Time Zone and Daylight Saving Time
geefox
Post by geefox »
got a question regarding the Timezones and the Daylight Saving Time.
We are going to provide a multiple language terminalserver 2016 for users from austria, romania and so on.
Is it possible to set the Daylight Saving Time in the config.wtc? Because if i set the timezone to W. Europe Standard Time the clock on the terminalserver is wrong. It is 1 hour earlier as it should be. I think the problem is caused by the Daylight Saving Time.
Do you have any ideas how to deal with that?
Btw, the option "Allow time zone redirection" in the GPO is checked.
best regards
thomas
rmcarthur
Re: Time Zone and Daylight Saving Time
Post by rmcarthur »
We are experiencing the same issue. Mountain Standard Time UTC-7:00 and the time on the terimal server is wrong. One hour behind. Almost as if Daylight Savings Time is enabled. I currently have the time set to Saskatchewan Timezone because they do not have DST. This is only a hack fix... Need a viable solution. Any help would be appreciated.
Thank You,
Robert
Server should calculate DST automatically if client specifies right timezone information. I have just updated timezones. Please, try this build:
http://pxe.ru/files/testing/201710241441.zip
And send me a log if it is still wrong: https://wtware.com/logs.html
geefox
Post by geefox »
Sorry for my late response - thank you akatik for your work.
It is working properly at the moment, but it was my own fault - there was a missconfiguration in the config file, which leads to this behaviour.
From my point of view, this thread can be closed
rmcarthur
Post by rmcarthur »
akatik,
DST seems to be working with the new production image. 5.6.18. However, when selecting Mountain Standard Time. It saving Mexico time. This is an issue because MST and Mexico time do not have the same start and end for DST. We tested 5.6.16 and it is doing the same thing. A fix for this would be appreciated.
Thank you,
Robert
I can not make fix until I receive:
1. log: https://wtware.com/logs.html
2. right digits.
What time should I set on server to see the problem? What time should be on terminal and what you get now?
rmcarthur
Post by rmcarthur »
akatik,
When you set the time in the config file for Mountain Standard time it sets it to Chihauhua Mexico MST time which is also UTC/GMT -7 Hours... however DST Start is Apr 2, 2017 and End Oct 29, 2017 for this time zone. Where as Mountain Standard Time (Alberta) has a DST start time of Mar. 12, 2017 and End Nov 5, 2017. So currently the time on the terminal servers are correct... but they will not be once DST kicks in again. as they are offset by a week.
Here is my log file
13-46-37-476| WTware 5.6.16/RPi supervisor.
13-46-37-476| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0x0
13-46-37-476| [ KERNEL] [ 0.000000] Linux version 4.9.51 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #2 SMP Sat Sep 30 11:33:59 +04 2017
13-46-37-476| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
13-46-37-476| [ KERNEL] [ 0.000000] CPU: div instructions available: patching division code
13-46-37-476| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
13-46-37-476| [ KERNEL] [ 0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
13-46-37-476| [ KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
13-46-37-476| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
13-46-37-476| [ KERNEL] [ 0.000000] On node 0 totalpages: 242688
13-46-37-476| [ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80b22cc0, node_mem_map ba3a1000
13-46-37-476| [ KERNEL] [ 0.000000] Normal zone: 2133 pages used for memmap
13-46-37-476| [ KERNEL] [ 0.000000] Normal zone: 0 pages reserved
13-46-37-476| [ KERNEL] [ 0.000000] Normal zone: 242688 pages, LIFO batch:31
13-46-37-476| [ KERNEL] [ 0.000000] percpu: Embedded 11 pages/cpu @ba367000 s16076 r8192 d20788 u45056
13-46-37-476| [ KERNEL] [ 0.000000] pcpu-alloc: s16076 r8192 d20788 u45056 alloc=11*4096
13-46-37-476| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
13-46-37-476| [ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 240555
13-46-37-476| [ KERNEL] [ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1680 bcm2708_fb.fbheight=1050 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 quiet wtboot=mmc
13-46-37-476| [ KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
13-46-37-476| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
13-46-37-476| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
13-46-37-476| [ KERNEL] [ 0.000000] Memory: 942176K/970752K available (5120K kernel code, 143K rwdata, 920K rodata, 4096K init, 373K bss, 20384K reserved, 8192K cma-reserved)
13-46-37-476| [ KERNEL] [ 0.000000] Virtual kernel memory layout:
13-46-37-476| [ KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
13-46-37-476| [ KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
13-46-37-476| [ KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
13-46-37-476| [ KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
13-46-37-476| [ KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
13-46-37-476| [ KERNEL] [ 0.000000] .text : 0x80008000 - 0x80600000 (6112 kB)
13-46-37-476| [ KERNEL] [ 0.000000] .init : 0x80700000 - 0x80b00000 (4096 kB)
13-46-37-476| [ KERNEL] [ 0.000000] .data : 0x80b00000 - 0x80b23f78 ( 144 kB)
13-46-37-476| [ KERNEL] [ 0.000000] .bss : 0x80b25000 - 0x80b826a0 ( 374 kB)
13-46-37-476| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
13-46-37-476| [ KERNEL] [ 0.000000] Hierarchical RCU implementation.
13-46-37-476| [ KERNEL] [ 0.000000] Build-time adjustment of leaf fanout to 32.
13-46-37-476| [ KERNEL] [ 0.000000] NR_IRQS:16 nr_irqs:16 16
13-46-37-476| [ KERNEL] [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
13-46-37-476| [ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
13-46-37-476| [ KERNEL] [ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
13-46-37-476| [ KERNEL] [ 0.000017] Switching to timer-based delay loop, resolution 52ns
13-46-37-476| [ KERNEL] [ 0.000212] Console: colour dummy device 80x30
13-46-37-476| [ KERNEL] [ 0.000226] console [tty0] enabled
13-46-37-476| [ KERNEL] [ 0.000241] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
13-46-37-476| [ KERNEL] [ 0.000255] pid_max: default: 32768 minimum: 301
13-46-37-476| [ KERNEL] [ 0.000387] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
13-46-37-476| [ KERNEL] [ 0.000394] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
13-46-37-476| [ KERNEL] [ 0.001236] Disabling memory control group subsystem
13-46-37-476| [ KERNEL] [ 0.001288] CPU: Testing write buffer coherency: ok
13-46-37-476| [ KERNEL] [ 0.001624] CPU0: update cpu_capacity 1024
13-46-37-476| [ KERNEL] [ 0.001631] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
13-46-37-476| [ KERNEL] [ 0.001656] Setting up static identity map for 0x100000 - 0x100034
13-46-37-476| [ KERNEL] [ 0.003147] CPU1: update cpu_capacity 1024
13-46-37-476| [ KERNEL] [ 0.003153] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
13-46-37-476| [ KERNEL] [ 0.003706] CPU2: update cpu_capacity 1024
13-46-37-476| [ KERNEL] [ 0.003712] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
13-46-37-476| [ KERNEL] [ 0.004261] CPU3: update cpu_capacity 1024
13-46-37-476| [ KERNEL] [ 0.004267] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
13-46-37-476| [ KERNEL] [ 0.004344] Brought up 4 CPUs
13-46-37-476| [ KERNEL] [ 0.004353] SMP: Total of 4 processors activated (153.60 BogoMIPS).
13-46-37-476| [ KERNEL] [ 0.004357] CPU: All CPU(s) started in HYP mode.
13-46-37-476| [ KERNEL] [ 0.004360] CPU: Virtualization extensions available.
