problem connecting rdp
nicola.piazzi
Post by nicola.piazzi »
I use wtware for raspberry
In my config.wtc i wrote a line like this :
server=myrdpserver.mydomain.it
Problem is that when raspberry starts it try to connect and the rdp server give the login page
after some seconds the server drop the commection and wtware relaunch it creating a server connection page loop
I tried a lot of combinations, but all not work, I need something that need an ENTER to start a connection request when server drop it
Re: problem connecting rdp
ask_password = on
Will ask login and password in wtware interface.
nicola.piazzi
Thanks, it works, but ...
I use keyboard italian that works only in rdp and not in wtware
so ask_password see my keyb as an english one and qhen someone write 12345# it make not # and give an error
then it solves when rdp ask password
i need to use only standard key passwords solves
1. If you find your keyboard layout, we can add it to wtware: http://ascii-table.com/keyboards.php
2. http://wtware.com/docs5/config.html#turnoffmenu
With "turnoffmenu=on" terminal will start screensaver after first connection. You will press Enter to reconnect to RDP.
nicola.piazzi
turnoffmenu=on without ask_password=on solve the problem
thanks
