Keyboard Problem?
garryggreen
Keyboard Problem?
Post by garryggreen »
After PXE booting WTWARE V5.4.68, I get the blue screen offering to
rdp:ip-addr-of-wtware-server:3389
Another server
Since I use a different port, I press the down arrow to hilite Another server, and I get a box and I type in:
rdp:ip-addr-of-machine:its-rdp-port
But instead it displays rd* - every time I press the letter p I get an *.
Sometimes I can get by this, to the prompt that shows my userid on the target system, but when I type in my password (which I can't see), it tells me my password is invalid (I've checked Caps Lock).
This seems to be a keyboard problem with incorrect codes sometimes being entered.
Can anyone suggest what might be the problem/what I might try?
Re: Keyboard Problem?
1. Send me to support@wtware.com terminal log (http://wtware.com/logs.html).
2. And photo of this screen.
For we failed to understand what you mean :(
