Network Layer Authentication / Local Password Prompt
J1mbo
Post by J1mbo »
Hi Support
Is it possible to disable the local username/password prompt, so that the users only see the RDP logon screen?
Many thanks
Re: Network Layer Authentication / Local Password Prompt
Yes, you'll see WTware window with local username/password prompt when NLA is working on server. Turn it off.
http://wtware.com/win/nla.html
J1mbo
Post by J1mbo »
OK thanks.
