Printing on terminal
hbbst
Post by hbbst »
Dear Aka,
I use your latest, 5.4.24 kernel and I have problem with printing on terminal.
I found your guide how to setup printing, but it doesn't work.
I use VMWare ESX6 and I have a running Windows 2012 R2.
I made these steps:
1. I plug the printer into the server and I install it. It works correctly.
2. I wrote down (CTRL+C of course) the driver name.
3. Unplug USB from server, plug into Raspberry.
4. I insert a line into the config file of Raspberry: rdp_printer=HP LaserJet A4/Letter PCL6 Class Driver
5. Boot the terminal, and it logs into the server correctly.
On the terminal's screen the printer what I installed onto the sever is grayed out, because I unplug it. It is OK.
Another printer appears, it's name is the driver name what I enter into the "rdp_printer", and a (redirected xxx) words after it. (HP LaserJet A4/Letter PCL6 Class Driver (ÍRedirected x) )
And when I try to print a test page the system says "Successfully sent" but the printer don't work.
What could be the problem?
I send the boot's log file maybe it is helpful:
14-22-38-416| [TFTP] Got RRQ, 48 bytes.
14-22-38-416| [TFTP] 00000000: 35 2e 34 2e 32 34 5c 6b 65 72 6e 65 6c 37 2e 69
14-22-38-448| [TFTP] 00000010: 6d 67 00 6f 63 74 65 74 00 74 69 6d 65 6f 75 74
14-22-38-448| [TFTP] 00000020: 00 35 00 62 6c 6b 73 69 7a 65 00 31 34 36 38 00
14-22-38-448| [TFTP] Request block size 1468, forced to 1460 (interface MTU 1500).
14-22-38-448| [TFTP] Requests file "5.4.24\kernel7.img". Tsize is not requested, blksize 1460 bytes.
14-22-38-448| [TFTP] Sending OASK (blksize 1460).
14-22-38-448| [TFTP] Transfer of file "5.4.24\kernel7.img" completed.
14-22-38-448| [TFTP] Connection closed.
14-22-38-448| [TFTP] Got RRQ, 73 bytes.
14-22-38-448| [TFTP] 00000000: 57 54 77 61 72 65 20 76 2e 35 2e 34 2e 32 34 20
14-22-38-448| [TFTP] 00000010: 61 74 20 42 38 3a 32 37 3a 45 42 3a 39 33 3a 31
14-22-38-448| [TFTP] 00000020: 42 3a 34 37 2c 20 64 68 63 70 3d 31 39 32 2e 31
14-22-38-448| [TFTP] 00000030: 36 38 2e 31 2e 32 35 32 2c 20 70 6c 61 74 66 6f
14-22-38-448| [TFTP] 00000040: 72 6d 3d 50 69 32 42 2e 00
14-22-38-448| [TFTP] WTware v.5.4.24 found at host [], mac B8:27:EB:93:1B:47.
14-22-38-479| [TFTP] Sending WTware TFTP version.
14-22-38-479| [TFTP] Got RRQ, 45 bytes.
14-22-38-494| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 6c 69 73 74 2e 77 74
14-22-38-494| [TFTP] 00000010: 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
14-22-38-541| [TFTP] 00000020: 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-22-38-541| [TFTP] Request block size 1400, interface MTU 1500.
14-22-38-557| [TFTP] Requests file "Everyone\list.wtc". Tsize is requested, blksize 1400 bytes.
14-22-38-557| [TFTP] Sending OASK (tsize 1209, blksize 1400).
14-22-38-557| [TFTP] Transfer of file "Everyone\list.wtc" completed.
14-22-38-557| [TFTP] Connection closed.
14-22-38-557| [TFTP] Got RRQ, 66 bytes.
14-22-38-557| [TFTP] 00000000: 54 65 72 6d 69 6e 61 6c 73 5c 42 38 2e 32 37 2e
14-22-38-557| [TFTP] 00000010: 45 42 2e 39 33 2e 31 42 2e 34 37 5c 63 6f 6e 66
14-22-38-557| [TFTP] 00000020: 69 67 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
14-22-38-557| [TFTP] 00000030: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
14-22-38-557| [TFTP] 00000040: 30 00
14-22-38-557| [TFTP] Request block size 1400, interface MTU 1500.
14-22-38-557| [TFTP] Requests file "Terminals\B8.27.EB.93.1B.47\config.wtc". Tsize is requested, blksize 1400 bytes.
14-22-38-557| [TFTP] Sending OASK (tsize 164, blksize 1400).
14-22-38-557| [TFTP] Transfer of file "Terminals\B8.27.EB.93.1B.47\config.wtc" completed.
14-22-38-557| [TFTP] Got RRQ, 44 bytes.
14-22-38-557| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 61 6c 6c 2e 77 74 63
14-22-38-557| [TFTP] 00000010: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
14-22-38-557| [TFTP] 00000020: 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-22-38-557| [TFTP] Requests file "Everyone\all.wtc". Tsize is requested, blksize 1400 bytes.
