Error with vnc
Adrien_Tr
Error with vnc
Post by Adrien_Tr »
I try your product with a Raspberry Pi 3 to connect on my RDS Broker 2012. it's works very fine !
but i have a problem when i try to connect him with vnc ...
on my computer i saw a rds session screen for 1 seconde and drop vnc session.
on log :
17-24-37-578| [ gm] [23818.039860] [VNC] Connection from 192.168.0.XXX.
17-24-37-578| [ gm] [23818.041687] [VNC] Client VNC version 8 (RFB 003.008).
17-24-37-578| [ gm] [23818.043551] [VNC] Password ok.
17-24-37-578| [ gm] [23818.060221] [VNC] 7 encodings.
17-24-37-578| [ gm] [23818.060433] [VNC] Encoding 16.
17-24-37-578| [ gm] [23818.060518] [VNC] Encoding 5.
17-24-37-578| [ gm] [23818.060595] [VNC] Encoding 2.
17-24-37-578| [ gm] [23818.060672] [VNC] Encoding 1.
17-24-37-578| [ gm] [23818.060747] [VNC] Encoding 0.
17-24-37-578| [ gm] [23818.060822] [VNC] Encoding -239.
17-24-37-578| [ gm] [23818.060898] [VNC] Encoding -223.
17-24-37-578| [ gm] [23818.060972] [VNC] bits-per-pixel 16, depth 16, big-endian false, true-colour true.
17-24-37-578| [ gm] [23818.061054] [VNC] red-max 0x001f, green-max 0x003f, blue-max 0x001f.
17-24-37-578| [ gm] [23818.061133] [VNC] red-shift 11, green-shift 5, blue-shift 0.
17-24-37-578| [ gm] [23818.061229] [VNC] 16-bit server, 16-bit client.
17-24-37-578| [ gm] [23819.101644] vncserver.cpp ( 817): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-24-37-578| [ gm] [23819.101972] vncserver.cpp ( 932): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-24-37-578| [ gm] [23819.102104] [VNC] Close connection.
17-24-37-579| Connection from wtc.exe at 192.168.0.XXX.
i try a few client vnc ... same results
Somebody have a idea ?
Re: Error with vnc
What VNC clients did you try?
Adrien_Tr
Re: Error with vnc
Post by Adrien_Tr »
hello,
i try UltraVNC, vnc viewer (official client), Dameware client...
same result ..
Re: Error with vnc
Looks very strange. Please, try 5.4.46 wtware version and send full log to aka@pxe.ru
Did you try VNC clients FROM different windows machines?
Adrien_Tr
Re: Error with vnc
Post by Adrien_Tr »
Yes, i try to do with a other computer and other client vnc. same result.
with ultra vnc when i try to connect and i have this message:
http://hpics.li/8abdc92
and Dameware client i saw 1 seconde a remote screen and drop without message.
i try with last version same problem i send you by mail a full log.
Re: Error with vnc
Please, try wtware 5.4.50.
Adrien_Tr
Re: Error with vnc
Post by Adrien_Tr »
It's working !
Thank you very much !