13-46-37-476| [ KERNEL] [ 0.004892] devtmpfs: initialized
13-46-37-476| [ KERNEL] [ 0.014476] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
13-46-37-476| [ KERNEL] [ 0.014856] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
13-46-37-476| [ KERNEL] [ 0.014872] futex hash table entries: 1024 (order: 4, 65536 bytes)
13-46-37-476| [ KERNEL] [ 0.015346] pinctrl core: initialized pinctrl subsystem
13-46-37-476| [ KERNEL] [ 0.015872] NET: Registered protocol family 16
13-46-37-476| [ KERNEL] [ 0.017700] DMA: preallocated 1024 KiB pool for atomic coherent allocations
13-46-37-476| [ KERNEL] [ 0.027865] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
13-46-37-476| [ KERNEL] [ 0.111185] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
13-46-37-476| [ KERNEL] [ 0.113531] usbcore: registered new interface driver usbfs
13-46-37-476| [ KERNEL] [ 0.113656] usbcore: registered new interface driver hub
13-46-37-476| [ KERNEL] [ 0.113740] usbcore: registered new device driver usb
13-46-37-476| [ KERNEL] [ 0.120159] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-09-12 15:21
13-46-37-476| [ KERNEL] [ 0.122432] clocksource: Switched to clocksource arch_sys_counter
13-46-37-476| [ KERNEL] [ 0.137186] NET: Registered protocol family 2
13-46-37-476| [ KERNEL] [ 0.137754] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
13-46-37-476| [ KERNEL] [ 0.137861] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
13-46-37-476| [ KERNEL] [ 0.138045] TCP: Hash tables configured (established 8192 bind 8192)
13-46-37-476| [ KERNEL] [ 0.138132] UDP hash table entries: 512 (order: 2, 16384 bytes)
13-46-37-476| [ KERNEL] [ 0.138173] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
13-46-37-476| [ KERNEL] [ 0.138352] NET: Registered protocol family 1
13-46-37-476| [ KERNEL] [ 2.241020] workingset: timestamp_bits=14 max_order=18 bucket_order=4
13-46-37-476| [ KERNEL] [ 2.276447] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
13-46-37-476| [ KERNEL] [ 2.276460] io scheduler noop registered
13-46-37-476| [ KERNEL] [ 2.276465] io scheduler deadline registered (default)
13-46-37-476| [ KERNEL] [ 2.286262] BCM2708FB: allocated DMA memory fad10000
13-46-37-476| [ KERNEL] [ 2.286314] BCM2708FB: allocated DMA channel 0 @ bb80f000
13-46-37-476| [ KERNEL] [ 2.336347] Console: switching to colour frame buffer device 210x65
13-46-37-476| [ KERNEL] [ 2.368563] bcm2835-rng 3f104000.rng: hwrng registered
13-46-37-476| [ KERNEL] [ 2.368731] vc-cma: Videocore CMA driver
13-46-37-476| [ KERNEL] [ 2.368742] vc-cma: vc_cma_base = 0x00000000
13-46-37-476| [ KERNEL] [ 2.368758] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
13-46-37-476| [ KERNEL] [ 2.368773] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
13-46-37-476| [ KERNEL] [ 2.369136] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
13-46-37-476| [ KERNEL] [ 2.369932] vc-sm: Videocore shared memory driver
13-46-37-476| [ KERNEL] [ 2.374076] zram: Added device: zram0
13-46-37-476| [ KERNEL] [ 2.374144] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
13-46-37-476| [ KERNEL] [ 2.602258] Core Release: 2.80a
13-46-37-476| [ KERNEL] [ 2.602267] Setting default values for core params
13-46-37-476| [ KERNEL] [ 2.602294] Finished setting default values for core params
13-46-37-476| [ KERNEL] [ 2.802676] Using Buffer DMA mode
13-46-37-476| [ KERNEL] [ 2.802681] Periodic Transfer Interrupt Enhancement - disabled
13-46-37-476| [ KERNEL] [ 2.802685] Multiprocessor Interrupt Enhancement - disabled
13-46-37-476| [ KERNEL] [ 2.802692] OTG VER PARAM: 0, OTG VER FLAG: 0
13-46-37-476| [ KERNEL] [ 2.802717] Dedicated Tx FIFOs mode
13-46-37-476| [ KERNEL] [ 2.803234] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
13-46-37-476| [ KERNEL] [ 2.803261] FIQ FSM acceleration enabled for :
13-46-37-476| [ KERNEL] [ 2.803261] Non-periodic Split Transactions
13-46-37-476| [ KERNEL] [ 2.803261] Periodic Split Transactions
13-46-37-476| [ KERNEL] [ 2.803261] High-Speed Isochronous Endpoints
13-46-37-476| [ KERNEL] [ 2.803261] Interrupt/Control Split Transaction hack enabled
13-46-37-476| [ KERNEL] [ 2.803267] dwc_otg: Microframe scheduler enabled
13-46-37-476| [ KERNEL] [ 2.803309] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80398974
13-46-37-476| [ KERNEL] [ 2.803318] WARN::hcd_init_fiq:460: FIQ ASM at 0x80398cd8 length 36
13-46-37-476| [ KERNEL] [ 2.803327] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
13-46-37-476| [ KERNEL] [ 2.803383] dwc_otg 3f980000.usb: DWC OTG Controller
13-46-37-476| [ KERNEL] [ 2.803416] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
13-46-37-476| [ KERNEL] [ 2.803446] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
13-46-37-476| [ KERNEL] [ 2.803490] Init: Port Power? op_state=1
13-46-37-476| [ KERNEL] [ 2.803494] Init: Power Port (0)
13-46-37-476| [ KERNEL] [ 2.803673] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
13-46-37-476| [ KERNEL] [ 2.803682] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
13-46-37-476| [ KERNEL] [ 2.803690] usb usb1: Product: DWC OTG Controller
13-46-37-476| [ KERNEL] [ 2.803697] usb usb1: Manufacturer: Linux 4.9.51 dwc_otg_hcd
13-46-37-476| [ KERNEL] [ 2.803703] usb usb1: SerialNumber: 3f980000.usb
13-46-37-476| [ KERNEL] [ 2.804438] hub 1-0:1.0: USB hub found
13-46-37-476| [ KERNEL] [ 2.804476] hub 1-0:1.0: 1 port detected
13-46-37-476| [ KERNEL] [ 2.805146] dwc_otg: FIQ enabled
13-46-37-476| [ KERNEL] [ 2.805150] dwc_otg: NAK holdoff enabled
13-46-37-476| [ KERNEL] [ 2.805153] dwc_otg: FIQ split-transaction FSM enabled
13-46-37-476| [ KERNEL] [ 2.805167] Module dwc_common_port init
13-46-37-476| [ KERNEL] [ 2.805549] usbcore: registered new interface driver usbtouchscreen
13-46-37-476| [ KERNEL] [ 2.807044] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
13-46-37-476| [ KERNEL] [ 2.807487] bcm2835-cpufreq: min=600000 max=1200000
13-46-37-476| [ KERNEL] [ 2.808578] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
13-46-37-476| [ KERNEL] [ 2.811056] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
13-46-37-476| [ KERNEL] [ 2.813525] ledtrig-cpu: registered to indicate activity on CPUs
13-46-37-476| [ KERNEL] [ 2.813680] hidraw: raw HID events driver (C) Jiri Kosina
