xb587a000
[    5.027151] dwc_otg 3f980000.usb: DWC OTG Controller
[    5.027326] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    5.027561] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    5.035120] Init: Port Power? op_state=1
[    5.042517] Init: Power Port (0)
[    5.050051] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    5.057449] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.064865] usb usb1: Product: DWC OTG Controller
[    5.072211] usb usb1: Manufacturer: Linux 4.9.26v7-aufs dwc_otg_hcd
[    5.079625] usb usb1: SerialNumber: 3f980000.usb
[    5.087762] hub 1-0:1.0: USB hub found
[    5.095253] hub 1-0:1.0: 1 port detected
[    5.103322] dwc_otg: FIQ enabled
[    5.103326] dwc_otg: NAK holdoff enabled
[    5.103330] dwc_otg: FIQ split-transaction FSM enabled
[    5.103343] Module dwc_common_port init
[    5.103578] usbcore: registered new interface driver usb-storage
[    5.111255] mousedev: PS/2 mouse device common for all mice
[    5.119900] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    5.127671] bcm2835-cpufreq: min=600000 max=1200000
[    5.135530] sdhci: Secure Digital Host Controller Interface driver
[    5.142962] sdhci: Copyright(c) Pierre Ossman
[    5.150622] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[    5.160236] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[    5.167784] sdhci-pltfm: SDHCI platform and OF driver helper
[    5.182929] ledtrig-cpu: registered to indicate activity on CPUs
[    5.190630] hidraw: raw HID events driver (C) Jiri Kosina
[    5.200385] usbcore: registered new interface driver usbhid
[    5.207962] usbhid: USB HID core driver
[    5.215847] ashmem: initialized
[    5.224102] vchiq: vchiq_init_state: slot_zero = 0xb4980000, is_master = 0
[    5.233873] Initializing XFRM netlink socket
[    5.241556] NET: Registered protocol family 17
[    5.249260] Key type dns_resolver registered
[    5.257118] Registering SWP/SWPB emulation handler
[    5.265475] registered taskstats version 1
[    5.275714] Btrfs loaded, crc32c=crc32c-generic
[    5.283621] vc-sm: Videocore shared memory driver
[    5.291153] [vc_sm_connected_init]: start
[    5.299173] [vc_sm_connected_init]: end - returning 0
[    5.312926] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    5.322424] sdhost: log_buf @ b4907000 (f4907000)
[    5.350760] Indeed it is in host mode hprt0 = 00021501
[    5.445930] random: fast init done
[    5.448524] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    5.450809] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    5.450816] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    5.528626] of_cfs_init
[    5.536407] of_cfs_init: OK
[    5.545664] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    5.546019] Freeing unused kernel memory: 1024K (80c00000 - 80d00000)
[    5.561585] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    5.570592] Indeed it is in host mode hprt0 = 00001101
[    5.640562] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    5.650629] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    5.653582] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    5.657733] mmc0: host does not support reading read-only switch, assuming write-enable
[    5.660811] mmc0: new high speed SDHC card at address aaaa
[    5.661590] mmcblk0: mmc0:aaaa SB32G 29.7 GiB
[    5.664312]  mmcblk0: p1 p2
[    5.750800] mmc1: new high speed SDIO card at address 0001
[    5.819013] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    5.819041] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.819908] hub 1-1:1.0: USB hub found
[    5.820011] hub 1-1:1.0: 5 ports detected
[    6.138629] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    6.268972] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    6.268998] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    6.271937] smsc95xx v1.0.5
[    6.363208] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2a:5f:a3
[    6.458646] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[    6.533207] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    6.547615] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[    6.592980] usb 1-1.2: New USB device found, idVendor=2188, idProduct=0ae1
[    6.593001] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    6.593014] usb 1-1.2: Product: USB OPTICAL MOUSE
[    6.598157] input: USB OPTICAL MOUSE  as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:2188:0AE1.0001/input/input0
[    6.643626] udevd[117]: starting version 2.1.1
[    6.659090] hid-generic 0003:2188:0AE1.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-3f980000.usb-1.2/input0
[    6.856200] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    6.943000] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[    6.948479] fb_ili9486: module is from the staging directory, the quality is unknown, you have been warned.
