2012R2 Broker - Temporary profiles
MJ-5
Post by MJ-5 »
Hello, this is what I have :
- Broker farm of 2 RDS 2012 R2
- Raspberry Pi 3
- WTware 5.9.94
- RoundRobin DNS name : RDS-HLM
Two weeks ago, I was in version 5.4.78, and I feel that since an update of the RDS servers, I had temporary session randomly.
So I updated WTware (5.4.94), but I still encounter temporary profiles.
When I log in several times with the same user, I get a temporary profile, always once every two !
Here log of RDS when I have temporary session :
And log of Raspberry :
NO TEMPORARY SESSION
16-28-53-523| [ gm] [ 194.784128] Free ram before fork terminal client /sbin/rdpclient (session 7 ): 920824 Kb.
16-28-53-538| [ gm] [ 194.784361] Run '/sbin/rdpclient 7', log '/tmp/rdpclient.out', env '', pid ''.
16-28-53-554| [ pfac] [ 194.784590] Run /sbin/rdpclient 7.
16-28-53-554| [ pfac] [ 194.784856] Ok, PID 705.
16-28-53-554| [ rdpclient 705] [ 194.792387] RDP Terminal Client, WTware 5.4.94/RPi, pipe 7, pid 705.
16-28-53-554| [ rdpclient 705] [ 194.793178] Use /lib/ui32.so.
16-28-53-569| [ rdpclient 705] [ 194.793955] Make RDP session with 192.168.4.51, 192.168.4.49, port 3389.
16-28-53-569| [ rdpclient 705] [ 194.794030] Username: "rj".
16-28-53-585| [ rdpclient 705] [ 194.794089] Password: present.
16-28-53-601| [ rdpclient 705] [ 194.794145] No PIN.
16-28-53-601| [ rdpclient 705] [ 194.794200] Domain: "DOM-HLM.LOCAL".
16-28-53-616| [ rdpclient 705] [ 194.794255] No shell.
16-28-53-632| [ rdpclient 705] [ 194.794310] No directory.
16-28-53-632| [ rdpclient 705] [ 194.794364] Window: 1440x900@24.
16-28-53-648| [ rdpclient 705] [ 194.794419] PFlags 0x0000002E.
16-28-53-648| [ rdpclient 705] [ 194.794473] Keyboard 00000409:00000000.
16-28-53-663| [ rdpclient 705] [ 194.794529] My hostname "CL0001".
16-28-53-663| [ rdpclient 705] [ 194.795305] TCP: connection with 192.168.4.51:3389 established.
16-28-53-663| [ rdpclient 705] [ 194.795367] Turn keepalive on.
16-28-53-679| [ rdpclient 705] [ 194.796262] Free ram after buffers allocation: 919956 KB.
16-28-53-679| [ rdpclient 705] [ 194.796342] Use Balance Info 43 bytes: 'tsv://MS Terminal Services Plugin.1.RDS-HLM'.
16-28-53-679| [ rdpclient 705] [ 194.800591] Server supports GFX Pipeline.
16-28-53-694| [ rdpclient 705] [ 194.803129] Process RDP server certificate.
16-28-53-694| [ rdpclient 705] [ 194.803209] RDP5 encryption (X.509).
16-28-53-710| [ rdpclient 705] [ 194.808634] Timezone '(UTC+01:00) Brussels, Copenhagen, Madrid, Paris'.
16-28-53-726| [ rdpclient 705] [ 194.808699] Enable font smoothing and Desktop Composition.
16-28-53-726| [ rdpclient 705] [ 194.871392] GFX codec.
16-28-54-148| [ rdpclient 705] [ 195.411694] Run 4 tile threads.
16-28-54-398| [ rdpclient 705] [ 195.656636] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x0000002b.
16-28-56-304| [ rdpclient 705] [ 197.571124] SessionId 0x0000002b: DOM-HLM\rj.
TEMPORARY SESSION
16-29-59-447| [ gm] [ 260.704122] Free ram before fork terminal client /sbin/rdpclient (session 8 ): 921024 Kb.
16-29-59-462| [ gm] [ 260.704326] Run '/sbin/rdpclient 8', log '/tmp/rdpclient.out', env '', pid ''.