13-46-37-476| [ KERNEL] [ 2.814487] usbcore: registered new interface driver usbhid
13-46-37-476| [ KERNEL] [ 2.814492] usbhid: USB HID core driver
13-46-37-476| [ KERNEL] [ 2.815620] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
13-46-37-476| [ KERNEL] [ 2.822874] [vc_sm_connected_init]: start
13-46-37-476| [ KERNEL] [ 2.830428] [vc_sm_connected_init]: end - returning 0
13-46-37-476| [ KERNEL] [ 2.830720] NET: Registered protocol family 17
13-46-37-476| [ KERNEL] [ 2.830848] Registering SWP/SWPB emulation handler
13-46-37-476| [ KERNEL] [ 2.831426] registered taskstats version 1
13-46-37-476| [ KERNEL] [ 2.835651] sdhost: log_buf @ bad07000 (fad07000)
13-46-37-476| [ KERNEL] [ 2.922449] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
13-46-37-476| [ KERNEL] [ 2.924579] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
13-46-37-476| [ KERNEL] [ 2.924582] mmc-bcm2835 3f300000.mmc: DMA channel allocated
13-46-37-476| [ KERNEL] [ 2.982490] of_cfs_init
13-46-37-476| [ KERNEL] [ 2.982557] of_cfs_init: OK
13-46-37-476| [ KERNEL] [ 2.992798] Freeing unused kernel memory: 4096K
13-46-37-476| [ KERNEL] [ 3.012281] mmc0: host does not support reading read-only switch, assuming write-enable
13-46-37-476| [ KERNEL] [ 3.014214] mmc0: new high speed SDHC card at address 1234
13-46-37-476| [ KERNEL] [ 3.014674] mmcblk0: mmc0:1234 SA08G 7.25 GiB
13-46-37-476| [ KERNEL] [ 3.017093] mmcblk0: p1
13-46-37-476| [ KERNEL] [ 3.021761] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
13-46-37-476| [ KERNEL] [ 3.024157] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
13-46-37-476| [ KERNEL] [ 3.025650] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
13-46-37-476| [ KERNEL] [ 3.028323] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
13-46-37-476| [ KERNEL] [ 3.032543] Indeed it is in host mode hprt0 = 00021501
13-46-37-476| [ KERNEL] [ 3.105187] random: fast init done
13-46-37-476| [ KERNEL] [ 3.176058] mmc1: new high speed SDIO card at address 0001
13-46-37-476| [ KERNEL] [ 3.232476] usb 1-1: new high-speed USB device number 2 using dwc_otg
13-46-37-476| [ KERNEL] [ 3.232613] Indeed it is in host mode hprt0 = 00001101
13-46-37-476| [ hotplug] [ 3.275881] Block device 254:0. No action.
13-46-37-476| [ hotplug] [ 3.316830] Block device 179:0. No action.
13-46-37-476| [ hotplug] [ 3.316957] Block device 179:1. No action.
13-46-37-476| [ pfac] [ 3.321180] Run /sbin/initrd.
13-46-37-476| [ pfac] [ 3.321674] Ok, PID 608.
13-46-37-476| [ initrd] [ 3.324805] WTware shell 5.6.16/RPi
13-46-37-476| [ initrd] [ 3.362728] HDD/MMC/SD boot.
13-46-37-476| [ KERNEL] [ 3.462705] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
13-46-37-476| [ KERNEL] [ 3.462716] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
13-46-37-476| [ KERNEL] [ 3.463452] hub 1-1:1.0: USB hub found
13-46-37-476| [ KERNEL] [ 3.463543] hub 1-1:1.0: 5 ports detected
13-46-37-476| [ KERNEL] [ 3.782465] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
13-46-37-476| [ KERNEL] [ 3.912681] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
13-46-37-476| [ KERNEL] [ 3.912691] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
13-46-37-476| [ KERNEL] [ 4.012462] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
13-46-37-476| [ KERNEL] [ 4.166728] usb 1-1.3: New USB device found, idVendor=045e, idProduct=0752
13-46-37-476| [ KERNEL] [ 4.166739] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
13-46-37-476| [ KERNEL] [ 4.166747] usb 1-1.3: Product: Wired Keyboard 400
13-46-37-476| [ KERNEL] [ 4.166754] usb 1-1.3: Manufacturer: Microsoft
13-46-37-476| [ KERNEL] [ 4.182596] input: Microsoft Wired Keyboard 400 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:045E:0752.0001/input/input0
13-46-37-476| [ KERNEL] [ 4.253614] hid-generic 0003:045E:0752.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Wired Keyboard 400] on usb-3f980000.usb-1.3/input0
13-46-37-476| [ KERNEL] [ 4.362460] usb 1-1.5: new low-speed USB device number 5 using dwc_otg
13-46-37-476| [ initrd] [ 4.416611] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
13-46-37-476| /--- FILE "/bootmedia/config.txt" -----------------------
13-46-37-476| | # For more options and information see
13-46-37-476| | # http://www.raspberrypi.org/documentatio ... fig-txt.md
13-46-37-476| | # Some settings may impact device functionality. See link above for details
13-46-37-476| | # Uncomment if you get no picture on HDMI for a default "safe" mode.
13-46-37-476| | #hdmi_safe=1
13-46-37-476| | # Uncomment this if your display has a black border of unused pixels visible
13-46-37-476| | # and your display can output without overscan.
13-46-37-476| | disable_overscan=1
13-46-37-476| | # Uncomment if hdmi display is not detected and composite is being output.
13-46-37-476| | #hdmi_force_hotplug=1
13-46-37-476| | # Uncomment to force a specific HDMI mode (this will force VGA).
13-46-37-476| | #hdmi_group=1
13-46-37-476| | #hdmi_mode=1
13-46-37-476| | # Force the monitor to HDMI mode so that sound will be sent over HDMI cable.
13-46-37-476| | #hdmi_drive=2
13-46-37-476| | # Uncomment to increase signal to HDMI, if you have interference, blanking, or
13-46-37-476| | # no display.
13-46-37-476| | #config_hdmi_boost=4
13-46-37-476| | # Uncomment to overclock the arm. 700 MHz is the default.
13-46-37-476| | #arm_freq=800
13-46-37-476| | disable_splash=1
13-46-37-476| | #hdmi_group=2
13-46-37-476| | # 800x600: hdmi_mode=9
13-46-37-476| | # 1024x768: hdmi_mode=16
13-46-37-476| | # 1280x1024: hdmi_mode=35
13-46-37-476| | # 1360x768: hdmi_mode=39
13-46-37-476| | # 1400x1050: hdmi_mode=42
13-46-37-476| | # 1440x900: hdmi_mode=47
13-46-37-476| | # 1600x1200: hdmi_mode=51
13-46-37-476| | # 1680x1050: hdmi_mode=58
13-46-37-476| | # 1366x768: hdmi_mode=81
13-46-37-476| | # 1920x1080: hdmi_mode=82
13-46-37-476| | # 1920x1200: hdmi_mode=69
13-46-37-476| | framebuffer_depth=32
13-46-37-476| | # Uncomment for 16-bit color. It is up to two
13-46-37-476| | # times faster than default 32-bit.
13-46-37-476| | #framebuffer_depth=16
13-46-37-476| | # Enable onboard audio (HDMI or jack).
13-46-37-476| | dtparam=audio=on
13-46-37-476| | # Removes the warning overlay.
13-46-37-476| | #avoid_warnings=1
13-46-37-476| | # Additionally allows turbo when low-voltage is present.
