Audio Jack output when using HDMI connection
fvalois
Post by fvalois »
I would like to know how to activate the audio jack when using an HDMI connection. When a HDMI cable is plugged in, the audio is always passed to the HDMI device.
Normally on Raspbian, i would use amixer to force the ouput on the audio jack, but i don't see any option in WTware configuration files.
Thanks.
Re: Audio Jack output when using HDMI connection
In WTware, additional digits can be specified in sound= parameter. Here is manual: http://wtware.com/docs5/sound.html
It helps to switch sound from HDMI to external USB sound card, for example. But it does not help me to get sound on Raspberry jack.
Please, tell me, how you get sound to jack on Raspberry?
We fixed jack 3.5mm sound in wtware 5.4.52:
sound=on, amixer:cset numid=3 1
