terminal won't boot
mickx
terminal won't boot
Post by mickx »
I have installed wtware on a server 2003. DHCP service is running on this server. Terminal gets ip-address and terminal can be seen in wtware. Terminal is a fit pc2 (see http://www.fit-pc.com) .
Terminal screen stops with IP-infos and blinking cursor. Seems like the wtware is not started on terminal.
Log file of terminal:
12-01-42-126| [TFTP] RRQ 32 bytes:
12-01-42-141| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 77 74 77 61 72 65 2e 70 78
12-01-42-141| [TFTP] 00000010: 65 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
12-01-42-141| [TFTP] "5.4.94\wtware.pxe": tsize is requested, blksize default.
12-01-42-141| [TFTP] "5.4.94\wtware.pxe": "C:\Programme\WTware\TFTPDROOT\5.4.94\wtware.pxe".
12-01-42-141| [TFTP] Received opcode ERR.
12-01-42-157| [TFTP] RRQ 37 bytes:
12-01-42-157| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 77 74 77 61 72 65 2e 70 78
12-01-42-157| [TFTP] 00000010: 65 00 6f 63 74 65 74 00 62 6c 6b 73 69 7a 65 00
12-01-42-157| [TFTP] 00000020: 31 34 35 36 00
12-01-42-157| [TFTP] Request block size 1456, interface MTU 1500.
12-01-42-157| [TFTP] "5.4.94\wtware.pxe": tsize is not requested, blksize 1456 bytes.
12-01-42-173| [TFTP] "5.4.94\wtware.pxe": "C:\Programme\WTware\TFTPDROOT\5.4.94\wtware.pxe".
12-01-42-204| [TFTP] "5.4.94\wtware.pxe": completed.
12-01-42-344| [TFTP] RRQ 71 bytes:
12-01-42-360| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 30 31 30 31 30 31 30 31 2d
12-01-42-360| [TFTP] 00000010: 30 31 30 31 2d 30 31 30 31 2d 30 31 30 31 2d 30
12-01-42-360| [TFTP] 00000020: 31 30 31 30 31 30 31 30 31 30 31 00 6f 63 74 65
12-01-42-360| [TFTP] 00000030: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
12-01-42-360| [TFTP] 00000040: 65 00 31 34 30 38 00
12-01-42-360| [TFTP] Request block size 1408, interface MTU 1500.
12-01-42-360| [TFTP] "5.4.94\01010101-0101-0101-0101-010101010101": tsize is requested, blksize 1408 bytes.
12-01-42-360| [TFTP] "5.4.94\01010101-0101-0101-0101-010101010101": file not found: "C:\Programme\WTware\TFTPDROOT\5.4.94\01010101-0101-0101-0101-010101010101".
12-01-42-360| [TFTP] RRQ 55 bytes:
12-01-42-360| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 30 31 2d 30 30 2d 30 31 2d
12-01-42-376| [TFTP] 00000010: 63 30 2d 30 35 2d 62 65 2d 65 38 00 6f 63 74 65
12-01-42-376| [TFTP] 00000020: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
12-01-42-376| [TFTP] 00000030: 65 00 31 34 30 38 00
12-01-42-376| [TFTP] Request block size 1408, interface MTU 1500.
12-01-42-376| [TFTP] "5.4.94\01-00-01-c0-05-be-e8": tsize is requested, blksize 1408 bytes.
12-01-42-376| [TFTP] "5.4.94\01-00-01-c0-05-be-e8": file not found: "C:\Programme\WTware\TFTPDROOT\5.4.94\01-00-01-c0-05-be-e8".
12-01-42-376| [TFTP] RRQ 43 bytes:
12-01-42-376| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 43 30 41 38 30 31 30 42 00
12-01-42-376| [TFTP] 00000010: 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c
12-01-42-376| [TFTP] 00000020: 6b 73 69 7a 65 00 31 34 30 38 00
12-01-42-391| [TFTP] "5.4.94\C0A8010B": tsize is requested, blksize 1408 bytes.