13-46-37-476| | #avoid_warnings=2
13-46-37-476| \----------------------------------------------------
13-46-37-476| [ initrd] [ 4.423295] WTpassword empty.
13-46-37-476| [ KERNEL] [ 4.508242] usb 1-1.5: New USB device found, idVendor=045e, idProduct=00cb
13-46-37-476| [ KERNEL] [ 4.508255] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
13-46-37-476| [ KERNEL] [ 4.508263] usb 1-1.5: Product: Microsoft Basic Optical Mouse v2.0
13-46-37-476| [ KERNEL] [ 4.508270] usb 1-1.5: Manufacturer: Microsoft
13-46-37-476| [ KERNEL] [ 4.514412] input: Microsoft Microsoft Basic Optical Mouse v2.0 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:045E:00CB.0002/input/input1
13-46-37-476| [ KERNEL] [ 4.514935] hid-generic 0003:045E:00CB.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft Basic Optical Mouse v2.0 ] on usb-3f980000.usb-1.5/input0
13-46-37-476| [ initrd] [ 5.861017] Start Setup.
13-46-37-476| [ KERNEL] [ 6.542473] usb 1-1.4: new high-speed USB device number 6 using dwc_otg
13-46-37-476| [ KERNEL] [ 6.674259] usb 1-1.4: New USB device found, idVendor=05e3, idProduct=0718
13-46-37-476| [ KERNEL] [ 6.674270] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=2
13-46-37-476| [ KERNEL] [ 6.674277] usb 1-1.4: Product: USB Storage
13-46-37-476| [ KERNEL] [ 6.674284] usb 1-1.4: SerialNumber: 000000000033
13-46-37-476| [ KERNEL] [ 11.488261] random: crng init done
13-46-37-476| [ initrd] [ 17.734342] Remount /bootmedia for writing.
13-46-37-476| [ initrd] [ 17.739121] Remount /bootmedia as read-only.
13-46-37-476| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
13-46-37-476| | [BOM]
13-46-37-476| | netmedia=ethernet
13-46-37-476| | config=http
13-46-37-476| | clientIP=*
13-46-37-476| | tftpPrefix=/wtware/
13-46-37-476| | tftpIP=10.100.100.205
13-46-37-476| | setupPassword=18862e06e06b9d82cd02237a2bb694f1
13-46-37-476| [ initrd] [ 27.614879] Load ethernet drivers.
13-46-37-476| [ initrd] [ 27.614967] modprobe smsc95xx.
13-46-37-476| [ KERNEL] [ 27.624736] smsc95xx v1.0.5
13-46-37-476| [ KERNEL] [ 27.715970] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2e:e7:d7
13-46-37-476| [ KERNEL] [ 27.716245] usbcore: registered new interface driver smsc95xx
13-46-37-476| [ KERNEL] [ 27.804231] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
13-46-37-476| [ KERNEL] [ 29.271742] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
13-46-37-476| [ initrd] [ 29.304886] Download configs from HTTP 10.100.100.205 port 789 prefix '/wtware/'.
13-46-37-476| [ initrd] [ 29.304975] WTpassword present: 18862e06e06b9d82cd02237a2bb694f1.
13-46-37-476| [ initrd] [ 30.510143] dhcp: 331 bytes from 10.100.111.1.
13-46-37-476| [ initrd] [ 30.510242] 00000000:0000013700000000001100000A646F010A646F0F004300440137000002010600 ...7........do..do..C.D.7......
13-46-37-476| [ initrd] [ 30.510313] 00000020:67458B6B00000000000000000A646F0F0A6464F50A646F01B827EB2EE7D70000 gE.k.........do..dd..do..'......
13-46-37-476| [ initrd] [ 30.510382] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 30.510450] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 30.510518] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 30.510586] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 30.510656] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 30.510745] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 32.760169] dhcp: 331 bytes from 10.100.111.1.
13-46-37-476| [ initrd] [ 32.760299] 00000000:0000013700000000001100000A646F010A646F0F004300440137000002010600 ...7........do..do..C.D.7......
13-46-37-476| [ initrd] [ 32.760373] 00000020:67458B6B00000000000000000A646F0F000000000A646F01B827EB2EE7D70000 gE.k.........do......do..'......
13-46-37-476| [ initrd] [ 32.760443] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 32.760511] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 32.760581] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 32.760648] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 32.760716] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 32.760783] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
13-46-37-476| [ initrd] [ 32.800093] dhcp: server address 10.100.100.245.
13-46-37-476| [ initrd] [ 32.800166] dhcp: 10.100.111.15/255.255.255.0.
13-46-37-476| [ initrd] [ 32.800236] dhcp: default gateway 10.100.111.1.
13-46-37-476| [ initrd] [ 32.800302] dhcp: DNS 10.100.100.225.
13-46-37-476| [ initrd] [ 32.800368] dhcp: domain SC.SCDGROUP.CA.
13-46-37-476| [ initrd] [ 32.800434] HTTP IP 10.100.100.205 already specified.
13-46-37-476| WTC listener is active.
13-46-37-476| WTC broadcast listener is active.
13-46-37-476| Send broadcast WTCU discover.
13-46-37-476| [ pfac] [ 32.802235] Run /sbin/httpd.
13-46-37-476| [ initrd] [ 32.802289] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
13-46-37-476| [ pfac] [ 32.802381] Ok, PID 652.
13-46-37-476| [ httpd] [ 32.807599] HTTP Server, WTware 5.6.16/RPi
13-46-37-476| [ initrd] [ 32.926864] USB: 045e:00cb Microsoft Corp. Basic Optical Mouse v2.0.
13-46-37-476| [ initrd] [ 32.927007] USB: 045e:0752 Microsoft Corp. Wired Keyboard 400.
13-46-37-476| [ initrd] [ 32.927082] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
13-46-37-476| [ initrd] [ 32.927201] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
13-46-37-476| [ initrd] [ 32.927290] USB: 05e3:0718 Genesys Logic, Inc. IDE/SATA Adapter.
13-46-37-476| [ initrd] [ 32.927364] [HTTP] Download config file /wtware/Everyone/list.wtc from 10.100.100.205.
13-46-37-476| [ initrd] [ 32.934498] [HTTP] Download config file /wtware/Terminals/B8.27.EB.2E.E7.D7/config.wtc from 10.100.100.205.
13-46-37-476| /--- FILE "/tmp/config.wtc" -----------------------
13-46-37-476| | server=gateway.scdgroup.ca
13-46-37-476| | loadbalanceinfo=tsv://MS Terminal Services Plugin.1.RDPCollection
13-46-37-476| | turnoffmenu=always
13-46-37-476| | clienthostname=fl2*IP3
13-46-37-476| | vnc=on
13-46-37-476| | vnc_password=
13-46-37-476| | ask_password=on
13-46-37-476| | timezone=Mountain Standard Time
13-46-37-476| | connection
13-46-37-476| [ initrd] [ 32.938027] [HTTP] Download config file /wtware/Everyone/all.wtc from 10.100.100.205.
13-46-37-476| /--- FILE "/tmp/all.wtc" -----------------------
13-46-37-476| | server=10.100.100.205
13-46-37-476| [ initrd] [ 32.941499] Remount /bootmedia for writing.
13-46-37-476| [ initrd] [ 32.948768] Remount /bootmedia as read-only.
13-46-37-476| /--- FILE "/etc/config.compiled" -----------------------
13-46-37-476| [ initrd] [ 33.037890] Hostname: "fl2-100-111-15".
13-46-37-476| Everyone can control terminal by RSH.
