I'm Tired
VXRDanny
I'm Tired
Post by VXRDanny »
Whilst testing the wtware product this error was produced. I'm running the latest version on a Pi3.
It has been working faultlessly for 3 or so days. It hasn't been switched off at all in that time period and I think it may be connected to Ethernet and Wifi (never switched wifi off after initial connection)
Config is running from the local SD card.
Do you know what may cause it?
rdpclient 2277] [432668.470365] Close TCP connection while receiving data, errno 110.
[rdpclient 2277] [432668.470499] rdpclient-connect.cpp (  474): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 2277] [432668.470584] rdpclient-connect.cpp ( 2691): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 2277] [432668.470663] rdpclient-connect.cpp ( 2931): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 2277] [432668.470742] I'm tired.
[            gm] [432668.471436] Final message: I'm tired.
[          pfac] [432668.520818] Process pid 2276 terminated, status 00000000.
Re: I'm Tired
errno 110 is ETIMEDOUT, 'Connection timed out'. Something is wrong in network.