14-22-38-557| [TFTP] Sending OASK (tsize 100, blksize 1400).
14-22-38-557| [TFTP] Transfer of file "Everyone\all.wtc" completed.
14-22-38-557| [TFTP] Got RRQ, 47 bytes.
14-22-38-557| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 77 74 77 61 72 65 2e
14-22-38-557| [TFTP] 00000010: 6c 69 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00
14-22-38-557| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-22-38-557| [TFTP] Requests file "Everyone\wtware.lic". Tsize is requested, blksize 1400 bytes.
14-22-38-557| [TFTP] Sending OASK (tsize 281, blksize 1400).
14-22-38-557| [TFTP] Transfer of file "Everyone\wtware.lic" completed.
14-22-38-557| [TFTP] Got RRQ, 90 bytes.
14-22-38-557| [TFTP] 00000000: 57 54 77 61 72 65 20 76 2e 35 2e 34 2e 32 34 20
14-22-38-557| [TFTP] 00000010: 61 74 20 42 38 3a 32 37 3a 45 42 3a 39 33 3a 31
14-22-38-557| [TFTP] 00000020: 42 3a 34 37 5b 77 74 77 42 38 32 37 45 42 39 33
14-22-38-557| [TFTP] 00000030: 31 42 34 37 5d 2c 20 64 68 63 70 3d 31 39 32 2e
14-22-38-557| [TFTP] 00000040: 31 36 38 2e 31 2e 32 35 32 2c 20 70 6c 61 74 66
14-22-38-557| [TFTP] 00000050: 6f 72 6d 3d 50 69 32 42 2e 00
14-22-38-557| [TFTP] WTware v.5.4.24 found at host [wtwB827EB931B47], mac B8:27:EB:93:1B:47.
14-22-38-588| [TFTP] Sending WTware TFTP version.
14-22-38-604| [TFTP] Got RRQ, 63 bytes.
14-22-38-604| [TFTP] 00000000: 35 2e 34 2e 32 34 5c 70 69 32 5c 6c 6f 63 61 6c
14-22-38-604| [TFTP] 00000010: 62 6f 6f 74 5c 70 61 63 6b 61 67 65 73 5c 70 72
14-22-38-604| [TFTP] 00000020: 69 6e 74 00 6f 63 74 65 74 00 74 73 69 7a 65 00
14-22-38-604| [TFTP] 00000030: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-22-38-604| [TFTP] Request block size 1400, interface MTU 1500.
14-22-38-604| [TFTP] Requests file "5.4.24\pi2\localboot\packages\print". Tsize is requested, blksize 1400 bytes.
14-22-38-604| [TFTP] Sending OASK (tsize 751935, blksize 1400).
14-22-38-604| [TFTP] Transfer of file "5.4.24\pi2\localboot\packages\print" completed.
14-22-38-604| [TFTP] Connection closed.
14-32-56-493| [TFTP] Got RRQ, 48 bytes.
14-32-56-493| [TFTP] 00000000: 35 2e 34 2e 32 34 5c 6b 65 72 6e 65 6c 37 2e 69
14-32-56-493| [TFTP] 00000010: 6d 67 00 6f 63 74 65 74 00 74 69 6d 65 6f 75 74
14-32-56-493| [TFTP] 00000020: 00 35 00 62 6c 6b 73 69 7a 65 00 31 34 36 38 00
14-32-56-493| [TFTP] Request block size 1468, forced to 1460 (interface MTU 1500).
14-32-56-493| [TFTP] Requests file "5.4.24\kernel7.img". Tsize is not requested, blksize 1460 bytes.
14-32-56-493| [TFTP] Sending OASK (blksize 1460).
14-33-06-806| [TFTP] Transfer of file "5.4.24\kernel7.img" completed.
14-33-06-806| [TFTP] Connection closed.
14-33-20-073| [TFTP] Got RRQ, 73 bytes.
14-33-20-073| [TFTP] 00000000: 57 54 77 61 72 65 20 76 2e 35 2e 34 2e 32 34 20
14-33-20-073| [TFTP] 00000010: 61 74 20 42 38 3a 32 37 3a 45 42 3a 39 33 3a 31
14-33-20-073| [TFTP] 00000020: 42 3a 34 37 2c 20 64 68 63 70 3d 31 39 32 2e 31
14-33-20-073| [TFTP] 00000030: 36 38 2e 31 2e 32 35 32 2c 20 70 6c 61 74 66 6f
14-33-20-073| [TFTP] 00000040: 72 6d 3d 50 69 32 42 2e 00
14-33-20-073| [TFTP] WTware v.5.4.24 found at host [], mac B8:27:EB:93:1B:47.
14-33-20-120| [TFTP] Sending WTware TFTP version.
14-33-20-120| [TFTP] Got RRQ, 45 bytes.
14-33-20-120| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 6c 69 73 74 2e 77 74
14-33-20-135| [TFTP] 00000010: 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
14-33-20-135| [TFTP] 00000020: 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-33-20-135| [TFTP] Request block size 1400, interface MTU 1500.