[    6.951752] fbtft_of_value: regwidth = 16
[    6.951774] fbtft_of_value: buswidth = 8
[    6.951785] fbtft_of_value: debug = 0
[    6.951808] fbtft_of_value: rotate = 90
[    6.951818] fbtft_of_value: fps = 30
[    6.958633] usb 1-1.5: new low-speed USB device number 5 using dwc_otg
[    6.992746] usbcore: registered new interface driver brcmfmac
[    7.105698] brcmfmac: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[    7.106599] usb 1-1.5: New USB device found, idVendor=1a2c, idProduct=2d23
[    7.106615] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.106627] usb 1-1.5: Product: USB Keyboard
[    7.106640] usb 1-1.5: Manufacturer: USB
[    7.118318] input: USB USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:1A2C:2D23.0002/input/input1
[    7.189583] hid-generic 0003:1A2C:2D23.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-3f980000.usb-1.5/input0
[    7.200154] input: USB USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:1A2C:2D23.0003/input/input2
[    7.269045] hid-generic 0003:1A2C:2D23.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keyboard] on usb-3f980000.usb-1.5/input1
[    7.613253] graphics fb1: fb_ili9486 frame buffer, 480x320, 300 KiB video memory, 4 KiB DMA buffer memory, fps=33, spi0.0 at 16 MHz
[    7.613538] spi0.1 supply vcc not found, using dummy regulator
[    7.614916] ads7846 spi0.1: touchscreen, irq 183
[    7.615510] input: ADS7846 Touchscreen as /devices/platform/soc/3f204000.spi/spi_master/spi0/spi0.1/input/input3
[    8.799860] random: crng init done
[   10.649057] systemd[1]: System time before build time, advancing clock.
[   10.730228] NET: Registered protocol family 10
[   10.743745] ip_tables: (C) 2000-2006 Netfilter Core Team
[   10.781191] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[   10.782384] systemd[1]: Detected architecture arm.
[   10.796647] systemd[1]: Set hostname to <raspberrypi>.
[   11.296142] systemd[1]: Listening on fsck to fsckd communication Socket.
[   11.297278] systemd[1]: Created slice User and Session Slice.
[   11.297657] systemd[1]: Reached target Swap.
[   11.298053] systemd[1]: Listening on udev Kernel Socket.
[   11.304612] systemd[1]: Listening on Journal Socket (/dev/log).
[   11.305556] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   11.306213] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.367186] i2c /dev entries driver
[   11.560214] systemd-journald[188]: Received request to flush runtime journal from PID 1
[   16.170576] uart-pl011 3f201000.serial: no DMA platform data
[   16.814717] brcmfmac: power management disabled
[   16.818316] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   17.179887] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   17.674132] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   18.711464] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[   20.596865] Bluetooth: Core ver 2.22
[   20.597011] NET: Registered protocol family 31
[   20.597017] Bluetooth: HCI device and connection manager initialized
[   20.598219] Bluetooth: HCI socket layer initialized
[   20.598234] Bluetooth: L2CAP socket layer initialized
[   20.598271] Bluetooth: SCO socket layer initialized
[   20.610408] Bluetooth: HCI UART driver ver 2.3
[   20.610421] Bluetooth: HCI UART protocol H4 registered
[   20.610425] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   20.610563] Bluetooth: HCI UART protocol Broadcom registered
[   20.845541] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   20.845550] Bluetooth: BNEP filters: protocol multicast
[   20.845567] Bluetooth: BNEP socket layer initialized
[   20.909840] Bluetooth: RFCOMM TTY layer initialized
[   20.909864] Bluetooth: RFCOMM socket layer initialized
[   20.909886] Bluetooth: RFCOMM ver 1.11
[   21.420920] fuse init (API version 7.26)
cat /proc/bus/input/devices (only Touchscreen output)
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="ADS7846 Touchscreen"
P: Phys=spi0.1/input0
S: Sysfs=/devices/platform/soc/3f204000.spi/spi_master/spi0/spi0.1/input/input3
U: Uniq=
H: Handlers=mouse1 event3
B: PROP=0
B: EV=b
B: KEY=400 0 0 0 0 0 0 0 0 0 0
B: ABS=1000003
cat /var/log/Xorg.0.log
X.Org X Server 1.19.2
Release Date: 2017-03-02
[    17.062] X Protocol Version 11, Revision 0
[    17.062] Build Operating System: Linux 4.9.41-v7+ armv7l Raspbian
[    17.062] Current Operating System: Linux raspberrypi 4.9.26v7-aufs #1 SMP Tue May 9 20:14:03 CEST 2017 armv7l
[    17.062] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  elevator=deadline bootmenutimeout=10 datadev=mmcblk0p2 qmap=us
[    17.063] Build Date: 18 October 2017  04:55:30PM
[    17.063] xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
[    17.063] Current version of pixman: 0.34.0
[    17.063]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[    17.063] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    17.063] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb  5 20:06:04 2018
[    17.066] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    17.077] (==) No Layout section.  Using the first Screen section.