16-29-59-478| [ pfac] [ 260.704555] Run /sbin/rdpclient 8.
16-29-59-478| [ pfac] [ 260.704822] Ok, PID 713.
16-29-59-478| [ rdpclient 713] [ 260.712441] RDP Terminal Client, WTware 5.4.94/RPi, pipe 8, pid 713.
16-29-59-478| [ rdpclient 713] [ 260.713258] Use /lib/ui32.so.
16-29-59-494| [ rdpclient 713] [ 260.714036] Make RDP session with 192.168.4.49, 192.168.4.51, port 3389.
16-29-59-494| [ rdpclient 713] [ 260.714114] Username: "rj".
16-29-59-509| [ rdpclient 713] [ 260.714171] Password: present.
16-29-59-509| [ rdpclient 713] [ 260.714227] No PIN.
16-29-59-525| [ rdpclient 713] [ 260.714283] Domain: "DOM-HLM.LOCAL".
16-29-59-525| [ rdpclient 713] [ 260.714338] No shell.
16-29-59-540| [ rdpclient 713] [ 260.714393] No directory.
16-29-59-556| [ rdpclient 713] [ 260.714448] Window: 1440x900@24.
16-29-59-556| [ rdpclient 713] [ 260.714503] PFlags 0x0000002E.
16-29-59-572| [ rdpclient 713] [ 260.714557] Keyboard 00000409:00000000.
16-29-59-572| [ rdpclient 713] [ 260.714613] My hostname "CL0001".
16-29-59-587| [ rdpclient 713] [ 260.715526] TCP: connection with 192.168.4.49:3389 established.
16-29-59-587| [ rdpclient 713] [ 260.715588] Turn keepalive on.
16-29-59-603| [ rdpclient 713] [ 260.716593] Free ram after buffers allocation: 920156 KB.
16-29-59-603| [ rdpclient 713] [ 260.716670] Use Balance Info 43 bytes: 'tsv://MS Terminal Services Plugin.1.RDS-HLM'.
16-29-59-603| [ rdpclient 713] [ 260.721577] Server supports GFX Pipeline.
16-29-59-619| [ rdpclient 713] [ 260.723957] Process RDP server certificate.
16-29-59-619| [ rdpclient 713] [ 260.724064] RDP5 encryption (X.509).
16-29-59-619| [ rdpclient 713] [ 260.729718] Timezone '(UTC+01:00) Brussels, Copenhagen, Madrid, Paris'.
16-29-59-634| [ rdpclient 713] [ 260.729786] Enable font smoothing and Desktop Composition.
16-29-59-650| [ rdpclient 713] [ 260.800662] GFX codec.
16-30-00-181| [ rdpclient 713] [ 261.439710] Run 4 tile threads.
16-30-00-509| [ rdpclient 713] [ 261.780928] Server Redirection flags 0x00000b0d.
16-30-00-540| [ rdpclient 713] [ 261.781058] Server 192.168.4.51.
16-30-00-556| [ rdpclient 713] [ 261.781121] User "rj".
16-30-00-556| [ rdpclient 713] [ 261.781178] Domain "DOM-HLM".
16-30-00-556| [ rdpclient 713] [ 261.781234] Send Disconnect Provider Ultimatum.
16-30-00-572| [ gm] [ 261.781430] TSClient (sessionId 8, pid 713) gracefully end.
16-30-00-572| [ gm] [ 261.789608] Free ram before fork terminal client /sbin/rdpclient (session 9): 921448 Kb.
16-30-00-587| [ gm] [ 261.789754] Run '/sbin/rdpclient 9', log '/tmp/rdpclient.out', env '', pid ''.
16-30-00-603| [ pfac] [ 261.789973] Run /sbin/rdpclient 9.
16-30-00-603| [ pfac] [ 261.790380] Ok, PID 720.
16-30-00-619| [ pfac] [ 261.790462] Process pid 713 terminated, status 00000009.
16-30-00-634| [ rdpclient 720] [ 261.797589] RDP Terminal Client, WTware 5.4.94/RPi, pipe 9, pid 720.
16-30-00-634| [ rdpclient 720] [ 261.798459] Use /lib/ui32.so.
16-30-00-650| [ rdpclient 720] [ 261.799228] Make RDP session with 192.168.4.51, port 3389.
