RDP error
skynet
RDP error
Post by skynet »
HI Aka
1 have a problem. My raspberry pi is connected to a Windows 2012 server. The problem is that the Firefox browser will be black. See the attached picture.
Do you have any idea what is this?
Thx
SkyNet
Browser error.jpg (57.72 KiB) Viewed 26573 times
Re: RDP error
Does Firefox work well when connected with mstsc.exe to the same server with the same username and 16 bit color?
I need terminal log file. From another Windows-computer in web-browser print terminal IP in address line and save log. Send me terminal log to license@wtware.com
Guest
Re: RDP error
Post by Guest »
Hi Aka
I sent the logfile
SkyNet
Re: RDP error
First of all, you're using old 5.4.18 version for Pi 3. Download and install new version.
And tell me about work in mstsc.exe.
skynet
Re: RDP error
Post by skynet »
I would like change a terminal versions, but I don't know how to do it. Please help me.
Re: RDP error
Now WTware does not support remote update.You have to eject your SD and rewrite it.
Before rewriting, backup all files in 'configs' directory on SD. And put them back after you write new WTware version on SD.
skynet
Re: RDP error
Post by skynet »
I changed a terminal versions, but the problem same us (the Firefox browser will be black). Do you have other ideads?
Re: RDP error
Please, go to another Windows machine (not server console) and run mstsc.exe
Connect to the same server and run firefox. Does it work well?
skynet
Re: RDP error
Post by skynet »
J1mbo
Re: RDP error
Post by J1mbo »
To summarise - start firefox in safe mode (hold shift) then in advanced options, clear the option to use hardware acceleration. Restart Firefox.