[    17.077] (==) No screen section available. Using defaults.
[    17.077] (**) |-->Screen "Default Screen Section" (0)
[    17.077] (**) |   |-->Monitor "<default monitor>"
[    17.083] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[    17.083] (**) |   |-->Device "Allwinner A10/A13 FBDEV"
[    17.083] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[    17.083] (==) Automatically adding devices
[    17.083] (==) Automatically enabling devices
[    17.083] (==) Automatically adding GPU devices
[    17.083] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    17.088] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[    17.088]    Entry deleted from font path.
[    17.088] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    17.090] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    17.090]    Entry deleted from font path.
[    17.090] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    17.090] (==) FontPath set to:
        /usr/share/fonts/X11/100dpi/:unscaled,
        /usr/share/fonts/X11/Type1,
        /usr/share/fonts/X11/100dpi,
        built-ins
[    17.090] (==) ModulePath set to "/usr/lib/xorg/modules"
[    17.090] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[    17.092] (II) Loader magic: 0x1fbf40
[    17.092] (II) Module ABI versions:
[    17.092]    X.Org ANSI C Emulation: 0.4
[    17.092]    X.Org Video Driver: 23.0
[    17.092]    X.Org XInput driver : 24.1
[    17.092]    X.Org Server Extension : 10.0
[    17.094] (++) using VT number 7
[    17.094] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    17.095] (II) no primary bus or device found
[    17.095] (II) LoadModule: "glx"
[    17.106] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    17.203] (II) Module glx: vendor="X.Org Foundation"
[    17.203]    compiled for 1.19.2, module version = 1.0.0
[    17.203]    ABI class: X.Org Server Extension, version 10.0
[    17.203] (II) LoadModule: "fbturbo"
[    17.204] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[    17.206] (II) Module fbturbo: vendor="X.Org Foundation"
[    17.206]    compiled for 1.19.2, module version = 0.5.1
[    17.206]    Module class: X.Org Video Driver
[    17.206]    ABI class: X.Org Video Driver, version 23.0
[    17.206] (II) FBTURBO: driver for framebuffer: fbturbo
[    17.229] (WW) Falling back to old probe method for fbturbo
[    17.229] (II) Loading sub module "fbdevhw"
[    17.229] (II) LoadModule: "fbdevhw"
[    17.230] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    17.235] (II) Module fbdevhw: vendor="X.Org Foundation"
[    17.235]    compiled for 1.19.2, module version = 0.0.2
[    17.235]    ABI class: X.Org Video Driver, version 23.0
[    17.235] (II) FBTURBO(0): using /dev/fb1
[    17.235] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    17.235] (II) FBTURBO(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 16/16
[    17.235] (==) FBTURBO(0): Depth 16, (==) framebuffer bpp 16
[    17.235] (==) FBTURBO(0): RGB weight 565
[    17.235] (==) FBTURBO(0): Default visual is TrueColor
[    17.235] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[    17.235] (II) FBTURBO(0): hardware: fb_ili9486 (video memory: 300kB)
[    17.235] (**) FBTURBO(0): Option "fbdev" "/dev/fb1"
[    17.235] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[    17.236] (II) FBTURBO(0): processor: Unknown
[    17.236] (II) FBTURBO(0): checking modes against framebuffer device...
[    17.236] (II) FBTURBO(0): checking modes against monitor...
