Have tried setting hash password in DHCP parameter 18 extensions-path option, but no matter what, you can access setup (Press DEL for setup), without entering password.
Does this not work for Rpi?
best regards
Martin
DHCP Option 18 ignored?
Re: DHCP Option 18 ignored?
It should work. Show me a log, please: https://wtware.com/logs.html
Hi, thanks for the great software.
I have the same problem with option 18 on WTware 5.6.24/RPi
Log:
look at this rows:
Log:
WTware 5.6.24
WTware 5.6.24/RPi supervisor.
[ KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
[ KERNEL] [ 0.000000] Linux version 4.9.75 (aka@c16) (gcc version 7.2.0 (Debian 7.2.0-11) ) #4 SMP Wed Jan 10 10:39:31 EST 2018
[ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ KERNEL] [ 0.000000] OF: fdt:Machine model: Raspberry Pi 2 Model B Rev 1.1
[ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80c22b80, node_mem_map ba3a1000
[ KERNEL] [ 0.000000] percpu: Embedded 11 pages/cpu @ba367000 s15948 r8192 d20916 u45056
[ KERNEL] [ 0.000000] pcpu-alloc: s15948 r8192 d20916 u45056 alloc=11*4096
[ KERNEL] [ 0.000000] Kernel command line: bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
[ KERNEL] [ 0.000000] Memory: 941160K/970752K available (5120K kernel code, 143K rwdata, 920K rodata, 5120K init, 365K bss, 21400K reserved, 8192K cma-reserved)
[ KERNEL] [ 0.000000] .init : 0x80700000 - 0x80c00000 (5120 kB)
[ KERNEL] [ 0.000000] .data : 0x80c00000 - 0x80c23e38 ( 144 kB)
[ KERNEL] [ 0.000000] .bss : 0x80c25000 - 0x80c805e0 ( 366 kB)
[ KERNEL] [ 0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ KERNEL] [ 0.000027] Switching to timer-based delay loop, resolution 52ns
[ KERNEL] [ 0.000262] Console: colour dummy device 80x30
[ KERNEL] [ 0.001024] console [tty1] enabled
[ KERNEL] [ 0.001069] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ KERNEL] [ 0.001141] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.001348] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.001392] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.002452] Disabling memory control group subsystem
[ KERNEL] [ 0.002577] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.003107] CPU0: update cpu_capacity 1024
[ KERNEL] [ 0.003152] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ KERNEL] [ 0.003218] Setting up static identity map for 0x100000 - 0x100034
[ KERNEL] [ 0.005601] CPU1: update cpu_capacity 1024
[ KERNEL] [ 0.005612] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ KERNEL] [ 0.006477] CPU2: update cpu_capacity 1024
[ KERNEL] [ 0.006485] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ KERNEL] [ 0.007343] CPU3: update cpu_capacity 1024
[ KERNEL] [ 0.007353] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ KERNEL] [ 0.007461] Brought up 4 CPUs
[ KERNEL] [ 0.007677] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ KERNEL] [ 0.007712] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.007744] CPU: Virtualization extensions available.