13-46-37-476| RSH: listener is active.
13-46-37-476| [ httpd] [ 33.280325] Reread settings.
13-46-37-476| [ httpd] [ 33.280474] Everyone can control terminal by HTTP.
13-46-37-476| [ gm] [ 33.280524] WTware session manager 5.6.16/RPi.
13-46-37-476| [ gm] [ 33.350127] EV_REL flag found. Add mouse event1: Microsoft Microsoft Basic Optical Mouse v2.0 .
13-46-37-476| [ gm] [ 33.350218] Add keyboard event0: Microsoft Wired Keyboard 400.
13-46-37-476| [ gm] [ 33.350373] Display mode: 1680x1050, 32 bit, 0 Hz, modeline "", DDC enabled, connector 0.
13-46-37-476| [ gm] [ 33.379818] Framebuffer device found.
13-46-37-476| [ gm] [ 33.379902] LINELENBYTES 6720
13-46-37-476| [ gm] [ 33.379980] VLEN 7056000
13-46-37-476| [ gm] [ 33.410342] Use /lib/ui32.so.
13-46-37-476| [ gm] [ 33.500624] Run '/sbin/resolver 0x109fe08 dns [gateway.scdgroup.ca]', log '', env '', pid ''.
13-46-37-476| [ pfac] [ 33.500778] Run /sbin/resolver 0x109fe08 dns [gateway.scdgroup.ca].
13-46-37-476| [ gm] [ 33.500828] Everyone can control terminal by VNC.
13-46-37-476| [ gm] [ 33.500914] [VNC] Listener at port 5900.
13-46-37-476| [ pfac] [ 33.501075] Ok, PID 653.
13-46-37-476| [ pfac] [ 33.510234] Process pid 653 terminated, status 00000000.
13-46-37-476| [ gm] [ 33.510989] gateway.scdgroup.ca => 10.100.100.244.
13-46-37-476| [ gm] [ 64.141192] Free ram before fork terminal client /sbin/rdpclient (session 1): 927672 Kb.
13-46-37-476| [ pfac] [ 64.141357] Run /sbin/rdpclient 1.
13-46-37-476| [ gm] [ 64.141407] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
13-46-37-476| [ pfac] [ 64.141633] Ok, PID 654.
13-46-37-476| [ rdpclient 654] [ 64.149054] RDP Terminal Client, WTware 5.6.16/RPi, pipe 1, pid 654.
13-46-37-476| [ rdpclient 654] [ 64.149946] Use /lib/ui32.so.
13-46-37-476| [ rdpclient 654] [ 64.151282] Make RDP session with 10.100.100.244, port 3389.
13-46-37-476| [ rdpclient 654] [ 64.151479] Username: "foamline2lh".
13-46-37-476| [ rdpclient 654] [ 64.151566] Password: present.
13-46-37-476| [ rdpclient 654] [ 64.151657] No PIN.
13-46-37-476| [ rdpclient 654] [ 64.151735] No domain.
13-46-37-476| [ rdpclient 654] [ 64.151812] No shell.
13-46-37-476| [ rdpclient 654] [ 64.151886] No directory.
13-46-37-476| [ rdpclient 654] [ 64.151963] Window: 1680x1050@24.
13-46-37-476| [ rdpclient 654] [ 64.152053] PFlags 0x0000002F.
13-46-37-476| [ rdpclient 654] [ 64.152126] Keyboard 00000409:00000000.
13-46-37-476| [ rdpclient 654] [ 64.152205] My hostname "fl2-100-111-15".
13-46-37-476| [ rdpclient 654] [ 64.152295] TCP: connecting to 10.100.100.244:3389.
13-46-37-476| [ rdpclient 654] [ 64.152469] TCP: connection with 10.100.100.244:3389 established.
13-46-37-476| [ rdpclient 654] [ 64.152563] Turn keepalive on.
13-46-37-476| [ rdpclient 654] [ 64.153999] Free ram after buffers allocation: 926880 KB.
13-46-37-476| [ rdpclient 654] [ 64.154253] Use Balance Info 49 bytes: 'tsv://MS Terminal Services Plugin.1.RDPCollection'.
13-46-37-476| [ rdpclient 654] [ 64.157193] Reconnect with CredSSP enabled.
13-46-37-476| [ rdpclient 654] [ 64.157443] TCP: reconnecting to 10.100.100.244:3389.
13-46-37-476| [ rdpclient 654] [ 64.158124] TCP: connection with 10.100.100.244:3389 established.
13-46-37-476| [ rdpclient 654] [ 64.158254] Turn keepalive on.
13-46-37-476| [ rdpclient 654] [ 64.158333] Use Balance Info 49 bytes: 'tsv://MS Terminal Services Plugin.1.RDPCollection'.
13-46-37-476| [ rdpclient 654] [ 64.160765] Server supports GFX Pipeline.
13-46-37-476| [ rdpclient 654] [ 64.160923] CredSSP.
13-46-37-476| [ rdpclient 654] [ 64.161000] SSL/TLS.
13-46-37-476| [ rdpclient 654] [ 64.383195] Timezone '(UTC-07:00) Chihuahua, La Paz, Mazatlan'.
13-46-37-476| [ rdpclient 654] [ 64.383355] Enable font smoothing and Desktop Composition.
13-46-37-476| [ rdpclient 654] [ 64.397917] TS_STATUS_FINDING_DESTINATION
13-46-37-476| [ rdpclient 654] [ 64.402176] TS_STATUS_LOADING_DESTINATION
13-46-37-476| [ rdpclient 654] [ 64.402368] TS_STATUS_REDIRECTING_TO_DESTINATION
13-46-37-476| [ rdpclient 654] [ 64.409587] TS_STATUS_BRINGING_SESSION_ONLINE
13-46-37-476| [ rdpclient 654] [ 64.426944] Server Redirection flags 0x00000b0d.
13-46-37-476| [ rdpclient 654] [ 64.427029] Server 10.100.100.238.
13-46-37-476| [ rdpclient 654] [ 64.427107] User "foamline2lh".
13-46-37-476| [ gm] [ 64.427183] TSClient (sessionId 1, pid 654) gracefully end.
13-46-37-476| [ rdpclient 654] [ 64.427228] Domain "SC".
13-46-37-476| [ rdpclient 654] [ 64.427302] Send Disconnect Provider Ultimatum.
13-46-37-476| [ gm] [ 64.427579] Free ram before fork terminal client /sbin/rdpclient (session 2): 926756 Kb.
13-46-37-476| [ pfac] [ 64.427713] Run /sbin/rdpclient 2.
13-46-37-476| [ gm] [ 64.427760] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
13-46-37-476| [ pfac] [ 64.428346] Ok, PID 655.
13-46-37-476| [ pfac] [ 64.428824] Process pid 654 terminated, status 00000009.
13-46-37-476| [ rdpclient 655] [ 64.435543] RDP Terminal Client, WTware 5.6.16/RPi, pipe 2, pid 655.
13-46-37-476| [ rdpclient 655] [ 64.436373] Use /lib/ui32.so.
13-46-37-476| [ rdpclient 655] [ 64.437154] Make RDP session with 10.100.100.238, port 3389.
13-46-37-476| [ rdpclient 655] [ 64.437253] Username: "foamline2lh".
13-46-37-476| [ rdpclient 655] [ 64.437332] Password: present.
13-46-37-476| [ rdpclient 655] [ 64.437407] No PIN.
13-46-37-476| [ rdpclient 655] [ 64.437484] Domain: "SC".