[    17.236] (--) FBTURBO(0): Virtual size is 480x320 (pitch 480)
[    17.236] (**) FBTURBO(0):  Built-in mode "current"
[    17.236] (==) FBTURBO(0): DPI set to (96, 96)
[    17.236] (II) Loading sub module "fb"
[    17.236] (II) LoadModule: "fb"
[    17.237] (II) Loading /usr/lib/xorg/modules/libfb.so
[    17.243] (II) Module fb: vendor="X.Org Foundation"
[    17.243]    compiled for 1.19.2, module version = 1.0.0
[    17.243]    ABI class: X.Org ANSI C Emulation, version 0.4
[    17.243] (II) FBTURBO(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[    17.262] (II) FBTURBO(0): using backing store heuristics
[    17.269] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[    17.269] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[    17.269] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[    17.269] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[    17.269] (II) FBTURBO(0): enabled VFP/NEON optimizations
[    17.269] (==) FBTURBO(0): Backing store enabled
[    17.277] (==) FBTURBO(0): DPMS enabled
[    17.277] (II) FBTURBO(0): failed to enable hardware cursor
[    17.277] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[    17.277] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[    17.278] (==) RandR enabled
[    17.307] (II) SELinux: Disabled on system
[    17.314] (II) AIGLX: Screen 0 is not DRI2 capable
[    17.314] (EE) AIGLX: reverting to software rendering
[    18.457] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[    18.459] (II) IGLX: Loaded and initialized swrast
[    18.459] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    18.696] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event3)
[    18.697] (**) ADS7846 Touchscreen: Applying InputClass "evdev touchscreen catchall"
[    18.697] (**) ADS7846 Touchscreen: Applying InputClass "libinput touchscreen catchall"
[    18.697] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[    18.697] (II) LoadModule: "evdev"
[    18.697] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    18.721] (II) Module evdev: vendor="X.Org Foundation"
[    18.721]    compiled for 1.19.0, module version = 2.10.5
[    18.721]    Module class: X.Org XInput Driver
[    18.721]    ABI class: X.Org XInput driver, version 24.1
[    18.721] (II) Using input driver 'evdev' for 'ADS7846 Touchscreen'
[    18.721] (**) ADS7846 Touchscreen: always reports core events
[    18.721] (**) evdev: ADS7846 Touchscreen: Device: "/dev/input/event3"
[    18.722] (--) evdev: ADS7846 Touchscreen: Vendor 0 Product 0
[    18.722] (--) evdev: ADS7846 Touchscreen: Found absolute axes
[    18.722] (--) evdev: ADS7846 Touchscreen: Found x and y absolute axes
[    18.722] (--) evdev: ADS7846 Touchscreen: Found absolute touchscreen
[    18.722] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen
[    18.722] (**) evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5
[    18.722] (**) evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    18.722] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f204000.spi/spi_master/spi0/spi0.1/input/input3/event3"
[    18.722] (II) XINPUT: Adding extended input device "ADS7846 Touchscreen" (type: TOUCHSCREEN, id 6)
[    18.722] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes.
[    18.723] (**) ADS7846 Touchscreen: (accel) keeping acceleration scheme 1
[    18.723] (**) ADS7846 Touchscreen: (accel) acceleration profile 0
[    18.723] (**) ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[    18.723] (**) ADS7846 Touchscreen: (accel) acceleration threshold: 4
[    18.725] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/mouse1)
[    18.725] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[    18.725] (II) Using input driver 'evdev' for 'ADS7846 Touchscreen'
[    18.726] (**) ADS7846 Touchscreen: always reports core events
[    18.726] (**) evdev: ADS7846 Touchscreen: Device: "/dev/input/mouse1"
[    18.726] (EE) evdev: ADS7846 Touchscreen: Unable to query fd: Inappropriate ioctl for device
[    18.810] (EE) PreInit returned 2 for "ADS7846 Touchscreen"
[    18.810] (II) UnloadModule: "evdev"
[    18.813] (II) config/udev: Adding input device USB OPTICAL MOUSE  (/dev/input/event0)
[    18.813] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[    18.813] (**) USB OPTICAL MOUSE : Applying InputClass "libinput pointer catchall"
[    18.813] (II) Using input driver 'evdev' for 'USB OPTICAL MOUSE '
[    18.813] (**) USB OPTICAL MOUSE : always reports core events
[    18.813] (**) evdev: USB OPTICAL MOUSE : Device: "/dev/input/event0"
[    18.813] (--) evdev: USB OPTICAL MOUSE : Vendor 0x2188 Product 0xae1
[    18.813] (--) evdev: USB OPTICAL MOUSE : Found 3 mouse buttons
[    18.813] (--) evdev: USB OPTICAL MOUSE : Found scroll wheel(s)
[    18.813] (--) evdev: USB OPTICAL MOUSE : Found relative axes
[    18.813] (--) evdev: USB OPTICAL MOUSE : Found x and y relative axes
[    18.813] (II) evdev: USB OPTICAL MOUSE : Configuring as mouse
[    18.813] (II) evdev: USB OPTICAL MOUSE : Adding scrollwheel support
[    18.813] (**) evdev: USB OPTICAL MOUSE : YAxisMapping: buttons 4 and 5
[    18.813] (**) evdev: USB OPTICAL MOUSE : EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    18.813] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:2188:0AE1.0001/input/input0/event0"
[    18.813] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE " (type: MOUSE, id 7)
[    18.814] (II) evdev: USB OPTICAL MOUSE : initialized for relative axes.
