Change Hostname
ait_usr
Change Hostname
Post by ait_usr »
Hello
Please can anyone assist, would like to change the hostname from the standard wtwmac address to something more meaningful.
Running configs from the SD card at present as still testing.
Re: Change Hostname
If you use DHCP, set 012 DHCP option: https://wtware.com/docs5/dhcp.html#hostname
Else use clienthostname= config file option