13-46-37-476| [ rdpclient 655] [ 64.437558] No shell.
13-46-37-476| [ rdpclient 655] [ 64.437634] No directory.
13-46-37-476| [ rdpclient 655] [ 64.437712] Window: 1680x1050@24.
13-46-37-476| [ rdpclient 655] [ 64.437792] PFlags 0x0000002F.
13-46-37-476| [ rdpclient 655] [ 64.437865] Keyboard 00000409:00000000.
13-46-37-476| [ rdpclient 655] [ 64.437944] My hostname "fl2-100-111-15".
13-46-37-476| [ rdpclient 655] [ 64.438018] TCP: connecting to 10.100.100.238:3389.
13-46-37-476| [ rdpclient 655] [ 64.438097] TCP: connection with 10.100.100.238:3389 established.
13-46-37-476| [ rdpclient 655] [ 64.438174] Turn keepalive on.
13-46-37-476| [ rdpclient 655] [ 64.438926] Free ram after buffers allocation: 926364 KB.
13-46-37-476| [ rdpclient 655] [ 64.439021] Empty Balance Info.
13-46-37-476| [ rdpclient 655] [ 64.441549] Reconnect with CredSSP enabled.
13-46-37-476| [ rdpclient 655] [ 64.441639] TCP: reconnecting to 10.100.100.238:3389.
13-46-37-476| [ rdpclient 655] [ 64.442194] TCP: connection with 10.100.100.238:3389 established.
13-46-37-476| [ rdpclient 655] [ 64.442277] Turn keepalive on.
13-46-37-476| [ rdpclient 655] [ 64.442352] Empty Balance Info.
13-46-37-476| [ rdpclient 655] [ 64.444095] Server supports GFX Pipeline.
13-46-37-476| [ rdpclient 655] [ 64.444201] CredSSP.
13-46-37-476| [ rdpclient 655] [ 64.444282] SSL/TLS.
13-46-37-476| [ rdpclient 655] [ 64.586614] Redirected Session ID 0x00000000.
13-46-37-476| [ rdpclient 655] [ 64.593422] Timezone '(UTC-07:00) Chihuahua, La Paz, Mazatlan'.
13-46-37-476| [ rdpclient 655] [ 64.593521] Enable font smoothing and Desktop Composition.
13-46-37-476| [ rdpclient 655] [ 64.595876] RDP5 encryption (X.509).
13-46-37-476| [ rdpclient 655] [ 64.735452] GFX codec.
13-46-37-476| [ rdpclient 655] [ 64.949527] Run 4 tile threads.
13-46-37-476| [ rdpclient 655] [ 65.022710] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000009.
13-46-37-476| [ rdpclient 655] [ 66.491998] SessionId 0x00000009: SC\foamline2lh.
13-46-37-476| [ rdpclient 655] [58570.586251] errorInfo 0x0000000c.
13-46-37-476| [ rdpclient 655] [58570.586437] ERRINFO_LOGOFF_BY_USER
13-46-37-476| [ rdpclient 655] [58570.716632] Receive Disconnect Provider Ultimatum.
13-46-37-476| [ gm] [58570.716847] TSClient (sessionId 2, pid 655) gracefully end.
13-46-37-476| [ pfac] [58570.743112] Process pid 655 terminated, status 00000009.
13-46-37-476| [ gm] [83671.893434] Run '/sbin/resolver 0x109fe08 dns [gateway.scdgroup.ca]', log '', env '', pid ''.
13-46-37-476| [ pfac] [83671.893804] Run /sbin/resolver 0x109fe08 dns [gateway.scdgroup.ca].
13-46-37-476| [ pfac] [83671.894399] Ok, PID 936.
13-46-37-476| [ pfac] [83671.902645] Process pid 936 terminated, status 00000000.
13-46-37-476| [ gm] [83671.904122] gateway.scdgroup.ca => 10.100.100.244.
13-46-37-476| [ gm] [83697.261262] Free ram before fork terminal client /sbin/rdpclient (session 3): 927440 Kb.
13-46-37-476| [ gm] [83697.261474] Run '/sbin/rdpclient 3', log '/tmp/rdpclient.out', env '', pid ''.
13-46-37-476| [ pfac] [83697.261761] Run /sbin/rdpclient 3.
13-46-37-476| [ pfac] [83697.262186] Ok, PID 937.
13-46-37-476| [ rdpclient 937] [83697.269854] RDP Terminal Client, WTware 5.6.16/RPi, pipe 3, pid 937.
13-46-37-476| [ rdpclient 937] [83697.272621] Use /lib/ui32.so.
13-46-37-476| [ rdpclient 937] [83697.272830] Make RDP session with 10.100.100.244, port 3389.
13-46-37-476| [ rdpclient 937] [83697.272923] Username: "Foamline2lh".
13-46-37-476| [ rdpclient 937] [83697.273024] Password: present.
13-46-37-476| [ rdpclient 937] [83697.273108] No PIN.
13-46-37-476| [ rdpclient 937] [83697.273186] No domain.
13-46-37-476| [ rdpclient 937] [83697.273263] No shell.
13-46-37-476| [ rdpclient 937] [83697.273337] No directory.
13-46-37-476| [ rdpclient 937] [83697.273416] Window: 1680x1050@24.
13-46-37-476| [ rdpclient 937] [83697.273490] PFlags 0x0000002F.
13-46-37-476| [ rdpclient 937] [83697.273567] Keyboard 00000409:00000000.
13-46-37-476| [ rdpclient 937] [83697.273685] My hostname "fl2-100-111-15".
13-46-37-476| [ rdpclient 937] [83697.273762] TCP: connecting to 10.100.100.244:3389.
13-46-37-476| [ rdpclient 937] [83697.275986] TCP: connection with 10.100.100.244:3389 established.
13-46-37-476| [ rdpclient 937] [83697.276190] Turn keepalive on.
13-46-37-476| [ rdpclient 937] [83697.276278] Free ram after buffers allocation: 927176 KB.
13-46-37-476| [ rdpclient 937] [83697.276355] Use Balance Info 49 bytes: 'tsv://MS Terminal Services Plugin.1.RDPCollection'.
13-46-37-476| [ rdpclient 937] [83697.278688] Reconnect with CredSSP enabled.
13-46-37-476| [ rdpclient 937] [83697.278882] TCP: reconnecting to 10.100.100.244:3389.
13-46-37-476| [ rdpclient 937] [83697.279270] TCP: connection with 10.100.100.244:3389 established.
13-46-37-476| [ rdpclient 937] [83697.279363] Turn keepalive on.
13-46-37-476| [ rdpclient 937] [83697.279444] Use Balance Info 49 bytes: 'tsv://MS Terminal Services Plugin.1.RDPCollection'.
13-46-37-476| [ rdpclient 937] [83697.282229] Server supports GFX Pipeline.
13-46-37-476| [ rdpclient 937] [83697.282355] CredSSP.
13-46-37-476| [ rdpclient 937] [83697.282433] SSL/TLS.
13-46-37-476| [ rdpclient 937] [83697.398545] Timezone '(UTC-07:00) Chihuahua, La Paz, Mazatlan'.
13-46-37-476| [ rdpclient 937] [83697.398730] Enable font smoothing and Desktop Composition.