[ KERNEL] [ 0.008616] devtmpfs: initialized
[ KERNEL] [ 0.020569] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ KERNEL] [ 0.021215] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.021297] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 0.022043] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.022927] NET: Registered protocol family 16
[ KERNEL] [ 0.025225] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.037942] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.121885] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[ KERNEL] [ 0.125187] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.125422] usbcore: registered new interface driver hub
[ KERNEL] [ 0.125590] usbcore: registered new device driver usb
[ KERNEL] [ 0.130326] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-01-08 14:28
[ KERNEL] [ 0.133703] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.155759] NET: Registered protocol family 2
[ KERNEL] [ 0.156589] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.156755] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.156976] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.157116] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.157207] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.157509] NET: Registered protocol family 1
[ KERNEL] [ 3.009265] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ KERNEL] [ 3.096360] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ KERNEL] [ 3.096449] io scheduler noop registered
[ KERNEL] [ 3.096486] io scheduler deadline registered (default)
[ KERNEL] [ 3.112395] BCM2708FB: allocated DMA memory fad00000
[ KERNEL] [ 3.112499] BCM2708FB: allocated DMA channel 0 @ bb80f000
[ KERNEL] [ 3.170092] Console: switching to colour frame buffer device 240x67
[ KERNEL] [ 3.206428] bcm2835-rng 3f104000.rng: hwrng registered
[ KERNEL] [ 3.206781] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ KERNEL] [ 3.208162] vc-sm: Videocore shared memory driver
[ KERNEL] [ 3.220768] zram: Added device: zram0
[ KERNEL] [ 3.221078] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 3.449660] Core Release: 2.80a
[ KERNEL] [ 3.449834] Setting default values for core params
[ KERNEL] [ 3.450009] Finished setting default values for core params
[ KERNEL] [ 3.650592] Using Buffer DMA mode
[ KERNEL] [ 3.650734] Periodic Transfer Interrupt Enhancement - disabled
[ KERNEL] [ 3.650899] Multiprocessor Interrupt Enhancement - disabled
[ KERNEL] [ 3.651057] OTG VER PARAM: 0, OTG VER FLAG: 0
[ KERNEL] [ 3.651349] Dedicated Tx FIFOs mode
[ KERNEL] [ 3.652333] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad14000 dma = 0xfad14000 len=9024
[ KERNEL] [ 3.652635] FIQ FSM acceleration enabled for :
[ KERNEL] [ 3.652635] Non-periodic Split Transactions
[ KERNEL] [ 3.652635] Periodic Split Transactions
[ KERNEL] [ 3.652635] High-Speed Isochronous Endpoints
[ KERNEL] [ 3.652635] Interrupt/Control Split Transaction hack enabled
[ KERNEL] [ 3.653215] dwc_otg: Microframe scheduler enabled
[ KERNEL] [ 3.653284] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397770
[ KERNEL] [ 3.653467] WARN::hcd_init_fiq:460: FIQ ASM at 0x80397ad4 length 36
[ KERNEL] [ 3.653653] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[ KERNEL] [ 3.653934] dwc_otg 3f980000.usb: DWC OTG Controller
[ KERNEL] [ 3.654136] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ KERNEL] [ 3.654385] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ KERNEL] [ 3.654592] Init: Port Power? op_state=1
[ KERNEL] [ 3.654707] Init: Power Port (0)
[ KERNEL] [ 3.655080] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ KERNEL] [ 3.655280] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 3.655484] usb usb1: Product: DWC OTG Controller
[ KERNEL] [ 3.655622] usb usb1: Manufacturer: Linux 4.9.75 dwc_otg_hcd
[ KERNEL] [ 3.655785] usb usb1: SerialNumber: 3f980000.usb
[ KERNEL] [ 3.656955] hub 1-0:1.0: USB hub found
[ KERNEL] [ 3.657181] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 3.658328] dwc_otg: FIQ enabled
[ KERNEL] [ 3.658339] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 3.658344] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 3.658365] Module dwc_common_port init
[ KERNEL] [ 3.659163] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 3.661093] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ KERNEL] [ 3.661945] bcm2835-cpufreq: min=600000 max=900000
[ KERNEL] [ 3.675745] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[ KERNEL] [ 3.683913] ledtrig-cpu: registered to indicate activity on CPUs
[ KERNEL] [ 3.693113] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 3.704581] usbcore: registered new interface driver usbhid
[ KERNEL] [ 3.711505] usbhid: USB HID core driver
[ KERNEL] [ 3.729922] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[ KERNEL] [ 3.737799] [vc_sm_connected_init]: start
[ KERNEL] [ 3.747722] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 3.754516] NET: Registered protocol family 17
[ KERNEL] [ 3.760690] Registering SWP/SWPB emulation handler
[ KERNEL] [ 3.768293] registered taskstats version 1
[ KERNEL] [ 3.780890] sdhost: log_buf @ bad13000 (fad13000)
[ KERNEL] [ 3.863730] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ KERNEL] [ 3.863869] of_cfs_init
[ KERNEL] [ 3.863988] of_cfs_init: OK
[ KERNEL] [ 3.895399] Indeed it is in host mode hprt0 = 00021501
[ KERNEL] [ 3.897858] Freeing unused kernel memory: 5120K
[ KERNEL] [ 4.002403] random: fast init done
[ KERNEL] [ 4.021492] mmc0: host does not support reading read-only switch, assuming write-enable
[ KERNEL] [ 4.023495] mmc0: new high speed SDHC card at address 0001
[ KERNEL] [ 4.024675] mmcblk0: mmc0:0001 TEAM 14.8 GiB
[ KERNEL] [ 4.028193] mmcblk0: p1 p2
[ hotplug] [ 4.030801] Block device 179:1. No action.