14-33-20-135| [TFTP] Requests file "Everyone\list.wtc". Tsize is requested, blksize 1400 bytes.
14-33-20-135| [TFTP] Sending OASK (tsize 1209, blksize 1400).
14-33-20-135| [TFTP] Transfer of file "Everyone\list.wtc" completed.
14-33-20-135| [TFTP] Connection closed.
14-33-20-135| [TFTP] Got RRQ, 66 bytes.
14-33-20-135| [TFTP] 00000000: 54 65 72 6d 69 6e 61 6c 73 5c 42 38 2e 32 37 2e
14-33-20-135| [TFTP] 00000010: 45 42 2e 39 33 2e 31 42 2e 34 37 5c 63 6f 6e 66
14-33-20-135| [TFTP] 00000020: 69 67 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
14-33-20-135| [TFTP] 00000030: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
14-33-20-135| [TFTP] 00000040: 30 00
14-33-20-135| [TFTP] Requests file "Terminals\B8.27.EB.93.1B.47\config.wtc". Tsize is requested, blksize 1400 bytes.
14-33-20-135| [TFTP] Sending OASK (tsize 256, blksize 1400).
14-33-20-135| [TFTP] Transfer of file "Terminals\B8.27.EB.93.1B.47\config.wtc" completed.
14-33-20-135| [TFTP] Got RRQ, 44 bytes.
14-33-20-135| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 61 6c 6c 2e 77 74 63
14-33-20-135| [TFTP] 00000010: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
14-33-20-135| [TFTP] 00000020: 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-33-20-135| [TFTP] Requests file "Everyone\all.wtc". Tsize is requested, blksize 1400 bytes.
14-33-20-135| [TFTP] Sending OASK (tsize 100, blksize 1400).
14-33-20-135| [TFTP] Transfer of file "Everyone\all.wtc" completed.
14-33-20-135| [TFTP] Got RRQ, 47 bytes.
14-33-20-135| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 77 74 77 61 72 65 2e
14-33-20-135| [TFTP] 00000010: 6c 69 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00
14-33-20-135| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-33-20-135| [TFTP] Requests file "Everyone\wtware.lic". Tsize is requested, blksize 1400 bytes.
14-33-20-135| [TFTP] Sending OASK (tsize 281, blksize 1400).
14-33-20-135| [TFTP] Transfer of file "Everyone\wtware.lic" completed.
14-33-20-370| [TFTP] Got RRQ, 90 bytes.
14-33-20-385| [TFTP] 00000000: 57 54 77 61 72 65 20 76 2e 35 2e 34 2e 32 34 20
14-33-20-401| [TFTP] 00000010: 61 74 20 42 38 3a 32 37 3a 45 42 3a 39 33 3a 31
14-33-20-401| [TFTP] 00000020: 42 3a 34 37 5b 77 74 77 42 38 32 37 45 42 39 33
14-33-20-401| [TFTP] 00000030: 31 42 34 37 5d 2c 20 64 68 63 70 3d 31 39 32 2e
14-33-20-401| [TFTP] 00000040: 31 36 38 2e 31 2e 32 35 32 2c 20 70 6c 61 74 66
14-33-20-401| [TFTP] 00000050: 6f 72 6d 3d 50 69 32 42 2e 00
14-33-20-401| [TFTP] WTware v.5.4.24 found at host [wtwB827EB931B47], mac B8:27:EB:93:1B:47.
14-33-20-448| [TFTP] Sending WTware TFTP version.
14-33-20-448| [TFTP] Got RRQ, 63 bytes.
14-33-20-448| [TFTP] 00000000: 35 2e 34 2e 32 34 5c 70 69 32 5c 6c 6f 63 61 6c
14-33-20-448| [TFTP] 00000010: 62 6f 6f 74 5c 70 61 63 6b 61 67 65 73 5c 70 72
14-33-20-448| [TFTP] 00000020: 69 6e 74 00 6f 63 74 65 74 00 74 73 69 7a 65 00
14-33-20-448| [TFTP] 00000030: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-33-20-448| [TFTP] Request block size 1400, interface MTU 1500.
14-33-20-448| [TFTP] Requests file "5.4.24\pi2\localboot\packages\print". Tsize is requested, blksize 1400 bytes.
14-33-20-448| [TFTP] Sending OASK (tsize 751935, blksize 1400).
14-33-20-791| [TFTP] Transfer of file "5.4.24\pi2\localboot\packages\print" completed.
14-33-20-791| [TFTP] Connection closed.
14-35-44-317| [TFTP] Got RRQ, 48 bytes.
14-35-44-317| [TFTP] 00000000: 35 2e 34 2e 32 34 5c 6b 65 72 6e 65 6c 37 2e 69
14-35-44-317| [TFTP] 00000010: 6d 67 00 6f 63 74 65 74 00 74 69 6d 65 6f 75 74
14-35-44-317| [TFTP] 00000020: 00 35 00 62 6c 6b 73 69 7a 65 00 31 34 36 38 00
14-35-44-317| [TFTP] Request block size 1468, forced to 1460 (interface MTU 1500).