13-46-37-476| [ rdpclient 937] [83697.430257] TS_STATUS_FINDING_DESTINATION
13-46-37-476| [ rdpclient 937] [83697.444996] TS_STATUS_LOADING_DESTINATION
13-46-37-476| [ rdpclient 937] [83697.445314] TS_STATUS_REDIRECTING_TO_DESTINATION
13-46-37-476| [ rdpclient 937] [83697.452897] TS_STATUS_BRINGING_SESSION_ONLINE
13-46-37-476| [ rdpclient 937] [83697.478653] Server Redirection flags 0x00000b0d.
13-46-37-476| [ rdpclient 937] [83697.478794] Server 10.100.100.241.
13-46-37-476| [ rdpclient 937] [83697.478923] User "foamline2lh".
13-46-37-476| [ rdpclient 937] [83697.479045] Domain "SC".
13-46-37-476| [ rdpclient 937] [83697.479189] Send Disconnect Provider Ultimatum.
13-46-37-476| [ gm] [83697.479530] TSClient (sessionId 3, pid 937) gracefully end.
13-46-37-476| [ gm] [83697.479933] Free ram before fork terminal client /sbin/rdpclient (session 4): 927052 Kb.
13-46-37-476| [ gm] [83697.480061] Run '/sbin/rdpclient 4', log '/tmp/rdpclient.out', env '', pid ''.
13-46-37-476| [ pfac] [83697.480147] Run /sbin/rdpclient 4.
13-46-37-476| [ pfac] [83697.480405] Ok, PID 938.
13-46-37-476| [ pfac] [83697.481707] Process pid 937 terminated, status 00000009.
13-46-37-476| [ rdpclient 938] [83697.488049] RDP Terminal Client, WTware 5.6.16/RPi, pipe 4, pid 938.
13-46-37-476| [ rdpclient 938] [83697.490104] Use /lib/ui32.so.
13-46-37-476| [ rdpclient 938] [83697.490994] Make RDP session with 10.100.100.241, port 3389.
13-46-37-476| [ rdpclient 938] [83697.491092] Username: "foamline2lh".
13-46-37-476| [ rdpclient 938] [83697.491167] Password: present.
13-46-37-476| [ rdpclient 938] [83697.491241] No PIN.
13-46-37-476| [ rdpclient 938] [83697.491513] Domain: "SC".
13-46-37-476| [ rdpclient 938] [83697.491591] No shell.
13-46-37-476| [ rdpclient 938] [83697.491684] No directory.
13-46-37-476| [ rdpclient 938] [83697.491758] Window: 1680x1050@24.
13-46-37-476| [ rdpclient 938] [83697.491831] PFlags 0x0000002F.
13-46-37-476| [ rdpclient 938] [83697.491904] Keyboard 00000409:00000000.
13-46-37-476| [ rdpclient 938] [83697.491975] My hostname "fl2-100-111-15".
13-46-37-476| [ rdpclient 938] [83697.492048] TCP: connecting to 10.100.100.241:3389.
13-46-37-476| [ rdpclient 938] [83697.493389] TCP: connection with 10.100.100.241:3389 established.
13-46-37-476| [ rdpclient 938] [83697.493528] Turn keepalive on.
13-46-37-476| [ rdpclient 938] [83697.493605] Free ram after buffers allocation: 926580 KB.
13-46-37-476| [ rdpclient 938] [83697.493679] Empty Balance Info.
13-46-37-476| [ rdpclient 938] [83697.495921] Reconnect with CredSSP enabled.
13-46-37-476| [ rdpclient 938] [83697.496113] TCP: reconnecting to 10.100.100.241:3389.
13-46-37-476| [ rdpclient 938] [83697.496538] TCP: connection with 10.100.100.241:3389 established.
13-46-37-476| [ rdpclient 938] [83697.496621] Turn keepalive on.
13-46-37-476| [ rdpclient 938] [83697.496695] Empty Balance Info.
13-46-37-476| [ rdpclient 938] [83697.510084] Server supports GFX Pipeline.
13-46-37-476| [ rdpclient 938] [83697.510184] CredSSP.
13-46-37-476| [ rdpclient 938] [83697.510258] SSL/TLS.
13-46-37-476| [ rdpclient 938] [83697.549636] Redirected Session ID 0x00000000.
13-46-37-476| [ rdpclient 938] [83697.556813] Timezone '(UTC-07:00) Chihuahua, La Paz, Mazatlan'.
13-46-37-476| [ rdpclient 938] [83697.556978] Enable font smoothing and Desktop Composition.
13-46-37-476| [ rdpclient 938] [83697.559562] RDP5 encryption (X.509).
13-46-37-476| [ rdpclient 938] [83697.702313] GFX codec.
13-46-37-476| [ rdpclient 938] [83697.878996] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000005.
13-46-37-476| [ rdpclient 938] [83697.910636] Run 4 tile threads.
13-46-37-476| [ rdpclient 938] [83699.662265] SessionId 0x00000005: SC\foamline2lh.
13-46-37-476| [ rdpclient 938] [144970.509359] errorInfo 0x0000000c.
13-46-37-476| [ rdpclient 938] [144970.509568] ERRINFO_LOGOFF_BY_USER
13-46-37-476| [ rdpclient 938] [144970.630801] Receive Disconnect Provider Ultimatum.
13-46-37-476| [ gm] [144970.631002] TSClient (sessionId 4, pid 938) gracefully end.
13-46-37-476| [ pfac] [144970.661131] Process pid 938 terminated, status 00000009.
13-46-37-476| [ gm] [168552.101367] Run '/sbin/resolver 0x109fe08 dns [gateway.scdgroup.ca]', log '', env '', pid ''.
13-46-37-476| [ pfac] [168552.102251] Run /sbin/resolver 0x109fe08 dns [gateway.scdgroup.ca].
13-46-37-476| [ pfac] [168552.102429] Ok, PID 1222.
13-46-37-476| [ pfac] [168552.110570] Process pid 1222 terminated, status 00000000.
13-46-37-476| [ gm] [168552.111962] gateway.scdgroup.ca => 10.100.100.244.
13-46-37-476| [ gm] [168569.845221] Free ram before fork terminal client /sbin/rdpclient (session 5): 927508 Kb.
13-46-37-476| [ gm] [168569.845457] Run '/sbin/rdpclient 5', log '/tmp/rdpclient.out', env '', pid ''.
13-46-37-476| [ pfac] [168569.846067] Run /sbin/rdpclient 5.
13-46-37-476| [ pfac] [168569.846173] Ok, PID 1223.
13-46-37-476| [rdpclient 1223] [168569.853833] RDP Terminal Client, WTware 5.6.16/RPi, pipe 5, pid 1223.
13-46-37-476| [rdpclient 1223] [168569.856656] Use /lib/ui32.so.
13-46-37-476| [rdpclient 1223] [168569.857207] Make RDP session with 10.100.100.244, port 3389.
13-46-37-476| [rdpclient 1223] [168569.857309] Username: "foamline2lh".
13-46-37-476| [rdpclient 1223] [168569.857390] Password: present.
13-46-37-476| [rdpclient 1223] [168569.857466] No PIN.
13-46-37-476| [rdpclient 1223] [168569.857543] No domain.
13-46-37-476| [rdpclient 1223] [168569.857620] No shell.
13-46-37-476| [rdpclient 1223] [168569.857696] No directory.
13-46-37-476| [rdpclient 1223] [168569.857773] Window: 1680x1050@24.
13-46-37-476| [rdpclient 1223] [168569.857849] PFlags 0x0000002F.
13-46-37-476| [rdpclient 1223] [168569.857925] Keyboard 00000409:00000000.
13-46-37-476| [rdpclient 1223] [168569.857999] My hostname "fl2-100-111-15".