[ hotplug] [ 4.031375] Block device 179:0. No action.
[ hotplug] [ 4.032495] Block device 179:2. No action.
[ KERNEL] [ 4.123763] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ KERNEL] [ 4.123940] Indeed it is in host mode hprt0 = 00001101
[ hotplug] [ 4.130807] Block device 254:0. No action.
[ pfac] [ 4.310808] Run /sbin/initrd.
[ pfac] [ 4.311146] Ok, PID 596.
[ initrd] [ 4.315813] WTware shell 5.6.24/RPi
[ KERNEL] [ 4.375037] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ KERNEL] [ 4.375045] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 4.375874] hub 1-1:1.0: USB hub found
[ KERNEL] [ 4.376006] hub 1-1:1.0: 5 ports detected
[ KERNEL] [ 4.693741] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ KERNEL] [ 4.824060] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ KERNEL] [ 4.824077] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 4.923760] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ KERNEL] [ 5.058682] usb 1-1.2: New USB device found, idVendor=03f0, idProduct=094a
[ KERNEL] [ 5.058698] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 5.058707] usb 1-1.2: Product: HP USB Optical Mouse
[ KERNEL] [ 5.058716] usb 1-1.2: Manufacturer: PixArt
[ KERNEL] [ 5.071417] input: PixArt HP USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:03F0:094A.0001/input/input0
[ KERNEL] [ 5.072706] hid-generic 0003:03F0:094A.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt HP USB Optical Mouse] on usb-3f980000.usb-1.2/input0
[ KERNEL] [ 5.173748] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[ KERNEL] [ 5.323193] usb 1-1.3: New USB device found, idVendor=04b3, idProduct=3025
[ KERNEL] [ 5.323211] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 5.323221] usb 1-1.3: Product: USB NetVista Full Width Keyboard
[ KERNEL] [ 5.323229] usb 1-1.3: Manufacturer: CHICONY
[ KERNEL] [ 5.337031] input: CHICONY USB NetVista Full Width Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:04B3:3025.0002/input/input1
[ KERNEL] [ 5.415465] hid-generic 0003:04B3:3025.0002: input,hidraw1: USB HID v1.10 Keyboard [CHICONY USB NetVista Full Width Keyboard] on usb-3f980000.usb-1.3/input0
[ initrd] [ 5.856664] Load ethernet drivers.
[ initrd] [ 5.856917] modprobe smsc95xx.
[ KERNEL] [ 5.870905] smsc95xx v1.0.5
[ KERNEL] [ 5.968398] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3a:5a:b9
[ KERNEL] [ 5.968809] usbcore: registered new interface driver smsc95xx
[ KERNEL] [ 6.076453] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ KERNEL] [ 7.512677] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
[ initrd] [ 10.960237] dhcp: 401 bytes from 192.168.3.254.
[ initrd] [ 10.960443] 00000000:0000017D0000000000110000C0A803FEFFFFFFFF00430044017D000002010600 ...}................C.D.}......
[ initrd] [ 10.960559] 00000020:67458B6B0000000000000000C0A801BAC0A8036F00000000B827EB3A5AB90000 gE.k...............o.....'.:Z...
[ initrd] [ 10.960658] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 10.960760] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 10.960857] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 10.960980] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 10.961076] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 10.961171] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.250249] dhcp: 401 bytes from 192.168.3.254.