14-35-44-317| [TFTP] Requests file "5.4.24\kernel7.img". Tsize is not requested, blksize 1460 bytes.
14-35-44-317| [TFTP] Sending OASK (blksize 1460).
14-35-54-725| [TFTP] Transfer of file "5.4.24\kernel7.img" completed.
14-35-54-725| [TFTP] Connection closed.
14-36-07-523| [TFTP] Got RRQ, 73 bytes.
14-36-07-538| [TFTP] 00000000: 57 54 77 61 72 65 20 76 2e 35 2e 34 2e 32 34 20
14-36-07-538| [TFTP] 00000010: 61 74 20 42 38 3a 32 37 3a 45 42 3a 39 33 3a 31
14-36-07-569| [TFTP] 00000020: 42 3a 34 37 2c 20 64 68 63 70 3d 31 39 32 2e 31
14-36-07-569| [TFTP] 00000030: 36 38 2e 31 2e 32 35 32 2c 20 70 6c 61 74 66 6f
14-36-07-569| [TFTP] 00000040: 72 6d 3d 50 69 32 42 2e 00
14-36-07-569| [TFTP] WTware v.5.4.24 found at host [], mac B8:27:EB:93:1B:47.
14-36-07-601| [TFTP] Sending WTware TFTP version.
14-36-07-616| [TFTP] Got RRQ, 45 bytes.
14-36-07-616| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 6c 69 73 74 2e 77 74
14-36-07-632| [TFTP] 00000010: 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
14-36-07-632| [TFTP] 00000020: 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-36-07-632| [TFTP] Request block size 1400, interface MTU 1500.
14-36-07-632| [TFTP] Requests file "Everyone\list.wtc". Tsize is requested, blksize 1400 bytes.
14-36-07-632| [TFTP] Sending OASK (tsize 1209, blksize 1400).
14-36-07-632| [TFTP] Transfer of file "Everyone\list.wtc" completed.
14-36-07-649| [TFTP] Connection closed.
14-36-07-649| [TFTP] Got RRQ, 66 bytes.
14-36-07-649| [TFTP] 00000000: 54 65 72 6d 69 6e 61 6c 73 5c 42 38 2e 32 37 2e
14-36-07-649| [TFTP] 00000010: 45 42 2e 39 33 2e 31 42 2e 34 37 5c 63 6f 6e 66
14-36-07-649| [TFTP] 00000020: 69 67 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
14-36-07-649| [TFTP] 00000030: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
14-36-07-649| [TFTP] 00000040: 30 00
14-36-07-649| [TFTP] Request block size 1400, interface MTU 1500.
14-36-07-649| [TFTP] Requests file "Terminals\B8.27.EB.93.1B.47\config.wtc". Tsize is requested, blksize 1400 bytes.
14-36-07-649| [TFTP] Sending OASK (tsize 256, blksize 1400).
14-36-07-649| [TFTP] Transfer of file "Terminals\B8.27.EB.93.1B.47\config.wtc" completed.
14-36-07-649| [TFTP] Got RRQ, 44 bytes.
14-36-07-649| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 61 6c 6c 2e 77 74 63
14-36-07-649| [TFTP] 00000010: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
14-36-07-649| [TFTP] 00000020: 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-36-07-649| [TFTP] Requests file "Everyone\all.wtc". Tsize is requested, blksize 1400 bytes.
14-36-07-649| [TFTP] Sending OASK (tsize 100, blksize 1400).
14-36-07-649| [TFTP] Transfer of file "Everyone\all.wtc" completed.
14-36-07-649| [TFTP] Got RRQ, 47 bytes.
14-36-07-649| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 77 74 77 61 72 65 2e
14-36-07-649| [TFTP] 00000010: 6c 69 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00
14-36-07-649| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-36-07-649| [TFTP] Requests file "Everyone\wtware.lic". Tsize is requested, blksize 1400 bytes.
14-36-07-649| [TFTP] Sending OASK (tsize 281, blksize 1400).
14-36-07-649| [TFTP] Transfer of file "Everyone\wtware.lic" completed.
14-36-07-819| [TFTP] Got RRQ, 90 bytes.
14-36-07-835| [TFTP] 00000000: 57 54 77 61 72 65 20 76 2e 35 2e 34 2e 32 34 20
14-36-07-851| [TFTP] 00000010: 61 74 20 42 38 3a 32 37 3a 45 42 3a 39 33 3a 31
14-36-07-866| [TFTP] 00000020: 42 3a 34 37 5b 77 74 77 42 38 32 37 45 42 39 33
14-36-07-866| [TFTP] 00000030: 31 42 34 37 5d 2c 20 64 68 63 70 3d 31 39 32 2e
14-36-07-866| [TFTP] 00000040: 31 36 38 2e 31 2e 32 35 32 2c 20 70 6c 61 74 66
14-36-07-866| [TFTP] 00000050: 6f 72 6d 3d 50 69 32 42 2e 00
14-36-07-866| [TFTP] WTware v.5.4.24 found at host [wtwB827EB931B47], mac B8:27:EB:93:1B:47.
