iTalc Integration
cody.duncan
iTalc Integration
Would it be a possibility to integrate with remote monitoring software like italc, or are there any plans to do so?
Re: iTalc Integration
1. Microsoft RDP server has remote control function to control user session remotely.
2. WTware has embedded VNC server: http://wtware.com/docs5/config.html#vnc
We have no plans to add third remote monitoring method.
cody.duncan
With a program like iTalc, you can display all the computers on one screen. Currently we use the VNC that is already on the system, but that requires us to open the session individually. Is there a method to display all the sessions at once and have them update every 5 seconds?
I also would like to do this. When using computers in a school setup this becomes very important. Especially in bigger classes. You have to keep your eyes on the kids.
Hi, I would be too interested in this solution... is something new in this, or it's no go for wtware?
thanks for answer.
thanks for answer.
Won't work for wtware in short time. And I still do not understand what is it (it's Veyon now, right?)
Hello, nothing has changed in running veyon on wtware? It would be an excellent choice for re schools.
