Skin
abtest
Skin
Post by abtest »
Hello
Im trying to change the background on the connections screen, i have created the images and placed them in a folder called sample under the graphic main folder, the logo appears in the info box if i hover over the bottom corner so it seems to be seeing them it just isn't displaying my background on the main connections screen
Re: Skin
abtest
Re: Skin
Post by abtest »
Log
WTware_B8.27.EB.CF.DA.95_2017-03-24_14-12-33.txt
(57.08 KiB) Downloaded 1152 times
Re: Skin
Bad PNG format /tmp/wait.png.
Bad PNG format /tmp/menu.png.
It saw your pngs, but didn't understand format.
abtest
Re: Skin
Post by abtest »
Thanks the image was corrupt