14-36-07-913| [TFTP] Sending WTware TFTP version.
14-36-07-929| [TFTP] Got RRQ, 63 bytes.
14-36-07-944| [TFTP] 00000000: 35 2e 34 2e 32 34 5c 70 69 32 5c 6c 6f 63 61 6c
14-36-07-944| [TFTP] 00000010: 62 6f 6f 74 5c 70 61 63 6b 61 67 65 73 5c 70 72
14-36-07-944| [TFTP] 00000020: 69 6e 74 00 6f 63 74 65 74 00 74 73 69 7a 65 00
14-36-07-944| [TFTP] 00000030: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
14-36-07-944| [TFTP] Request block size 1400, interface MTU 1500.
14-36-07-944| [TFTP] Requests file "5.4.24\pi2\localboot\packages\print". Tsize is requested, blksize 1400 bytes.
14-36-07-960| [TFTP] Sending OASK (tsize 751935, blksize 1400).
14-36-08-241| [TFTP] Transfer of file "5.4.24\pi2\localboot\packages\print" completed.
14-36-08-241| [TFTP] Connection closed.
Re: Printing on terminal
Please, attach terminal log file, not TFTP log.
You can Save it from Wtcenter. Make sure that you pressed the button on next screen:
Or terminal log can be saved from another windows-computer. Enter terminal IP in browser address line.
hbbst
Post by hbbst »
Hy Aka!
Here is the log file: (usblp0: removed repeats continuously... )
11-24-48-227| [TFTP] Got RRQ, 48 bytes.
11-24-48-259| [TFTP] 00000000: 35 2e 34 2e 32 34 5c 6b 65 72 6e 65 6c 37 2e 69
11-24-48-259| [TFTP] 00000010: 6d 67 00 6f 63 74 65 74 00 74 69 6d 65 6f 75 74
11-24-48-290| [TFTP] 00000020: 00 35 00 62 6c 6b 73 69 7a 65 00 31 34 36 38 00
11-24-48-290| [TFTP] Request block size 1468, forced to 1460 (interface MTU 1500).
11-24-48-337| [TFTP] Requests file "5.4.24\kernel7.img". Tsize is not requested, blksize 1460 bytes.
11-24-48-337| [TFTP] Sending OASK (blksize 1460).
11-24-58-541| [TFTP] Transfer of file "5.4.24\kernel7.img" completed.
11-24-58-557| [TFTP] Connection closed.
11-25-11-730| [TFTP] Got RRQ, 73 bytes.
11-25-11-730| [TFTP] 00000000: 57 54 77 61 72 65 20 76 2e 35 2e 34 2e 32 34 20
11-25-11-761| [TFTP] 00000010: 61 74 20 42 38 3a 32 37 3a 45 42 3a 39 33 3a 31
11-25-11-761| [TFTP] 00000020: 42 3a 34 37 2c 20 64 68 63 70 3d 31 39 32 2e 31
11-25-11-808| [TFTP] 00000030: 36 38 2e 31 2e 32 35 32 2c 20 70 6c 61 74 66 6f
11-25-11-808| [TFTP] 00000040: 72 6d 3d 50 69 32 42 2e 00
11-25-11-839| [TFTP] WTware v.5.4.24 found at host [], mac B8:27:EB:93:1B:47.
11-25-11-933| [TFTP] Sending WTware TFTP version.
11-25-11-949| [TFTP] Got RRQ, 45 bytes.
11-25-11-980| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 6c 69 73 74 2e 77 74
11-25-12-121| [TFTP] 00000010: 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
11-25-12-168| [TFTP] 00000020: 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
11-25-12-168| [TFTP] Request block size 1400, interface MTU 1500.
11-25-12-199| [TFTP] Requests file "Everyone\list.wtc". Tsize is requested, blksize 1400 bytes.
11-25-12-199| [TFTP] Sending OASK (tsize 1209, blksize 1400).
11-25-12-246| [TFTP] Transfer of file "Everyone\list.wtc" completed.
11-25-12-246| [TFTP] Connection closed.
11-25-12-293| [TFTP] Got RRQ, 66 bytes.
11-25-12-293| [TFTP] 00000000: 54 65 72 6d 69 6e 61 6c 73 5c 42 38 2e 32 37 2e
11-25-12-324| [TFTP] 00000010: 45 42 2e 39 33 2e 31 42 2e 34 37 5c 63 6f 6e 66
11-25-12-324| [TFTP] 00000020: 69 67 2e 77 74 63 00 6f 63 74 65 74 00 74 73 69
11-25-12-355| [TFTP] 00000030: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
11-25-12-355| [TFTP] 00000040: 30 00
11-25-12-402| [TFTP] Request block size 1400, interface MTU 1500.
