SSL] error:14094419:SSL routines:ssl3_read_bytes:tlsv1 alert access denied
derdanilo
Post by derdanilo »
This happens when trying to connect to any terminal from the pi 3.
When rebooting and trying it sometimes works.
I put some logs here. If you need more please let me know.
15-56-43-982| [        rdpsnd] [   15.651055] Caught signal SIGSEGV.
15-56-43-982| [          pfac] [   15.651940] Process pid 680 terminated, status 00000000.
15-56-43-982| [ rdpclient 683] [   17.521981] rdpclient-rdpsnd.cpp (  572): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
15-56-43-982| [ rdpclient 683] [   17.522109] rdpclient-vchans.cpp (   67): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
15-56-43-982| [ rdpclient 683] [   17.522194] Make RDP session with 192.168.1.35, port 3389.
15-56-43-982| [ rdpclient 683] [   17.522277]  Username: "Administrator".
15-56-43-982| [ rdpclient 683] [   17.522353]  No password.
15-56-43-982| [ rdpclient 683] [   17.522430]  No PIN.
15-56-43-982| [ rdpclient 683] [   17.522506]  Domain: "mydomain.lan".
15-56-43-982| [ rdpclient 683] [   17.522584]  No shell.
15-56-43-982| [ rdpclient 683] [   17.522680]  No directory.
15-56-43-982| [ rdpclient 683] [   17.522757]  Window: 1920x1080@24.
15-56-43-982| [ rdpclient 683] [   17.522835]  PFlags 0x00000181.
15-56-43-982| [ rdpclient 683] [   17.522911]  Keyboard 00000407:00000000.
15-56-43-982| [ rdpclient 683] [   17.522986]  My hostname "wtw-168-1-50".
15-56-43-982| [ rdpclient 683] [   17.523062] TCP: connecting to 192.168.1.35:3389.
15-56-43-982| [ rdpclient 683] [   17.523139] TCP: connection with 192.168.1.35:3389 established.
15-56-43-982| [ rdpclient 683] [   17.523217] Turn keepalive on.
15-56-43-982| [ rdpclient 683] [   17.524012] Free ram after buffers allocation: 921844 KB.
15-56-43-982| [ rdpclient 683] [   21.473635] Reconnect with CredSSP enabled.
15-56-43-982| [ rdpclient 683] [   21.473812] TCP: reconnecting to 192.168.1.35:3389.
15-56-43-982| [ rdpclient 683] [   21.474572] TCP: connection with 192.168.1.35:3389 established.
15-56-43-982| [ rdpclient 683] [   21.474679] Turn keepalive on.
15-56-43-982| [ rdpclient 683] [   21.477252] Server supports GFX Pipeline.
15-56-43-982| [ rdpclient 683] [   21.477436] CredSSP.
15-56-43-982| [ rdpclient 683] [   21.477514] SSL/TLS.
15-56-43-982| [ rdpclient 683] [   22.513016] SSL_ERROR_SSL
15-56-43-982| [ rdpclient 683] [   22.513165] [SSL] error:14094419:SSL routines:ssl3_read_bytes:tlsv1 alert access denied
15-56-43-982| [ rdpclient 683] [   22.513251] rdpclient-credssp.cpp (  146): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
15-56-43-982| [ rdpclient 683] [   22.513331] rdpclient-credssp.cpp (  196): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
15-56-43-982| [ rdpclient 683] [   22.513410] rdpclient-credssp.cpp (  324): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
15-56-43-982| [ rdpclient 683] [   22.513490] rdpclient-credssp.cpp (  656): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
15-56-43-982| [            gm] [   22.513572] Final message: CredSSP connection failed.
15-56-43-982| [ rdpclient 683] [   22.513622]    rdpclient-tcp.cpp (  533): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
15-56-43-982| [ rdpclient 683] [   22.513703] CredSSP connection failed.
15-56-43-982| [          pfac] [   22.535248] Process pid 683 terminated, status 00000009.
15-56-43-993| Connection from wtc.exe at 192.168.1.35.
Re: SSL] error:14094419:SSL routines:ssl3_read_bytes:tlsv1 alert access denied
...Remove all unneccesary lines from config...
...Reboot thin client...
...Make as few actions as possible to reproduce the error. Save log as soon as you see first error...
derdanilo
Post by derdanilo »
I could not reproduce the issue for now.
Please keep the threat open. I will report the log once it appears again.