12-01-42-391| [TFTP] "5.4.94\C0A8010B": file not found: "C:\Programme\WTware\TFTPDROOT\5.4.94\C0A8010B".
12-01-42-391| [TFTP] RRQ 42 bytes:
12-01-42-391| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 43 30 41 38 30 31 30 00 6f
12-01-42-391| [TFTP] 00000010: 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b
12-01-42-391| [TFTP] 00000020: 73 69 7a 65 00 31 34 30 38 00
12-01-42-391| [TFTP] Request block size 1408, interface MTU 1500.
12-01-42-391| [TFTP] "5.4.94\C0A8010": tsize is requested, blksize 1408 bytes.
12-01-42-391| [TFTP] "5.4.94\C0A8010": file not found: "C:\Programme\WTware\TFTPDROOT\5.4.94\C0A8010".
12-01-42-391| [TFTP] RRQ 41 bytes:
12-01-42-391| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 43 30 41 38 30 31 00 6f 63
12-01-42-407| [TFTP] 00000010: 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73
12-01-42-407| [TFTP] 00000020: 69 7a 65 00 31 34 30 38 00
12-01-42-407| [TFTP] Request block size 1408, interface MTU 1500.
12-01-42-407| [TFTP] "5.4.94\C0A801": tsize is requested, blksize 1408 bytes.
12-01-42-407| [TFTP] "5.4.94\C0A801": file not found: "C:\Programme\WTware\TFTPDROOT\5.4.94\C0A801".
12-01-42-407| [TFTP] RRQ 40 bytes:
12-01-42-407| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 43 30 41 38 30 00 6f 63 74
12-01-42-407| [TFTP] 00000010: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
12-01-42-407| [TFTP] 00000020: 7a 65 00 31 34 30 38 00
12-01-42-423| [TFTP] "5.4.94\C0A80": tsize is requested, blksize 1408 bytes.
12-01-42-423| [TFTP] "5.4.94\C0A80": file not found: "C:\Programme\WTware\TFTPDROOT\5.4.94\C0A80".
12-01-42-423| [TFTP] RRQ 39 bytes:
12-01-42-423| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 43 30 41 38 00 6f 63 74 65
12-01-42-423| [TFTP] 00000010: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
12-01-42-423| [TFTP] 00000020: 65 00 31 34 30 38 00
12-01-42-423| [TFTP] Request block size 1408, interface MTU 1500.
12-01-42-423| [TFTP] "5.4.94\C0A8": tsize is requested, blksize 1408 bytes.
12-01-42-423| [TFTP] "5.4.94\C0A8": file not found: "C:\Programme\WTware\TFTPDROOT\5.4.94\C0A8".
12-01-42-423| [TFTP] RRQ 38 bytes:
12-01-42-438| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 43 30 41 00 6f 63 74 65 74
12-01-42-438| [TFTP] 00000010: 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65
12-01-42-438| [TFTP] 00000020: 00 31 34 30 38 00
12-01-42-438| [TFTP] Request block size 1408, interface MTU 1500.
12-01-42-438| [TFTP] "5.4.94\C0A": tsize is requested, blksize 1408 bytes.
12-01-42-438| [TFTP] "5.4.94\C0A": file not found: "C:\Programme\WTware\TFTPDROOT\5.4.94\C0A".
12-01-42-438| [TFTP] RRQ 37 bytes:
12-01-42-438| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 43 30 00 6f 63 74 65 74 00
12-01-42-438| [TFTP] 00000010: 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00
12-01-42-438| [TFTP] 00000020: 31 34 30 38 00
12-01-42-454| [TFTP] "5.4.94\C0": tsize is requested, blksize 1408 bytes.
12-01-42-454| [TFTP] "5.4.94\C0": file not found: "C:\Programme\WTware\TFTPDROOT\5.4.94\C0".
