No sound and no USB redirection with Raspberry Pi 2
xybrek
Post by xybrek »
Hello, I just installed WTware on my Raspberry Pi 2, it works fine however the problem is there is no sound and no USB redirection.
I tried to plug a USB flash drive into Raspberry PI 2 port and the Remote Windows machine cannot detect the USB.
What configuration is needed to make USB work and also make sound work.
Re: No sound and no USB redirection with Raspberry Pi 2
In terminal configuration file specify
disk=usb
Onboard sound at RPi should be enabled in config.txt at SD card now. To edit config.txt, you can use a browser, http://[terminal-ip]/
dtparam=audio=on
and the sound option should be on
sound=on
xybrek
Post by xybrek »
Thanks aka, it works now.
dwillis75
Post by dwillis75 »
I'm having almost the exact same problem, except that I have dtparam=audio=on uncommented in my config.txt. I can get audio to work, but only if I first run the Sound Test from the terminal information page. If I simply log in from the RPi 3, I can move the sound control, but no sound comes through until I run the test.
1. Reboot.
2. Log into Windows. Play sound from Windows. Can you hear it?
3. Run Test Sound. Can you hear it?
4. Play sound from Windows again. Can you hear it?
5. Take terminal log http://wtware.com/logs.html and send it to support@wtware.com
