de-ch missing language parameter- RPi
duri3
Post by duri3 »
Sadly the parameter
language=de-ch, default
isn't working. WTware doesn't show a blue box with the selected Keyboard language. I tried with
language=fr-ch, default
and this seems to work, also shows a blue box in the lower right corner with the letters FR-CH.
http://ascii-table.com/keyboard.php/150G-1
Please can you add the de-ch language parameter?
Re: de-ch missing language parameter- RPi
http://pxe.ru/files/testing/201711092109.zip
language=de-ch,default
Does it work?
duri3
Post by duri3 »
First thank you for your really fast reply.
Sadly I can't update our RPI Terminal. We do boot wtware from sdcard. The configurator doesn't show the microSD card even after formating. I need just the wtware 5.1.9 Image so I can rewrite it on our sdcards.
best regards
Roland
duri3
Post by duri3 »
Nevermind I used another laptop to write the image and now it's working fine! Thank you so much!
Best regards
Roland
duri3 wrote:The configurator doesn't show the microSD card even after formating.
The configurator doesn't show the microSD card even with checkbox "Show all drives" ?
duri3
Post by duri3 »
Just for the record
No it didn't show on buildin SDreader on my HP Tower EliteDesk G1. But when I tried another HP Laptop it worked :D