12-01-42-454| [TFTP] RRQ 36 bytes:
12-01-42-454| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 43 00 6f 63 74 65 74 00 74
12-01-42-454| [TFTP] 00000010: 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31
12-01-42-454| [TFTP] 00000020: 34 30 38 00
12-01-42-454| [TFTP] Request block size 1408, interface MTU 1500.
12-01-42-454| [TFTP] "5.4.94\C": tsize is requested, blksize 1408 bytes.
12-01-42-454| [TFTP] "5.4.94\C": file not found: "C:\Programme\WTware\TFTPDROOT\5.4.94\C".
12-01-42-469| [TFTP] RRQ 42 bytes:
12-01-42-469| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 70 78 65 2e 63 66 67 00 6f
12-01-42-469| [TFTP] 00000010: 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b
12-01-42-469| [TFTP] 00000020: 73 69 7a 65 00 31 34 30 38 00
12-01-42-469| [TFTP] Request block size 1408, interface MTU 1500.
12-01-42-469| [TFTP] "5.4.94\pxe.cfg": tsize is requested, blksize 1408 bytes.
12-01-42-469| [TFTP] "5.4.94\pxe.cfg": "C:\Programme\WTware\TFTPDROOT\5.4.94\pxe.cfg".
12-01-42-469| [TFTP] "5.4.94\pxe.cfg": completed.
12-01-42-469| [TFTP] RRQ 50 bytes:
12-01-42-469| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 70 61 63 6b 61 67 65 73 2f
12-01-42-469| [TFTP] 00000010: 6b 65 72 6e 65 6c 00 6f 63 74 65 74 00 74 73 69
12-01-42-485| [TFTP] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
12-01-42-485| [TFTP] 00000030: 38 00
12-01-42-485| [TFTP] Request block size 1408, interface MTU 1500.
12-01-42-485| [TFTP] "5.4.94\packages\kernel": tsize is requested, blksize 1408 bytes.
12-01-42-485| [TFTP] "5.4.94\packages\kernel": "C:\Programme\WTware\TFTPDROOT\5.4.94\packages\kernel".
12-01-43-126| [TFTP] "5.4.94\packages\kernel": completed.
12-01-43-126| [TFTP] RRQ 50 bytes:
12-01-43-126| [TFTP] 00000000: 35 2e 34 2e 39 34 5c 70 61 63 6b 61 67 65 73 2f
12-01-43-141| [TFTP] 00000010: 69 6e 69 74 72 64 00 6f 63 74 65 74 00 74 73 69
12-01-43-141| [TFTP] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
12-01-43-141| [TFTP] 00000030: 38 00
12-01-43-141| [TFTP] Request block size 1408, interface MTU 1500.
12-01-43-141| [TFTP] "5.4.94\packages\initrd": tsize is requested, blksize 1408 bytes.
12-01-43-157| [TFTP] "5.4.94\packages\initrd": "C:\Programme\WTware\TFTPDROOT\5.4.94\packages\initrd".
12-01-44-048| [TFTP] "5.4.94\packages\initrd": completed.
12-02-20-173| [wtc.exe] Failed to connect to 192.168.1.11:779.
12-02-49-314| [wtc.exe] Failed to connect to 192.168.1.11:779.
Please help, does wtware work with fit pc2 at all?
Werner
mickx
Re: terminal won't boot
Post by mickx »
Solved - has to do with folder rights of the user starting the wtware tftp-service. If access to folder wtware is set to any, it works fine. Which is the suggested user to start the wtware tftp-service? Or which user should be set in the folder properties for local-system?
I don't understand what are you talking about. Your log:
It means that wtware tftp service has access to "folder" and reads files. You should got "Press Del to enter Setup" on terminal screen.
Show me "Terminal screen stops with IP-infos and blinking cursor" photo.
Installer should set right access for folder and right user for service.