11-25-12-402| [TFTP] Requests file "Terminals\B8.27.EB.93.1B.47\config.wtc". Tsize is requested, blksize 1400 bytes.
11-25-12-433| [TFTP] Sending OASK (tsize 256, blksize 1400).
11-25-12-433| [TFTP] Transfer of file "Terminals\B8.27.EB.93.1B.47\config.wtc" completed.
11-25-12-480| [TFTP] Connection closed.
11-25-12-480| [TFTP] Got RRQ, 44 bytes.
11-25-12-511| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 61 6c 6c 2e 77 74 63
11-25-12-511| [TFTP] 00000010: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
11-25-12-543| [TFTP] 00000020: 6c 6b 73 69 7a 65 00 31 34 30 30 00
11-25-12-543| [TFTP] Request block size 1400, interface MTU 1500.
11-25-12-590| [TFTP] Requests file "Everyone\all.wtc". Tsize is requested, blksize 1400 bytes.
11-25-12-590| [TFTP] Sending OASK (tsize 100, blksize 1400).
11-25-12-621| [TFTP] Transfer of file "Everyone\all.wtc" completed.
11-25-12-621| [TFTP] Connection closed.
11-25-12-668| [TFTP] Got RRQ, 47 bytes.
11-25-12-668| [TFTP] 00000000: 45 76 65 72 79 6f 6e 65 5c 77 74 77 61 72 65 2e
11-25-12-730| [TFTP] 00000010: 6c 69 63 00 6f 63 74 65 74 00 74 73 69 7a 65 00
11-25-12-730| [TFTP] 00000020: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
11-25-12-808| [TFTP] Request block size 1400, interface MTU 1500.
11-25-12-808| [TFTP] Requests file "Everyone\wtware.lic". Tsize is requested, blksize 1400 bytes.
11-25-12-886| [TFTP] Sending OASK (tsize 281, blksize 1400).
11-25-12-886| [TFTP] Transfer of file "Everyone\wtware.lic" completed.
11-25-12-918| [TFTP] Connection closed.
11-25-12-918| [TFTP] Got RRQ, 90 bytes.
11-25-12-996| [TFTP] 00000000: 57 54 77 61 72 65 20 76 2e 35 2e 34 2e 32 34 20
11-25-12-996| [TFTP] 00000010: 61 74 20 42 38 3a 32 37 3a 45 42 3a 39 33 3a 31
11-25-13-043| [TFTP] 00000020: 42 3a 34 37 5b 77 74 77 42 38 32 37 45 42 39 33
11-25-13-058| [TFTP] 00000030: 31 42 34 37 5d 2c 20 64 68 63 70 3d 31 39 32 2e
11-25-13-121| [TFTP] 00000040: 31 36 38 2e 31 2e 32 35 32 2c 20 70 6c 61 74 66
11-25-13-121| [TFTP] 00000050: 6f 72 6d 3d 50 69 32 42 2e 00
11-25-13-168| [TFTP] WTware v.5.4.24 found at host [wtwB827EB931B47], mac B8:27:EB:93:1B:47.
11-25-13-309| [TFTP] Sending WTware TFTP version.
11-25-13-309| [TFTP] Got RRQ, 63 bytes.
11-25-13-402| [TFTP] 00000000: 35 2e 34 2e 32 34 5c 70 69 32 5c 6c 6f 63 61 6c
11-25-13-402| [TFTP] 00000010: 62 6f 6f 74 5c 70 61 63 6b 61 67 65 73 5c 70 72
11-25-13-480| [TFTP] 00000020: 69 6e 74 00 6f 63 74 65 74 00 74 73 69 7a 65 00
11-25-13-480| [TFTP] 00000030: 30 00 62 6c 6b 73 69 7a 65 00 31 34 30 30 00
11-25-13-605| [TFTP] Request block size 1400, interface MTU 1500.
11-25-13-621| [TFTP] Requests file "5.4.24\pi2\localboot\packages\print". Tsize is requested, blksize 1400 bytes.
11-25-13-683| [TFTP] Sending OASK (tsize 751935, blksize 1400).
11-25-13-683| [TFTP] Transfer of file "5.4.24\pi2\localboot\packages\print" completed.
11-25-13-730| [TFTP] Connection closed.
11-27-38-069| WTware v.5.4.24/Pi2 supervisor.
11-27-38-069| WTC listener is active.
11-27-38-069| WTC broadcast listener is active.
11-27-38-069| HTTPd listener is active.