[ initrd] [ 13.250442] 00000000:0000017D0000000000110000C0A803FEFFFFFFFF00430044017D000002010600 ...}................C.D.}......
[ initrd] [ 13.250558] 00000020:67458B6B0000000000000000C0A801BAC0A8036F00000000B827EB3A5AB90000 gE.k...............o.....'.:Z...
[ initrd] [ 13.250662] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.250761] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.250858] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.250954] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.251049] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.251144] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.300166] [DHCP] DHCP server address 192.168.3.254.
[ initrd] [ 13.300288] [DHCP] IP 192.168.1.186 mask 255.255.252.0.
[ initrd] [ 13.300394] [DHCP] Default gateway 192.168.0.1.
[ initrd] [ 13.300496] [DHCP] DNS 192.168.3.254.
[ initrd] [ 13.300593] [DHCP] DNS 192.168.3.253.
[ initrd] [ 13.300687] [DHCP] NTP 192.168.0.1.
[ initrd] [ 13.300782] [DHCP] Domain local.xxxxx.ru.
[ initrd] [ 13.300885] [DHCP] TFTP from 066 192.168.3.111.
[ initrd] [ 13.300988] [DHCP] TFTP 192.168.3.111.
[ initrd] [ 13.301091] [DHCP] Use default TFTP prefix for Raspberry network boot.
[ initrd] [ 13.301191] [DHCP] TFTP binary "5.6.24/", configs prefix "", using "/" slash.
[ initrd] [ 13.301294] [DHCP] WTPassword hash 3f9f2ea8e36aaeecfe82b1ba0e353683.
[ initrd] [ 13.309249] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
| # http://www.raspberrypi.org/documentation/configuration/config-txt.md
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| #hdmi_group=2
| # 800x600: hdmi_mode=9
| # 1024x768: hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768: hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900: hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768: hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| hdmi_blanking=1
[ initrd] [ 13.315126] WTpassword empty.
[ initrd] [ 13.351037] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ pfac] [ 13.351246] Run /sbin/httpd.
[ pfac] [ 13.351635] Ok, PID 634.
[ httpd] [ 13.360393] HTTP Server, WTware 5.6.24/RPi
[ initrd] [ 13.486826] USB: 04b3:3025 IBM Corp. NetVista Full Width Keyboard.
[ initrd] [ 13.487047] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[ initrd] [ 13.487178] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[ initrd] [ 13.487298] USB: 03f0:094a Hewlett-Packard Optical Mouse [672662-001].
[ initrd] [ 13.487410] [TFTP] Download config file Everyone/source.wtc from 192.168.3.111.
[ initrd] [ 13.497594] [TFTP] WTware TFTP v.5.6.24.
[ initrd] [ 13.511871] [TFTP] Download config file Everyone/list.wtc from 192.168.3.111.
[ initrd] [ 13.524639] [TFTP] Download config file Terminals/B8.27.EB.3A.5A.B9/config.wtc from 192.168.3.111.
[ initrd] [ 13.525468] [TFTP] Error code 1: File not found..
[ initrd] [ 13.525591] [TFTP] Download config file Terminals/B8.27.EB.3A.5A.B9.wtc from 192.168.3.111.
[ initrd] [ 13.526374] [TFTP] Error code 1: File not found..
[ initrd] [ 13.526489] [TFTP] Download config file Everyone/default.wtc from 192.168.3.111.
