Custom graphic?
adameup
Custom graphic?
Post by adameup »
Any way to add your own wallpaper/icons on the username and password screen for the end user when setting "ask_password = on"?
thanks
Re: Custom graphic?
Re: Custom graphic?
Put into config file:
skin=sample
Files are taken from C:\ProgramData\WTware\Graphic if you download configs from tftp/http.
Copy folder C:\ProgramData\WTware\Graphic\sample to graphic folder on SD if terminal stores configs on SD.