11-27-38-069| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
11-27-38-069| [ KERNEL] [ 0.000000] Linux version 4.1.20 (aka@c12) (gcc version 5.2.1 20151010 (Ubuntu 5.2.1-22ubuntu1) ) #6 SMP PREEMPT Sun Mar 27 19:59:34 SAMT 2016
11-27-38-069| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
11-27-38-069| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
11-27-38-069| [ KERNEL] [ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
11-27-38-069| [ KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3a800000
11-27-38-069| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
11-27-38-069| [ KERNEL] [ 0.000000] On node 0 totalpages: 241664
11-27-38-069| [ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80808a80, node_mem_map ba092000
11-27-38-069| [ KERNEL] [ 0.000000] Normal zone: 1888 pages used for memmap
11-27-38-069| [ KERNEL] [ 0.000000] Normal zone: 0 pages reserved
11-27-38-069| [ KERNEL] [ 0.000000] Normal zone: 241664 pages, LIFO batch:31
11-27-38-069| [ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] enter (93c0->f3003010)
11-27-38-069| [ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
11-27-38-069| [ KERNEL] [ 0.000000] PERCPU: Embedded 10 pages/cpu @ba05c000 s10688 r8192 d22080 u40960
11-27-38-069| [ KERNEL] [ 0.000000] pcpu-alloc: s10688 r8192 d22080 u40960 alloc=10*4096
11-27-38-069| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
11-27-38-069| [ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
11-27-38-069| [ KERNEL] [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1680 bcm2708_fb.fbheight=1050 bcm2709.boardrev=0xa01041 bcm2709.serial=0xd931b47 smsc95xx.macaddr=B8:27:EB:93:1B:47 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 console=ttyAMA0,115200 console=tty1 quiet
11-27-38-069| [ KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
11-27-38-069| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
11-27-38-069| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
11-27-38-069| [ KERNEL] [ 0.000000] Memory: 941276K/966656K available (3439K kernel code, 261K rwdata, 1104K rodata, 3392K init, 347K bss, 17188K reserved, 8192K cma-reserved)
11-27-38-069| [ KERNEL] [ 0.000000] Virtual kernel memory layout:
11-27-38-069| [ KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
11-27-38-069| [ KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
11-27-38-069| [ KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
11-27-38-069| [ KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
11-27-38-069| [ KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
11-27-38-069| [ KERNEL] [ 0.000000] .text : 0x80008000 - 0x80477fc4 (4544 kB)
11-27-38-069| [ KERNEL] [ 0.000000] .init : 0x80478000 - 0x807c8000 (3392 kB)
11-27-38-069| [ KERNEL] [ 0.000000] .data : 0x807c8000 - 0x808096c0 ( 262 kB)
11-27-38-069| [ KERNEL] [ 0.000000] .bss : 0x8080c000 - 0x80862c28 ( 348 kB)
11-27-38-069| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
11-27-38-069| [ KERNEL] [ 0.000000] Preemptible hierarchical RCU implementation.
11-27-38-069| [ KERNEL] [ 0.000000] NR_IRQS:608
11-27-38-069| [ KERNEL] [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
11-27-38-069| [ KERNEL] [ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
11-27-38-069| [ KERNEL] [ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
11-27-38-069| [ KERNEL] [ 0.000030] Switching to timer-based delay loop, resolution 52ns
11-27-38-069| [ KERNEL] [ 0.000244] Console: colour dummy device 80x30
11-27-38-069| [ KERNEL] [ 0.000444] console [tty1] enabled
11-27-38-069| [ KERNEL] [ 0.000472] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
11-27-38-069| [ KERNEL] [ 0.000498] pid_max: default: 32768 minimum: 301
11-27-38-069| [ KERNEL] [ 0.000642] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
11-27-38-069| [ KERNEL] [ 0.000662] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
11-27-38-069| [ KERNEL] [ 0.001727] CPU: Testing write buffer coherency: ok
11-27-38-069| [ KERNEL] [ 0.002304] CPU0: update cpu_capacity 1024
11-27-38-069| [ KERNEL] [ 0.002325] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
11-27-38-069| [ KERNEL] [ 0.002338] [bcm2709_smp_prepare_cpus] enter
11-27-38-069| [ KERNEL] [ 0.002442] Setting up static identity map for 0x8240 - 0x8274
11-27-38-069| [ KERNEL] [ 0.060281] [bcm2709_boot_secondary] cpu:1 started (0) 18
11-27-38-069| [ KERNEL] [ 0.060664] [bcm2709_secondary_init] enter cpu:1
11-27-38-069| [ KERNEL] [ 0.060718] CPU1: update cpu_capacity 1024
11-27-38-069| [ KERNEL] [ 0.060727] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
11-27-38-069| [ KERNEL] [ 0.080232] [bcm2709_boot_secondary] cpu:2 started (0) 16
11-27-38-069| [ KERNEL] [ 0.080533] [bcm2709_secondary_init] enter cpu:2
11-27-38-069| [ KERNEL] [ 0.080563] CPU2: update cpu_capacity 1024
11-27-38-069| [ KERNEL] [ 0.080571] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
11-27-38-069| [ KERNEL] [ 0.100275] [bcm2709_boot_secondary] cpu:3 started (0) 16
11-27-38-069| [ KERNEL] [ 0.100546] [bcm2709_secondary_init] enter cpu:3
11-27-38-069| [ KERNEL] [ 0.100574] CPU3: update cpu_capacity 1024
11-27-38-069| [ KERNEL] [ 0.100581] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
11-27-38-069| [ KERNEL] [ 0.100654] Brought up 4 CPUs
11-27-38-069| [ KERNEL] [ 0.100681] SMP: Total of 4 processors activated (153.60 BogoMIPS).
