MS VDI / RDWEB
johanbroersma
MS VDI / RDWEB
Post by johanbroersma »
Good day all,
I am trying to figure out how to configure the WTWARE to use a virtual desktop normally presented to a user via RDWEB (The MS website for remoteApp and VDI).
I know I am suppose to use the loadbalanceinfo parameter, but I cannot figure out how to actually implement this in the configuration file.
Basically our clients now connect to a webpage (http://webpage.xyz/rdweb) which they then authenicate on and are presented with their remoteApp or virtual desktops (this is a microsoft default page - much like citrix). When opening a virtual desktop there is an RDP connection made through a session broker to the virtual desktop.
I would like to use the raspberries with a local SD card that it will boot from that has the configuration stored on it (not using DHCP option) so that I do not need to make modifications to the server.
Any help is appreciated.
Thank you,
Johan
Re: MS VDI / RDWEB
http://forum.wtware.com/viewtopic.php?f=11&t=47370
WTware does not work with TS gateway.
Why do you use TS gateway?