/--- FILE "/tmp/default.wtc" -----------------------
| # Список групп терминалов по подсетям.
| # Если терминал загружается по сети и не находит индивидуальный конфигурационный
| # файл на сервере, то он останавливает работу, сообщает, что терминал не настроен, и требует
| # создать конфигурационный файл для этого терминала.
| # Это поведение можно изменить. Для группы терминалов в выбранной подсети либо вообще для всех
| # терминалов можно создать конфигурационный файл по умолчанию. Создайте группу интересующих вас
| # терминалов, а затем в списке терминалов найдите соответствующую строку и создайте
| # конфигурацию по умолчанию.
| # После этого новый терминал из этой группы будет считаться автоматически настроенным:
| # не будет показывать предупреждений, а скачает созданную вами конфигурацию.
| # Формат строки в этом файле:
| # 03 10.1.1.0/24 Удаленный филиал
| # Первым идет номер группы в 16-ричном формате - 03. Допустимы номера от 01 до ff.
| # Тогда конфигурация группы 03 будет в папке FF.FF.FF.FF.FF.03 в каталоге Terminals.
| # Далее идут параметры подсети - IP и маска - 10.1.1.0/24.
| # "Удаленный филиал" - название группы, по которому вы найдете эту группу в конфигураторе
| # в списке терминалов.
| # Эта конфигурация будет скачиваться TFTP-сервером как индивидуальный конфигурационный
| # файл по умолчанию для терминалов из подсети 10.1.1.0/24, у которых нет собственного
| # конфигурационного файла.
| # Еще пример:
| # 0d 192.168.1.0/16 Подсеть бухгалтерии
| # Группа для подсети 192.168.1.0/16. Конфигурация хранится в каталоге FF.FF.FF.FF.FF.0d.
| # В списке терминалов в конфигураторе находится под названием "Подсеть бухгалтерии".
| # В конце файла можно добавить группу для всех остальных терминалов в сети, не попавших
| # в указанные подсети. Эта группа должна быть единственной. Эта группа должна быть последней
| # строкой в default.wtc. Все группы, указанные после нее, будут проигнорированы при считывании.
| # Формат строки группы для всех терминалов:
| 1f all ZOOOOOO
[ initrd] [ 13.541421] Default config group FF:FF:FF:FF:FF:1F.
[ initrd] [ 13.541553] [TFTP] Download config file Terminals/FF.FF.FF.FF.FF.1F/config.wtc from 192.168.3.111.
[ initrd] [ 13.551101] [TFTP] Download config file Everyone/all.wtc from 192.168.3.111.
| server=rdp
| disk=cdrom; usb
| graphic=af
| onerror=30
| sleep=10,poweroff
| sound=on
| vnc=on
| vnc_password=hex:797593216c9c954ea74e400d2dd28133
| clienthostname=wt*IP3
| mouse_accel_mult=2.5
| server=rdp
| disk=cdrom; usb
| graphic=af
| onerror=30
| sleep=10,poweroff
| sound=on
| vnc=on
| vnc_password=off
[ initrd] [ 13.572739] Hostname: "wt-168-1-186".
[ initrd] [ 13.860309] Run '/usr/sbin/ntpdate -bs 192.168.0.1', log '', env '', pid ''.
[ pfac] [ 13.860435] Run /usr/sbin/ntpdate -bs 192.168.0.1.
[ pfac] [ 13.862249] Ok, PID 635.
[ httpd] [ 13.868434] Reread settings.
[ httpd] [ 13.868670] Everyone can control terminal by HTTP.
[ gm] [ 13.874596] WTware session manager 5.6.24/RPi.
[ gm] [ 13.874744] Add keyboard event1: CHICONY USB NetVista Full Width Keyboard.
[ gm] [ 13.940243] EV_REL flag found. Add mouse event0: PixArt HP USB Optical Mouse.
[ gm] [ 13.940590] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 13.974219] Framebuffer device found.
[ gm] [ 13.974804] LINELENBYTES 7680
[ gm] [ 13.974949] VLEN 8294400
[ gm] [ 14.009942] Use /lib/ui32.so.
[ gm] [ 14.069162] [WARNING] 'disk = cdrom' does not work on Raspberry.
[ gm] [ 14.069375] [WARNING] 'disk = cdrom' does not work on Raspberry.
[ gm] [ 14.069507] [TFTP] Download and unpack file 5.6.24/pi2/localboot/packages/pi2-alsa from 192.168.3.111.
[ gm] [ 14.747900] modprobe snd-bcm2835.
[ gm] [ 14.780504] modprobe snd-usb-audio.