[    18.814] (**) USB OPTICAL MOUSE : (accel) keeping acceleration scheme 1
[    18.814] (**) USB OPTICAL MOUSE : (accel) acceleration profile 0
[    18.814] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[    18.814] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[    18.817] (II) config/udev: Adding input device USB OPTICAL MOUSE  (/dev/input/mouse0)
[    18.817] (II) No input driver specified, ignoring this device.
[    18.817] (II) This device may have been added with another device file.
[    18.820] (II) config/udev: Adding input device USB USB Keyboard (/dev/input/event1)
[    18.820] (**) USB USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    18.820] (**) USB USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    18.820] (II) Using input driver 'evdev' for 'USB USB Keyboard'
[    18.820] (**) USB USB Keyboard: always reports core events
[    18.820] (**) evdev: USB USB Keyboard: Device: "/dev/input/event1"
[    18.820] (--) evdev: USB USB Keyboard: Vendor 0x1a2c Product 0x2d23
[    18.820] (--) evdev: USB USB Keyboard: Found keys
[    18.821] (II) evdev: USB USB Keyboard: Configuring as keyboard
[    18.821] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:1A2C:2D23.0002/input/input1/event1"
[    18.821] (II) XINPUT: Adding extended input device "USB USB Keyboard" (type: KEYBOARD, id 8)
[    18.821] (**) Option "xkb_rules" "evdev"
[    18.821] (**) Option "xkb_model" "pc105"
[    18.821] (**) Option "xkb_layout" "br"
[    18.899] (II) config/udev: Adding input device USB USB Keyboard (/dev/input/event2)
[    18.899] (**) USB USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    18.899] (**) USB USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    18.899] (II) Using input driver 'evdev' for 'USB USB Keyboard'
[    18.899] (**) USB USB Keyboard: always reports core events
[    18.899] (**) evdev: USB USB Keyboard: Device: "/dev/input/event2"
[    18.899] (--) evdev: USB USB Keyboard: Vendor 0x1a2c Product 0x2d23
[    18.899] (--) evdev: USB USB Keyboard: Found 1 mouse buttons
[    18.899] (--) evdev: USB USB Keyboard: Found scroll wheel(s)
[    18.899] (--) evdev: USB USB Keyboard: Found relative axes
[    18.899] (II) evdev: USB USB Keyboard: Forcing relative x/y axes to exist.
[    18.899] (--) evdev: USB USB Keyboard: Found absolute axes
[    18.899] (II) evdev: USB USB Keyboard: Forcing absolute x/y axes to exist.
[    18.899] (--) evdev: USB USB Keyboard: Found keys
[    18.900] (II) evdev: USB USB Keyboard: Configuring as mouse
[    18.900] (II) evdev: USB USB Keyboard: Configuring as keyboard
[    18.900] (II) evdev: USB USB Keyboard: Adding scrollwheel support
[    18.900] (**) evdev: USB USB Keyboard: YAxisMapping: buttons 4 and 5
[    18.900] (**) evdev: USB USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    18.900] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:1A2C:2D23.0003/input/input2/event2"
[    18.900] (II) XINPUT: Adding extended input device "USB USB Keyboard" (type: KEYBOARD, id 9)
[    18.900] (**) Option "xkb_rules" "evdev"
[    18.900] (**) Option "xkb_model" "pc105"
[    18.900] (**) Option "xkb_layout" "br"
[    18.901] (II) evdev: USB USB Keyboard: initialized for relative axes.
[    18.901] (WW) evdev: USB USB Keyboard: ignoring absolute axes.
[    18.902] (**) USB USB Keyboard: (accel) keeping acceleration scheme 1
[    18.902] (**) USB USB Keyboard: (accel) acceleration profile 0
[    18.902] (**) USB USB Keyboard: (accel) acceleration factor: 2.000
[    18.902] (**) USB USB Keyboard: (accel) acceleration threshold: 4
Re: Display TFT 3.5"
marcostelecom wrote: Mon Feb 05, 2018 11:29 pm The question: how can I do the same in the watware for RPI ?
No way. We will not support second display on Pi until we'll find more common hardware. Not 480x320.
