WTware 5.6.18 - How to get Windows 2012
NicolasC
Post by NicolasC »
Hello everybody,
I installed WTware 5.6.18 on a Raspberry Pi 3 to connect to a RDS farm.
It works but it uses the WTware login screen when connecting to the RDS server.
I'd like to force use of Windows Server login screen.
How can I do that ?
Thanks in advance for your help.
Here is my config file :
keyboard=fr
clienthostname=wtw*IP1
display=1280x1024
domain=mydomain.com
graphic=f
resolution=1280x1024
server=myserver
timezone=Romance Standard Time
connection
Re: WTware 5.6.18 - How to get Windows 2012
Disable NLA on the server:
https://wtware.com/win/nla.html