[ KERNEL] [ 14.817123] usbcore: registered new interface driver snd-usb-audio
| 0: [ 0] : control
| 16: [ 0- 0]: digital audio playback
| 17: [ 0- 1]: digital audio playback
| 33: : timer
[ gm] [ 14.816674] /dev/snd/pcmC0D1p character device.
[ gm] [ 14.816889] /dev/snd/pcmC0D0p character device.
[ gm] [ 14.817080] /dev/snd/controlC0 character device.
[ pfac] [ 14.817289] Run /sbin/rdpsnd sndvol 100 100 50.
[ gm] [ 14.817406] /dev/snd/timer character device.
[ gm] [ 14.817578] Preconfigure ALSA.
[ pfac] [ 14.817767] Ok, PID 663.
[ gm] [ 14.817874] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[ pfac] [ 14.818090] Run /sbin/rdpsnd 1 0 100 0 -1.
[ gm] [ 14.818217] Run sound daemon.
[ pfac] [ 14.818421] Ok, PID 664.
[ gm] [ 14.818531] Run '/sbin/rdpsnd 1 0 100 0 -1', log '', env '', pid ''.
[ gm] [ 14.818750] Load usb storage driver.
[ gm] [ 14.818968] modprobe scsi_mod.
[ rdpsnd] [ 14.828541] RDP Sound Redirector, WTware 5.6.24/RPi.
[ gm] [ 14.843762] modprobe usb-storage.
[ KERNEL] [ 14.845582] SCSI subsystem initialized
[ rdpsnd] [ 14.844870] Card 'ALSA'/'bcm2835 ALSA'.
[ rdpsnd] [ 14.845084] Mixer name: 'Broadcom Mixer'.
[ rdpsnd] [ 14.845284] Components: ''.
[ rdpsnd] [ 14.845444] Controls: 6.
[ rdpsnd] [ 14.845613] ALSA: control 'PCM Playback Volume'.
[ rdpsnd] [ 14.845783] ALSA: control 'PCM Playback Switch'.
[ rdpsnd] [ 14.845947] ALSA: control 'PCM Playback Route'.
[ rdpsnd] [ 14.846131] ALSA: control 'IEC958 Playback Default'.
[ rdpsnd] [ 14.846313] ALSA: control 'IEC958 Playback Con Mask'.
[ rdpsnd] [ 14.846516] ALSA: control 'IEC958 Playback PCM Stream'.
[ rdpsnd] [ 14.846706] Inactive control IEC958 Playback PCM Stream'.
[ sndvol] [ 14.849170] Card 'ALSA'/'bcm2835 ALSA'.
[ sndvol] [ 14.849437] Mixer name: 'Broadcom Mixer'.
[ sndvol] [ 14.849659] Components: ''.
[ sndvol] [ 14.849859] Controls: 6.
[ sndvol] [ 14.850256] ALSA: control 'PCM Playback Volume'.
[ sndvol] [ 14.850466] ALSA: control 'PCM Playback Switch'.
[ sndvol] [ 14.850649] ALSA: control 'PCM Playback Route'.
[ sndvol] [ 14.850835] ALSA: control 'IEC958 Playback Default'.
[ sndvol] [ 14.850983] ALSA: control 'IEC958 Playback Con Mask'.
[ sndvol] [ 14.851179] ALSA: control 'IEC958 Playback PCM Stream'.
[ sndvol] [ 14.851368] Inactive control IEC958 Playback PCM Stream'.
[ pfac] [ 14.853511] Process pid 663 terminated, status 00000000.
[ gm] [ 14.868171] modprobe sd_mod.
[ KERNEL] [ 14.870268] usbcore: registered new interface driver usb-storage
[ gm] [ 14.882935] Load EXFAT filesystem driver.
[ gm] [ 14.883183] modprobe fuse.
[ KERNEL] [ 14.901921] fuse init (API version 7.26)
[ gm] [ 14.901134] modprobe exfat.
[ KERNEL] [ 14.918586] exFAT: Version 1.2.9
[ gm] [ 14.969357] Run '/sbin/resolver 0x1c59d70 dns [rdp]', log '', env '', pid ''.