16-30-00-650| [ rdpclient 720] [ 261.799314] Username: "rj".
16-30-00-665| [ rdpclient 720] [ 261.799389] Password: present.
16-30-00-681| [ rdpclient 720] [ 261.799448] No PIN.
16-30-00-681| [ rdpclient 720] [ 261.799502] Domain: "DOM-HLM".
16-30-00-697| [ rdpclient 720] [ 261.799557] No shell.
16-30-00-697| [ rdpclient 720] [ 261.799611] No directory.
16-30-00-712| [ rdpclient 720] [ 261.799665] Window: 1440x900@24.
16-30-00-712| [ rdpclient 720] [ 261.799720] PFlags 0x0000002E.
16-30-00-728| [ rdpclient 720] [ 261.799774] Keyboard 00000409:00000000.
16-30-00-728| [ rdpclient 720] [ 261.799830] My hostname "CL0001".
16-30-00-744| [ rdpclient 720] [ 261.799926] TCP: connecting to 192.168.4.51:3389.
16-30-00-744| [ rdpclient 720] [ 261.800538] TCP: connection with 192.168.4.51:3389 established.
16-30-00-759| [ rdpclient 720] [ 261.800603] Turn keepalive on.
16-30-00-775| [ rdpclient 720] [ 261.801485] Free ram after buffers allocation: 920728 KB.
16-30-00-775| [ rdpclient 720] [ 261.801550] Empty Balance Info.
16-30-00-790| [ rdpclient 720] [ 261.805834] Server supports GFX Pipeline.
16-30-00-790| [ rdpclient 720] [ 261.805896] Redirected Session ID 0x00000000.
16-30-00-806| [ rdpclient 720] [ 261.808282] Process RDP server certificate.
16-30-00-806| [ rdpclient 720] [ 261.808342] RDP5 encryption (X.509).
16-30-00-822| [ rdpclient 720] [ 261.813589] Timezone '(UTC+01:00) Brussels, Copenhagen, Madrid, Paris'.
16-30-00-853| [ rdpclient 720] [ 261.813652] Enable font smoothing and Desktop Composition.
16-30-00-853| [ rdpclient 720] [ 261.870098] GFX codec.
16-30-01-119| [ rdpclient 720] [ 262.389005] Run 4 tile threads.
16-30-01-259| [ rdpclient 720] [ 262.530881] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x0000002c.
16-30-05-306| [ rdpclient 720] [ 266.571805] SessionId 0x0000002c: DOM-HLM\rj.
We can see that in case it works, we have much less log.
We do not find the part I highlighted in green in the case of a temporary session, except that we have a "Server Redirection" flag, which initiates a connection again.
And when this second connection is established, we do not find the IP address of both RDS, but only one (line highlighted in pink).
Another thing, during the second connection, the domain name is not really correct : "DOM-HLM" instead of "DOM-HLM.LOCAL"
We only have redirected message when we first connect to the first RDS (.49).
This is my template configuration :
server=rds-hlm
domain=DOM-HLM.LOCAL
keyboard=fr
graphic=a
loadbalanceinfo=tsv://MS Terminal Services Plugin.1.RDS-HLM
language=fr,default
timezone=Romance Standard Time
vnc=on
vnc_password=hex:fcbf.................
infobox=never
bpp=16
skin=sample
chrome_language=fr_be
I have no issue with other thin client (Wyse). VHDX disc are low capacity, and we have redirected "Document" folder.
Thank you,
Regards
Re: 2012R2 Broker - Temporary profiles
Try to connect directly to servers. Replace "server=rds-hlm" with "server=192.168.4.49". Reboot several times. Will you get temporary profile? Then write "server=192.168.4.51" and reboot several times again. Will you get temporary profile?
LOG OFF every time. Do not disconnect, do not reset client but log off.
And show me full logs, from boot to logging in. Send to support@wtware.com if there are a passwords in it.
MJ-5
Post by MJ-5 »
Several connections on both servers separately as you told me, no temporary profiles.
Several connections on server "RDS-HLM", no temporary profiles.
I hope this is not random, and that it will not fail in a few day.
Thank you !
