keyboard and vnc is ignored
ping_guin
Post by ping_guin »
I'm trying to get WTware 5.6.16/RPi to work.
The RDP-Session to a windows server 2008 is establishing, but there is always the en_us keyboard layout and I don't know how to get it work in german language.
my config.wtc is:
language=de,default
keyboard=de
server=server10.intranet.local
vnc=on
What makes me courious is, that I'm sure it has worked correctly, before I added these three lines:
user = myuser
domain = intranet
vnc_password=hex:abcde012345678
After removing that three lines because there was no change in login behaviour and also vnc was not reachable, the language/keyboard remains in english and vnc also is not working anymore.
I tried another new sd-card... same behaviour.
Do I run into a bug or how can I get my correct keyboard layout back and vnc working with hashed password?
best regards!
Re: keyboard and vnc is ignored
ping_guin
Post by ping_guin »
thanks for your hint.
I got the keyboard layout to work. It is important also to disconnect the hdmi-wire. It supplied the rasperry in that way, that a completely reset was not possible.
