Touchmonitor iiyama
wpmuellner
Touchmonitor iiyama
Post by wpmuellner »
Hallo aka/WT Support
WTware for raspberry is one of the best Thinclient I ever tested.
I have a USB barcodescanner and a USB RFID Reader connected and they work.
There is only a problem with the touchmonitor iiyama t2435msc-b2.
The touch has no function.
With Raspian Jessie the Touch worked.
In USB he is present:
WTware v.5.4.52
[0] USB ID: 0424:9514, bus ID: 1-1, class: 0x09, subclass: 0x00, Standard Microsystems Corp. SMC9514 Hub
[1] USB ID: 0424:ec00, bus ID: 1-1.1, class: 0xff, subclass: 0x00, Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
[2] USB ID: 05e3:0608, bus ID: 1-1.3, class: 0x09, subclass: 0x00, Genesys Logic, Inc. Hub
[3] USB ID: 046d:c050, bus ID: 1-1.4, class: 0x00, subclass: 0x00, Logitech, Inc. RX 250 Optical Mouse
[4] USB ID: 046d:c31c, bus ID: 1-1.5, class: 0x00, subclass: 0x00, Logitech, Inc. Keyboard K120
[5] USB ID: 0596:0535, bus ID: 1-1.3.1, class: 0x00, subclass: 0x00, MicroTouch Systems, Inc.
[6] USB ID: 1bcf:2281, bus ID: 1-1.3.2, class: 0xef, subclass: 0x02, Sunplus Innovation Technology Inc.
[7] USB ID: 1307:0330, bus ID: 1-1.3.3, class: 0x00, subclass: 0x00, Transcend Information, Inc. 63-in-1 Multi-Card Reader/Writer
[8] USB ID: ffff:0035, bus ID: 1-1.3.4, class: 0x00, subclass: 0x00,
Can you help me please.
Wolfgang
Re: Touchmonitor iiyama
Please, send me terminal log file to support@wtware.com
How to create log is here: http://wtware.com/logs.html
wpmuellner
@aka: I have sent you the logfile a few days ago. Is there a solution to the problem.
Here again the logfile:
USB is disconnected and reconnected:
10-03-08-449| [ gm] [ 192.479099] Standby monitor.
10-04-16-856| [ KERNEL] [ 260.888846] usb 1-1.2: USB disconnect, device number 6
10-04-16-906| [ KERNEL] [ 260.888875] usb 1-1.2.1: USB disconnect, device number 7
10-04-16-915| [ KERNEL] [ 260.889983] usb 1-1.2.2: USB disconnect, device number 8
10-04-21-702| [ KERNEL] [ 265.728760] usb 1-1.2: new high-speed USB device number 9 using dwc_otg
10-04-21-797| [ KERNEL] [ 265.830526] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0608
10-04-21-848| [ KERNEL] [ 265.830549] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
10-04-21-856| [ KERNEL] [ 265.830565] usb 1-1.2: Product: USB2.0 Hub
10-04-21-857| [ KERNEL] [ 265.831987] hub 1-1.2:1.0: USB hub found
10-04-21-865| [ KERNEL] [ 265.835141] hub 1-1.2:1.0: 4 ports detected
10-04-22-081| [ KERNEL] [ 266.108753] usb 1-1.2.1: new full-speed USB device number 10 using dwc_otg
10-04-22-190| [ KERNEL] [ 266.223155] usb 1-1.2.1: New USB device found, idVendor=0596, idProduct=0535
10-04-22-240| [ KERNEL] [ 266.223178] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
10-04-22-248| [ KERNEL] [ 266.223194] usb 1-1.2.1: Product: 3M MicroTouch USB controller
10-04-22-249| [ KERNEL] [ 266.223210] usb 1-1.2.1: Manufacturer: 3M
10-04-22-292| [ KERNEL] [ 266.318772] usb 1-1.2.2: new high-speed USB device number 11 using dwc_otg
10-04-22-717| [ KERNEL] [ 266.750074] usb 1-1.2.2: New USB device found, idVendor=1bcf, idProduct=2281
10-04-22-767| [ KERNEL] [ 266.750100] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
10-04-22-775| [ KERNEL] [ 266.750116] usb 1-1.2.2: Product: SPCA2281 Web Camera
10-04-22-776| [ KERNEL] [ 266.750131] usb 1-1.2.2: Manufacturer: Sunplus IT Co
10-06-19-754| [ KERNEL] [ 383.785224] usb 1-1.2: USB disconnect, device number 9
10-06-19-804| [ KERNEL] [ 383.785255] usb 1-1.2.1: USB disconnect, device number 10
10-06-19-812| [ KERNEL] [ 383.789577] usb 1-1.2.2: USB disconnect, device number 11
10-06-50-974| [ KERNEL] [ 414.998761] usb 1-1.2: new high-speed USB device number 12 using dwc_otg
10-06-51-070| [ KERNEL] [ 415.100480] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0608
10-06-51-121| [ KERNEL] [ 415.100503] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
10-06-51-129| [ KERNEL] [ 415.100519] usb 1-1.2: Product: USB2.0 Hub
10-06-51-130| [ KERNEL] [ 415.101689] hub 1-1.2:1.0: USB hub found
10-06-51-138| [ KERNEL] [ 415.102203] hub 1-1.2:1.0: 4 ports detected
10-06-51-354| [ KERNEL] [ 415.378756] usb 1-1.2.1: new full-speed USB device number 13 using dwc_otg
10-06-51-462| [ KERNEL] [ 415.493432] usb 1-1.2.1: New USB device found, idVendor=0596, idProduct=0535
10-06-51-513| [ KERNEL] [ 415.493455] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
10-06-51-521| [ KERNEL] [ 415.493471] usb 1-1.2.1: Product: 3M MicroTouch USB controller
10-06-51-522| [ KERNEL] [ 415.493485] usb 1-1.2.1: Manufacturer: 3M
10-06-51-565| [ KERNEL] [ 415.588772] usb 1-1.2.2: new high-speed USB device number 14 using dwc_otg
10-06-51-988| [ KERNEL] [ 416.019291] usb 1-1.2.2: New USB device found, idVendor=1bcf, idProduct=2281
10-06-52-038| [ KERNEL] [ 416.019315] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
10-06-52-046| [ KERNEL] [ 416.019330] usb 1-1.2.2: Product: SPCA2281 Web Camera
10-06-52-047| [ KERNEL] [ 416.019345] usb 1-1.2.2: Manufacturer: Sunplus IT Co
10-07-14-354| [ gm] [ 438.378792] Standby monitor.
We haven't received your log. Please, resend it. In message Subject field specify work "WTware".
We need full log with connected touchmonitor.
wpmuellner
Thank you aka,
with the new WTware 5.4.56 work the touchmonitor iiyama.
Best regard
Wolfgang
dangermouse
Post by dangermouse »
we also have a touchscreen from iiyama: T2452MTS-B4
Under WTware 5.4.72 one-finger touch (like mouse) works well, but no multi touch. :(
This model supports two-finger gestures (e.g. wipe picture to left/right or zoom in/out with two fingers).
But under WTware these two finger gestures do not work and I could'nt find any setting to enable two-finger gestures. :?
I also googled a lot but coul'dnt find a solution.
How can we get it to work with WTware?
Regards
dangermouse
WTware does not support multitouch :(