MJ-5
Post by MJ-5 »
I unfortunately spoke too fast, again I have temporary profiles when in connect to "RDS-HLM", and always once every two :(
It seem that I do not have a temporary profile when I log on separately on both servers (not sure, I'll give you the logs tomorrow).
NO TEMPORARY PROFILES (SERVER=RDS-HLM)
17-30-31-442| [ gm] [ 3676.424323] Free ram before fork terminal client /sbin/rdpclient (session 22): 921576 Kb.
17-30-31-474| [ pfac] [ 3676.424489] Run /sbin/rdpclient 22.
17-30-31-489| [ gm] [ 3676.424519] Run '/sbin/rdpclient 22', log '/tmp/rdpclient.out', env '', pid ''.
17-30-31-489| [ pfac] [ 3676.424742] Ok, PID 833.
17-30-31-505| [ rdpclient 833] [ 3676.432185] RDP Terminal Client, WTware 5.4.94/RPi, pipe 22, pid 833.
17-30-31-505| [ rdpclient 833] [ 3676.432994] Use /lib/ui32.so.
17-30-31-521| [ rdpclient 833] [ 3676.433780] Make RDP session with 192.168.4.49, 192.168.4.51, port 3389.
17-30-31-521| [ rdpclient 833] [ 3676.433849] Username: "rj".
17-30-31-536| [ rdpclient 833] [ 3676.433907] Password: present.
17-30-31-536| [ rdpclient 833] [ 3676.434051] No PIN.
17-30-31-552| [ rdpclient 833] [ 3676.434111] Domain: "DOM-HLM.LOCAL".
17-30-31-552| [ rdpclient 833] [ 3676.434165] No shell.
17-30-31-567| [ rdpclient 833] [ 3676.434219] No directory.
17-30-31-567| [ rdpclient 833] [ 3676.434273] Window: 1440x900@24.
17-30-31-583| [ rdpclient 833] [ 3676.434328] PFlags 0x0000002E.
17-30-31-599| [ rdpclient 833] [ 3676.434381] Keyboard 0000040C:00000000.
17-30-31-599| [ rdpclient 833] [ 3676.434436] My hostname "CL0001".
17-30-31-614| [ rdpclient 833] [ 3676.435020] TCP: connection with 192.168.4.49:3389 established.
17-30-31-614| [ rdpclient 833] [ 3676.435086] Turn keepalive on.
17-30-31-630| [ rdpclient 833] [ 3676.435934] Free ram after buffers allocation: 920832 KB.
17-30-31-630| [ rdpclient 833] [ 3676.436044] Use Balance Info 43 bytes: 'tsv://MS Terminal Services Plugin.1.RDS-HLM'.
17-30-31-646| [ rdpclient 833] [ 3676.440646] Server supports GFX Pipeline.
17-30-31-661| [ rdpclient 833] [ 3676.444111] Process RDP server certificate.
17-30-31-661| [ rdpclient 833] [ 3676.444295] RDP5 encryption (X.509).
17-30-31-677| [ rdpclient 833] [ 3676.449815] Timezone '(UTC+01:00) Brussels, Copenhagen, Madrid, Paris'.
17-30-31-677| [ rdpclient 833] [ 3676.449909] Enable font smoothing and Desktop Composition.
17-30-31-692| [ rdpclient 833] [ 3676.530942] GFX codec.
17-30-32-208| [ rdpclient 833] [ 3677.190550] Run 4 tile threads.
17-30-32-552| [ rdpclient 833] [ 3677.527962] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x0000002b.
17-30-35-130| [ rdpclient 833] [ 3680.110631] SessionId 0x0000002b: DOM-HLM\rj.
17-30-52-489| [ rdpclient 833] [ 3697.458566] errorInfo 0x0000000c.
17-30-52-552| [ rdpclient 833] [ 3697.458771] ERRINFO_LOGOFF_BY_USER
17-30-52-614| [ rdpclient 833] [ 3697.568292] Receive Disconnect Provider Ultimatum.
17-30-52-614| [ gm] [ 3697.568467] TSClient (sessionId 22, pid 833) gracefully end.
17-30-52-614| [ pfac] [ 3697.579181] Process pid 833 terminated, status 00000009.
17-30-52-677| [ gm] [ 3697.587532] Run '/sbin/resolver 0x1b7e78 dns [rds-hlm]', log '', env '', pid ''.
