Keyboard setting "de" for login screen
Joep
Post by Joep »
the setting keyboard=de does not result in QWERTZ on the login screen. It works when the rdp session is running, but not during input of the username / password on the WTWARE login screen.
We are working with the newest WTWARE build (5.4.88), and we access rdp of a windows server 2016.
As parameters we use server, domain and keyboard.
Re: Keyboard setting "de" for login screen
Right. The setting language= works for login screen in WTware interface: https://wtware.com/docs5/config.html#language
Also, you can disable NLA on server so that WTware will not show login interface: https://wtware.com/win/nla.html
Joep
Post by Joep »
OK, it seems it's only working with following settings:
language=de,default
without the "default" it doesn't work.
