OpenVPN RPi 3
Tks2k4
OpenVPN RPi 3
Post by Tks2k4 »
Error on openvpn config, no tun device
08-55-54-083| [        initrd] [    7.944037] Load ethernet drivers.
08-55-54-083| [        initrd] [    7.944122] modprobe smsc95xx.
08-55-54-083| [        KERNEL] [    7.958929] smsc95xx v1.0.4
08-55-54-083| [        KERNEL] [    8.020787] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:f1:c1:39
08-55-54-083| [        KERNEL] [    8.021009] usbcore: registered new interface driver smsc95xx
08-55-54-083| [        KERNEL] [    8.079639] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
08-55-54-083| [        KERNEL] [    9.546491] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
08-55-54-083| Send broadcast WTCU discover.
08-55-54-083| [        initrd] [    9.576838] Run OpenVPN with user config configs/openvpn.cfg.
08-55-54-083| [        initrd] [    9.580584] Unpack /bootmedia/packages/pi2-xnet.
08-55-54-083| [        initrd] [    9.887398] +--- Executing "/sbin/modprobe tun"
08-55-54-083| [        initrd] [    9.891481] +- Errorlevel: 1, output:
08-55-54-083| | modprobe: module tun not found in modules.dep
08-55-54-083| [        initrd] [    9.891787] +------------------------
08-55-54-083| [        initrd] [    9.891863] ERROR: INTERNAL ERROR
08-55-54-083| WTware v.5.4.40/RPi
08-55-54-083| File: initrdConfig.cpp
08-55-54-083| Line: 340
08-55-54-083| Please, report this information to WTware tech support.
Re: OpenVPN RPi 3
Sorry, not implemented on Raspberry now.
Tks2k4
Re: OpenVPN RPi 3
Post by Tks2k4 »
is there any information when OpenVPN will be implemented on RPi3?. Thank You
Re: OpenVPN RPi 3
No.
Re: OpenVPN RPi 3
OpenVPN should work in wtware 5.4.46 on Raspberry. Here is manual: http://wtware.com/docs5/openvpn.html
Tks2k4
Re: OpenVPN RPi 3
Post by Tks2k4 »
Wow, thanks for the update, Working great...
Guest
Re: OpenVPN RPi 3
Post by Guest »
aka, you're the man!