17-30-52-677| [ pfac] [ 3697.587635] Run /sbin/resolver 0x1b7e78 dns [rds-hlm].
17-30-52-677| [ pfac] [ 3697.587882] Ok, PID 840.
17-30-52-692| [ gm] [ 3697.595817] rds-hlm => 192.168.4.51.
17-30-52-692| [ gm] [ 3697.595943] rds-hlm => 192.168.4.49.
17-30-52-708| [ pfac] [ 3697.596350] Process pid 840 terminated, status 00000000.
17-31-18-445| [ gm] [ 3723.424478] Free ram before fork terminal client /sbin/rdpclient (session 23): 921560 Kb.
17-31-18-476| [ gm] [ 3723.424705] Run '/sbin/rdpclient 23', log '/tmp/rdpclient.out', env '', pid ''.
17-31-18-476| [ pfac] [ 3723.424916] Run /sbin/rdpclient 23.
17-31-18-476| [ pfac] [ 3723.425290] Ok, PID 841.
17-31-18-492| [ rdpclient 841] [ 3723.432738] RDP Terminal Client, WTware 5.4.94/RPi, pipe 23, pid 841.
17-31-18-492| [ rdpclient 841] [ 3723.433571] Use /lib/ui32.so.
17-31-18-508| [ rdpclient 841] [ 3723.434334] Make RDP session with 192.168.4.51, 192.168.4.49, port 3389.
17-31-18-523| [ rdpclient 841] [ 3723.434402] Username: "rj".
17-31-18-523| [ rdpclient 841] [ 3723.434460] Password: present.
17-31-18-539| [ rdpclient 841] [ 3723.434515] No PIN.
17-31-18-554| [ rdpclient 841] [ 3723.434672] Domain: "DOM-HLM.LOCAL".
17-31-18-554| [ rdpclient 841] [ 3723.434728] No shell.
17-31-18-570| [ rdpclient 841] [ 3723.434782] No directory.
17-31-18-586| [ rdpclient 841] [ 3723.434837] Window: 1440x900@24.
17-31-18-586| [ rdpclient 841] [ 3723.434891] PFlags 0x0000002E.
17-31-18-601| [ rdpclient 841] [ 3723.434944] Keyboard 0000040C:00000000.
17-31-18-617| [ rdpclient 841] [ 3723.434999] My hostname "CL0001".
17-31-18-617| [ rdpclient 841] [ 3723.435653] TCP: connection with 192.168.4.51:3389 established.
17-31-18-633| [ rdpclient 841] [ 3723.435720] Turn keepalive on.
17-31-18-633| [ rdpclient 841] [ 3723.436555] Free ram after buffers allocation: 920824 KB.
17-31-18-648| [ rdpclient 841] [ 3723.436659] Use Balance Info 43 bytes: 'tsv://MS Terminal Services Plugin.1.RDS-HLM'.
17-31-18-648| [ rdpclient 841] [ 3723.441354] Server supports GFX Pipeline.
17-31-18-664| [ rdpclient 841] [ 3723.443912] Process RDP server certificate.
17-31-18-664| [ rdpclient 841] [ 3723.444023] RDP5 encryption (X.509).
17-31-18-679| [ rdpclient 841] [ 3723.449402] Timezone '(UTC+01:00) Brussels, Copenhagen, Madrid, Paris'.
17-31-18-679| [ rdpclient 841] [ 3723.449496] Enable font smoothing and Desktop Composition.
17-31-18-695| [ rdpclient 841] [ 3723.521311] GFX codec.
17-31-19-086| [ rdpclient 841] [ 3724.057466] Run 4 tile threads.
17-31-19-383| [ rdpclient 841] [ 3724.361292] Server Redirection flags 0x00000b0d.
17-31-19-398| [ gm] [ 3724.361472] TSClient (sessionId 23, pid 841) gracefully end.
17-31-19-398| [ rdpclient 841] [ 3724.361504] Server 192.168.4.49.
17-31-19-414| [ rdpclient 841] [ 3724.361567] User "rj".
17-31-19-414| [ rdpclient 841] [ 3724.361624] Domain "DOM-HLM".
17-31-19-429| [ rdpclient 841] [ 3724.361678] Send Disconnect Provider Ultimatum.
