Network Share
clemylton
Network Share
Post by clemylton »
Hi guys,
Is it possible to map network shared drives on Windows TS Session? I have four stations running WTWare on a local network and we have a file server sharing files to the entire LAN. How do i map that for TS users on WTWare stations?
Thanks!
Re: Network Share
You are to map network shared drive on the terminal server, inside user RDP session, for one connected user. Thin client doesn't interact with file share.
clemylton
Re: Network Share
Post by clemylton »
Ok. Thanks for your reply! So, there is no way to access network shared folders when running WTWare? There is no workaround for this?? :(
Re: Network Share
Please, write more words about the task you are solving. For there is no reason to access network share from thin client. User can access network share from server, in Windows.