[ pfac] [ 14.969671] Run /sbin/resolver 0x1c59d70 dns [rdp].
[ gm] [ 14.969778] Everyone can control terminal by VNC.
[ gm] [ 14.969945] [VNC] Listener at port 5900.
[ pfac] [ 14.970311] Ok, PID 690.
[ pfac] [ 14.987095] Process pid 690 terminated, status 00000000.
[ gm] [ 14.987276] rdp => 192.168.3.111.
[ gm] [ 14.999603] Free ram before fork terminal client /sbin/rdpclient (session 1): 920068 Kb.
[ pfac] [ 14.999898] Run /sbin/rdpclient 1.
[ gm] [ 15.000145] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 15.000394] Ok, PID 691.
[ rdpclient 691] [ 15.011836] RDP Terminal Client, WTware 5.6.24/RPi, pipe 1, pid 691.
[ rdpclient 691] [ 15.012762] Use /lib/ui32.so.
[ rdpclient 691] [ 15.014916] Redirect sound.
[ rdpclient 691] [ 15.015552] Make RDP session with 192.168.3.111, port 3389.
[ rdpclient 691] [ 15.015894] No username.
[ rdpclient 691] [ 15.016249] No password.
[ rdpclient 691] [ 15.016532] No PIN.
[ rdpclient 691] [ 15.016790] No domain.
[ rdpclient 691] [ 15.017007] No shell.
[ rdpclient 691] [ 15.017244] No directory.
[ rdpclient 691] [ 15.017577] Window: 1920x1080@24.
[ rdpclient 691] [ 15.017899] PFlags 0x000000AE.
[ rdpclient 691] [ 15.018192] Keyboard 00000409:00000000.
[ rdpclient 691] [ 15.018457] My hostname "wt-168-1-186".
[ rdpclient 691] [ 15.018778] TCP: connecting to 192.168.3.111:3389.
[ rdpclient 691] [ 15.019056] TCP: connection with 192.168.3.111:3389 established.
[ rdpclient 691] [ 15.019319] Turn keepalive on.
[ rdpclient 691] [ 15.020214] Free ram after buffers allocation: 919276 KB.
[ rdpclient 691] [ 15.025187] Reconnect with TLS/SSL enabled.
[ rdpclient 691] [ 15.025678] TCP: reconnecting to 192.168.3.111:3389.
[ rdpclient 691] [ 15.026698] TCP: connection with 192.168.3.111:3389 established.
[ rdpclient 691] [ 15.027095] Turn keepalive on.
[ rdpclient 691] [ 15.030674] Server supports GFX Pipeline.
[ rdpclient 691] [ 15.031088] TLS.
[ rdpclient 691] [ 15.031260] SSL/TLS.
[ rdpclient 691] [ 15.079503] Enable font smoothing and Desktop Composition.
[ rdpclient 691] [ 15.081262] RDP4 encryption.
[ rdpclient 691] [ 15.229110] GFX codec.
[ rdpclient 691] [ 15.692472] Run 4 tile threads.
[ KERNEL] [ 16.839438] random: crng init done
[SYSLOG] <29>Feb 21 17:20:58 ntpdate[635]: step time server 192.168.0.1 offset -27844757.261463 sec
[ pfac] [ 19.977199] Process pid 635 terminated, status 00000000.
Home WTware diskless client.
[ initrd] [ 13.231323] [DHCP] WTPassword hash 3f9f2ea8e36aaeecfe82b1ba0e353683.
[ initrd] [ 13.315126] WTpassword empty.Re: DHCP Option 18 ignored?
naves
Something strange on SD. Reformat and reinstall wtware.
Thanks for answer.
I found the cause of the problem
I took the distribution ZIP (no Windows-utilities)
and copied files from the directory zip\wtware on the SD card
wtware\cmdline.txt file contains only the string
quiet
without a parameter
wtboot=mmc
With the new cmdline.txt file from setup distr everything works
quiet
without a parameter
wtboot=mmc