17-31-19-429| [ pfac] [ 3724.361964] Run /sbin/rdpclient 24.
17-31-19-445| [ gm] [ 3724.361991] Free ram before fork terminal client /sbin/rdpclient (session 24): 905896 Kb.
17-31-19-461| [ gm] [ 3724.362052] Run '/sbin/rdpclient 24', log '/tmp/rdpclient.out', env '', pid ''.
17-31-19-461| [ pfac] [ 3724.362259] Ok, PID 848.
17-31-19-492| [ rdpclient 848] [ 3724.369773] RDP Terminal Client, WTware 5.4.94/RPi, pipe 24, pid 848.
17-31-19-492| [ rdpclient 848] [ 3724.371990] Use /lib/ui32.so.
17-31-19-508| [ pfac] [ 3724.372082] Process pid 841 terminated, status 00000009.
17-31-19-523| [ rdpclient 848] [ 3724.372109] Make RDP session with 192.168.4.49, port 3389.
17-31-19-523| [ rdpclient 848] [ 3724.372167] Username: "rj".
17-31-19-539| [ rdpclient 848] [ 3724.372223] Password: present.
17-31-19-539| [ rdpclient 848] [ 3724.372278] No PIN.
17-31-19-554| [ rdpclient 848] [ 3724.372332] Domain: "DOM-HLM".
17-31-19-554| [ rdpclient 848] [ 3724.372387] No shell.
17-31-19-570| [ rdpclient 848] [ 3724.372440] No directory.
17-31-19-570| [ rdpclient 848] [ 3724.372494] Window: 1440x900@24.
17-31-19-586| [ rdpclient 848] [ 3724.372548] PFlags 0x0000002E.
17-31-19-586| [ rdpclient 848] [ 3724.372603] Keyboard 0000040C:00000000.
17-31-19-601| [ rdpclient 848] [ 3724.372658] My hostname "CL0001".
17-31-19-633| [ rdpclient 848] [ 3724.372763] TCP: connecting to 192.168.4.49:3389.
17-31-19-633| [ rdpclient 848] [ 3724.374067] TCP: connection with 192.168.4.49:3389 established.
17-31-19-648| [ rdpclient 848] [ 3724.374150] Turn keepalive on.
17-31-19-648| [ rdpclient 848] [ 3724.374207] Free ram after buffers allocation: 920488 KB.
17-31-19-664| [ rdpclient 848] [ 3724.374264] Empty Balance Info.
17-31-19-664| [ rdpclient 848] [ 3724.378879] Server supports GFX Pipeline.
17-31-19-679| [ rdpclient 848] [ 3724.378942] Redirected Session ID 0x00000000.
17-31-19-679| [ rdpclient 848] [ 3724.381811] Process RDP server certificate.
17-31-19-695| [ rdpclient 848] [ 3724.381875] RDP5 encryption (X.509).
17-31-19-711| [ rdpclient 848] [ 3724.387573] Timezone '(UTC+01:00) Brussels, Copenhagen, Madrid, Paris'.
17-31-19-711| [ rdpclient 848] [ 3724.387692] Enable font smoothing and Desktop Composition.
17-31-19-726| [ rdpclient 848] [ 3724.475792] GFX codec.
17-31-20-383| [ rdpclient 848] [ 3725.351149] Run 4 tile threads.
17-31-20-586| [ rdpclient 848] [ 3725.553598] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x0000002f.
17-31-25-820| [ rdpclient 848] [ 3730.796211] SessionId 0x0000002f: DOM-HLM\rj.
17-31-54-601| [ rdpclient 848] [ 3759.568787] errorInfo 0x0000000c.
17-31-54-664| [ rdpclient 848] [ 3759.568923] ERRINFO_LOGOFF_BY_USER
17-31-54-711| [ rdpclient 848] [ 3759.675003] Receive Disconnect Provider Ultimatum.
17-31-54-711| [ gm] [ 3759.675144] TSClient (sessionId 24, pid 848) gracefully end.
17-31-54-773| [ gm] [ 3759.693730] Run '/sbin/resolver 0x1b7e78 dns [rds-hlm]', log '', env '', pid ''.
17-31-54-773| [ pfac] [ 3759.694040] Run /sbin/resolver 0x1b7e78 dns [rds-hlm].