13-46-37-476| [rdpclient 1223] [168569.858072] TCP: connecting to 10.100.100.244:3389.
13-46-37-476| [rdpclient 1223] [168569.860489] TCP: connection with 10.100.100.244:3389 established.
13-46-37-476| [rdpclient 1223] [168569.860690] Turn keepalive on.
13-46-37-476| [rdpclient 1223] [168569.860770] Free ram after buffers allocation: 926732 KB.
13-46-37-476| [rdpclient 1223] [168569.860851] Use Balance Info 49 bytes: 'tsv://MS Terminal Services Plugin.1.RDPCollection'.
13-46-37-476| [rdpclient 1223] [168569.864004] Reconnect with CredSSP enabled.
13-46-37-476| [rdpclient 1223] [168569.864289] TCP: reconnecting to 10.100.100.244:3389.
13-46-37-476| [rdpclient 1223] [168569.864732] TCP: connection with 10.100.100.244:3389 established.
13-46-37-476| [rdpclient 1223] [168569.864834] Turn keepalive on.
13-46-37-476| [rdpclient 1223] [168569.864910] Use Balance Info 49 bytes: 'tsv://MS Terminal Services Plugin.1.RDPCollection'.
13-46-37-476| [rdpclient 1223] [168569.870141] Server supports GFX Pipeline.
13-46-37-476| [rdpclient 1223] [168569.870238] CredSSP.
13-46-37-476| [rdpclient 1223] [168569.870315] SSL/TLS.
13-46-37-476| [rdpclient 1223] [168569.985431] Timezone '(UTC-07:00) Chihuahua, La Paz, Mazatlan'.
13-46-37-476| [rdpclient 1223] [168569.985591] Enable font smoothing and Desktop Composition.
13-46-37-476| [rdpclient 1223] [168570.001805] TS_STATUS_FINDING_DESTINATION
13-46-37-476| [rdpclient 1223] [168570.006363] TS_STATUS_LOADING_DESTINATION
13-46-37-476| [rdpclient 1223] [168570.006558] TS_STATUS_REDIRECTING_TO_DESTINATION
13-46-37-476| [rdpclient 1223] [168570.013690] TS_STATUS_BRINGING_SESSION_ONLINE
13-46-37-476| [rdpclient 1223] [168570.031289] Server Redirection flags 0x00000b0d.
13-46-37-476| [rdpclient 1223] [168570.031373] Server 10.100.100.237.
13-46-37-476| [rdpclient 1223] [168570.031453] User "foamline2lh".
13-46-37-476| [rdpclient 1223] [168570.031534] Domain "SC".
13-46-37-476| [rdpclient 1223] [168570.031614] Send Disconnect Provider Ultimatum.
13-46-37-476| [ gm] [168570.031692] TSClient (sessionId 5, pid 1223) gracefully end.
13-46-37-476| [ gm] [168570.032030] Free ram before fork terminal client /sbin/rdpclient (session 6): 926616 Kb.
13-46-37-476| [ gm] [168570.032116] Run '/sbin/rdpclient 6', log '/tmp/rdpclient.out', env '', pid ''.
13-46-37-476| [ pfac] [168570.032196] Run /sbin/rdpclient 6.
13-46-37-476| [ pfac] [168570.032450] Ok, PID 1224.
13-46-37-476| [ pfac] [168570.033873] Process pid 1223 terminated, status 00000009.
13-46-37-476| [rdpclient 1224] [168570.039888] RDP Terminal Client, WTware 5.6.16/RPi, pipe 6, pid 1224.
13-46-37-476| [rdpclient 1224] [168570.040823] Use /lib/ui32.so.
13-46-37-476| [rdpclient 1224] [168570.041591] Make RDP session with 10.100.100.237, port 3389.
13-46-37-476| [rdpclient 1224] [168570.041676] Username: "foamline2lh".
13-46-37-476| [rdpclient 1224] [168570.041753] Password: present.
13-46-37-476| [rdpclient 1224] [168570.041829] No PIN.
13-46-37-476| [rdpclient 1224] [168570.041903] Domain: "SC".
13-46-37-476| [rdpclient 1224] [168570.041977] No shell.
13-46-37-476| [rdpclient 1224] [168570.042048] No directory.
13-46-37-476| [rdpclient 1224] [168570.042121] Window: 1680x1050@24.
13-46-37-476| [rdpclient 1224] [168570.042195] PFlags 0x0000002F.
13-46-37-476| [rdpclient 1224] [168570.042272] Keyboard 00000409:00000000.
13-46-37-476| [rdpclient 1224] [168570.042348] My hostname "fl2-100-111-15".
13-46-37-476| [rdpclient 1224] [168570.042421] TCP: connecting to 10.100.100.237:3389.
13-46-37-476| [rdpclient 1224] [168570.042498] TCP: connection with 10.100.100.237:3389 established.
13-46-37-476| [rdpclient 1224] [168570.042575] Turn keepalive on.
13-46-37-476| [rdpclient 1224] [168570.043305] Free ram after buffers allocation: 926608 KB.
13-46-37-476| [rdpclient 1224] [168570.043404] Empty Balance Info.
13-46-37-476| [rdpclient 1224] [168570.045793] Reconnect with CredSSP enabled.
13-46-37-476| [rdpclient 1224] [168570.045877] TCP: reconnecting to 10.100.100.237:3389.
13-46-37-476| [rdpclient 1224] [168570.046425] TCP: connection with 10.100.100.237:3389 established.
13-46-37-476| [rdpclient 1224] [168570.046504] Turn keepalive on.
13-46-37-476| [rdpclient 1224] [168570.046577] Empty Balance Info.
13-46-37-476| [rdpclient 1224] [168570.049993] Server supports GFX Pipeline.
13-46-37-476| [rdpclient 1224] [168570.050135] CredSSP.
13-46-37-476| [rdpclient 1224] [168570.050229] SSL/TLS.
13-46-37-476| [rdpclient 1224] [168570.096658] Redirected Session ID 0x00000000.
13-46-37-476| [rdpclient 1224] [168570.103354] Timezone '(UTC-07:00) Chihuahua, La Paz, Mazatlan'.
13-46-37-476| [rdpclient 1224] [168570.103454] Enable font smoothing and Desktop Composition.
13-46-37-476| [rdpclient 1224] [168570.105827] RDP5 encryption (X.509).
13-46-37-476| [rdpclient 1224] [168570.150251] GFX codec.
13-46-37-476| [rdpclient 1224] [168570.321238] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000003.
13-46-37-476| [rdpclient 1224] [168570.360407] Run 4 tile threads.
13-46-37-476| [rdpclient 1224] [168571.730204] SessionId 0x00000003: SC\foamline2lh.
13-46-37-484| Connection from wtc.exe at 10.100.100.205.
I fixed option parsing. Now this text in config:
timezone = Mountain
set 'Mountain Standard Time', '(UTC-07:00) Mountain Time (US & Canada)'.
To set Mexico '(UTC-07:00) Chihuahua, La Paz, Mazatlan' longer config text needed:
timezone = Mountain Standard Time (Mexico)
Then, I set server time to UTC. November, 12. 17:00 on server.
I specify In config:
timezone = Mountain
Log in and get "10:00" in tray.
I change server date to November, 1. Log off and log in again. I get "11:00" in tray.
Then I change server date to March, 20. Log off and log in again. Still "11:00" in tray.
Finally I change server date to March, 1. Log off and log in again. "10:00" in tray.
Is it right?