17-31-54-789| [ pfac] [ 3759.694398] Ok, PID 855.
17-31-54-789| [ pfac] [ 3759.694940] Process pid 848 terminated, status 00000009.
17-31-54-804| [ gm] [ 3759.702767] rds-hlm => 192.168.4.49.
17-31-54-804| [ pfac] [ 3759.702850] Process pid 855 terminated, status 00000000.
17-31-54-820| [ gm] [ 3759.702959] rds-hlm => 192.168.4.51.
No problem today until tonight, and I did not change anything... so strange.
MJ-5
Post by MJ-5 »
Another test : server=192.168.4.49
Always temporary profiles
11-24-22-760| [ gm] [ 29.719448] Free ram before fork terminal client /sbin/rdpclient (session 1): 921196 Kb.
11-24-22-776| [ pfac] [ 29.719609] Run /sbin/rdpclient 1.
11-24-22-792| [ gm] [ 29.719639] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
11-24-22-792| [ pfac] [ 29.719871] Ok, PID 659.
11-24-22-807| [ rdpclient 659] [ 29.727157] RDP Terminal Client, WTware 5.4.94/RPi, pipe 1, pid 659.
11-24-22-807| [ rdpclient 659] [ 29.728061] Use /lib/ui32.so.
11-24-22-823| [ rdpclient 659] [ 29.728863] Make RDP session with 192.168.4.49, port 3389.
11-24-22-823| [ rdpclient 659] [ 29.728948] Username: "rj".
11-24-22-823| [ rdpclient 659] [ 29.729022] Password: present.
11-24-22-838| [ rdpclient 659] [ 29.729079] No PIN.
11-24-22-838| [ rdpclient 659] [ 29.729133] Domain: "DOM-HLM.LOCAL".
11-24-22-854| [ rdpclient 659] [ 29.729187] No shell.
11-24-22-854| [ rdpclient 659] [ 29.729241] No directory.
11-24-22-854| [ rdpclient 659] [ 29.729295] Window: 1440x900@24.
11-24-22-870| [ rdpclient 659] [ 29.729349] PFlags 0x0000002E.
11-24-22-885| [ rdpclient 659] [ 29.729402] Keyboard 0000040C:00000000.
11-24-22-901| [ rdpclient 659] [ 29.729457] My hostname "CL0001".
11-24-22-901| [ rdpclient 659] [ 29.729511] TCP: connecting to 192.168.4.49:3389.
11-24-22-917| [ rdpclient 659] [ 29.730167] TCP: connection with 192.168.4.49:3389 established.
11-24-22-917| [ rdpclient 659] [ 29.730229] Turn keepalive on.
11-24-22-932| [ rdpclient 659] [ 29.731085] Free ram after buffers allocation: 920560 KB.
11-24-22-948| [ rdpclient 659] [ 29.731150] Use Balance Info 43 bytes: 'tsv://MS Terminal Services Plugin.1.RDS-HLM'.
11-24-22-948| [ rdpclient 659] [ 29.736421] Server supports GFX Pipeline.
11-24-22-948| [ rdpclient 659] [ 29.739822] Process RDP server certificate.
11-24-22-948| [ rdpclient 659] [ 29.739886] RDP5 encryption (X.509).
11-24-22-963| [ rdpclient 659] [ 29.746121] Timezone '(UTC+01:00) Brussels, Copenhagen, Madrid, Paris'.
11-24-22-979| [ rdpclient 659] [ 29.746188] Enable font smoothing and Desktop Composition.
11-24-22-979| [ rdpclient 659] [ 29.854459] GFX codec.
11-24-23-589| [ rdpclient 659] [ 30.545299] Run 4 tile threads.
11-24-23-839| [ rdpclient 659] [ 30.803851] TS_STATUS_FINDING_DESTINATION
11-24-23-901| [ rdpclient 659] [ 30.812544] TS_STATUS_LOADING_DESTINATION
11-24-23-901| [ rdpclient 659] [ 30.813068] TS_STATUS_REDIRECTING_TO_DESTINATION
11-24-23-932| [ rdpclient 659] [ 30.836704] TS_STATUS_BRINGING_SESSION_ONLINE
11-24-23-964| [ rdpclient 659] [ 30.910050] Server Redirection flags 0x00000b0d.
11-24-23-964| [ rdpclient 659] [ 30.910122] Server 192.168.4.51.
11-24-23-979| [ rdpclient 659] [ 30.910185] User "rj".
11-24-23-995| [ gm] [ 30.910241] TSClient (sessionId 1, pid 659) gracefully end.
11-24-23-995| [ rdpclient 659] [ 30.910278] Domain "DOM-HLM".
11-24-24-010| [ rdpclient 659] [ 30.910336] Send Disconnect Provider Ultimatum.
11-24-24-010| [ gm] [ 30.910709] Free ram before fork terminal client /sbin/rdpclient (session 2): 905964 Kb.
11-24-24-026| [ gm] [ 30.910784] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
11-24-24-026| [ pfac] [ 30.911072] Run /sbin/rdpclient 2.
11-24-24-026| [ pfac] [ 30.912472] Ok, PID 666.
11-24-24-042| [ rdpclient 666] [ 30.919096] RDP Terminal Client, WTware 5.4.94/RPi, pipe 2, pid 666.
11-24-24-042| [ pfac] [ 30.920098] Process pid 659 terminated, status 00000009.
11-24-24-042| [ rdpclient 666] [ 30.920601] Use /lib/ui32.so.
11-24-24-057| [ rdpclient 666] [ 30.922148] Make RDP session with 192.168.4.51, port 3389.
11-24-24-057| [ rdpclient 666] [ 30.922214] Username: "rj".
11-24-24-073| [ rdpclient 666] [ 30.922271] Password: present.
11-24-24-088| [ rdpclient 666] [ 30.922327] No PIN.
11-24-24-088| [ rdpclient 666] [ 30.922383] Domain: "DOM-HLM".
11-24-24-104| [ rdpclient 666] [ 30.922439] No shell.
11-24-24-120| [ rdpclient 666] [ 30.922493] No directory.
11-24-24-120| [ rdpclient 666] [ 30.922548] Window: 1440x900@24.
11-24-24-135| [ rdpclient 666] [ 30.922604] PFlags 0x0000002E.
11-24-24-151| [ rdpclient 666] [ 30.922659] Keyboard 0000040C:00000000.
11-24-24-151| [ rdpclient 666] [ 30.922714] My hostname "CL0001".
11-24-24-167| [ rdpclient 666] [ 30.922768] TCP: connecting to 192.168.4.51:3389.
11-24-24-167| [ rdpclient 666] [ 30.923330] TCP: connection with 192.168.4.51:3389 established.
11-24-24-182| [ rdpclient 666] [ 30.923393] Turn keepalive on.
11-24-24-182| [ rdpclient 666] [ 30.924286] Free ram after buffers allocation: 920548 KB.
11-24-24-198| [ rdpclient 666] [ 30.924354] Empty Balance Info.
11-24-24-198| [ rdpclient 666] [ 30.929205] Server supports GFX Pipeline.
11-24-24-213| [ rdpclient 666] [ 30.929265] Redirected Session ID 0x00000000.
11-24-24-213| [ rdpclient 666] [ 30.932748] Process RDP server certificate.
11-24-24-229| [ rdpclient 666] [ 30.932814] RDP5 encryption (X.509).
11-24-24-245| [ rdpclient 666] [ 30.938086] Timezone '(UTC+01:00) Brussels, Copenhagen, Madrid, Paris'.
11-24-24-245| [ rdpclient 666] [ 30.938156] Enable font smoothing and Desktop Composition.
11-24-24-260| [ rdpclient 666] [ 30.999264] GFX codec.
11-24-24-604| [ rdpclient 666] [ 31.562968] Run 4 tile threads.
11-24-24-964| [ rdpclient 666] [ 31.917681] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x0000001c.
11-24-29-932| [ rdpclient 666] [ 36.886994] SessionId 0x0000001c: DOM-HLM\rj.
server=192.168.4.51
No temporary profiles (never)
It's random, yesterday, I have temporary profiles when I firt connect to 4.51.
Today it's different, I have temporary profiles when I first connect to 4.49.
MJ-5
Post by MJ-5 »
Problem solved.
Installed Broker role on 1 dedicated server only, and it's works :)