11-27-38-069| [ KERNEL] [ 0.100691] CPU: All CPU(s) started in HYP mode.
11-27-38-069| [ KERNEL] [ 0.100700] CPU: Virtualization extensions available.
11-27-38-069| [ KERNEL] [ 0.101341] devtmpfs: initialized
11-27-38-069| [ KERNEL] [ 0.123729] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
11-27-38-069| [ KERNEL] [ 0.124336] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
11-27-38-069| [ KERNEL] [ 0.124851] pinctrl core: initialized pinctrl subsystem
11-27-38-069| [ KERNEL] [ 0.125430] NET: Registered protocol family 16
11-27-38-069| [ KERNEL] [ 0.131118] DMA: preallocated 4096 KiB pool for atomic coherent allocations
11-27-38-069| [ KERNEL] [ 0.132133] bcm2709.uart_clock = 3000000
11-27-38-069| [ KERNEL] [ 0.139820] Serial: AMBA PL011 UART driver
11-27-38-069| [ KERNEL] [ 0.140019] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
11-27-38-069| [ KERNEL] [ 0.140434] console [ttyAMA0] enabled
11-27-38-069| [ KERNEL] [ 0.141159] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
11-27-38-069| [ KERNEL] [ 0.221858] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
11-27-38-069| [ KERNEL] [ 0.221907] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
11-27-38-069| [ KERNEL] [ 0.223113] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
11-27-38-069| [ KERNEL] [ 0.223136] bcm2708-dmaengine 3f007000.dma: dma_debug:0
11-27-38-069| [ KERNEL] [ 0.223853] usbcore: registered new interface driver usbfs
11-27-38-069| [ KERNEL] [ 0.224048] usbcore: registered new interface driver hub
11-27-38-069| [ KERNEL] [ 0.224244] usbcore: registered new device driver usb
11-27-38-069| [ KERNEL] [ 0.225273] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-15 14:47
11-27-38-069| [ KERNEL] [ 0.227879] Switched to clocksource arch_sys_counter
11-27-38-069| [ KERNEL] [ 0.245838] NET: Registered protocol family 2
11-27-38-069| [ KERNEL] [ 0.246838] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
11-27-38-069| [ KERNEL] [ 0.246979] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
11-27-38-069| [ KERNEL] [ 0.247171] TCP: Hash tables configured (established 8192 bind 8192)
11-27-38-069| [ KERNEL] [ 0.247290] UDP hash table entries: 512 (order: 2, 16384 bytes)
11-27-38-069| [ KERNEL] [ 0.247357] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
11-27-38-069| [ KERNEL] [ 0.247646] NET: Registered protocol family 1
11-27-38-069| [ KERNEL] [ 2.409356] futex hash table entries: 1024 (order: 4, 65536 bytes)
11-27-38-069| [ KERNEL] [ 2.409590] audit: initializing netlink subsys (disabled)
11-27-38-069| [ KERNEL] [ 2.409731] audit: type=2000 audit(2.399:1): initialized
11-27-38-069| [ KERNEL] [ 2.468712] alg: No test for stdrng (krng)
11-27-38-069| [ KERNEL] [ 2.469683] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
11-27-38-069| [ KERNEL] [ 2.469712] io scheduler noop registered
11-27-38-069| [ KERNEL] [ 2.469765] io scheduler cfq registered (default)
11-27-38-069| [ KERNEL] [ 2.475388] BCM2708FB: allocated DMA memory fac00000
11-27-38-069| [ KERNEL] [ 2.475456] BCM2708FB: allocated DMA channel 0 @ f3007000
11-27-38-069| [ KERNEL] [ 2.496634] Console: switching to colour frame buffer device 210x65
11-27-38-069| [ KERNEL] [ 2.515936] bcm2708_rng_init=bb906000
11-27-38-069| [ KERNEL] [ 3.363466] bcm2835-rng 3f104000.rng: hwrng registered
11-27-38-069| [ KERNEL] [ 3.363664] vc-cma: Videocore CMA driver
11-27-38-069| [ KERNEL] [ 3.363679] vc-cma: vc_cma_base = 0x00000000
11-27-38-069| [ KERNEL] [ 3.363691] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
11-27-38-069| [ KERNEL] [ 3.363701] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
11-27-38-069| [ KERNEL] [ 3.364116] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
11-27-38-069| [ KERNEL] [ 3.366367] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
11-27-38-069| [ KERNEL] [ 3.372169] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
11-27-38-069| [ KERNEL] [ 3.572706] Core Release: 2.80a
11-27-38-069| [ KERNEL] [ 3.572734] Setting default values for core params
11-27-38-069| [ KERNEL] [ 3.572775] Finished setting default values for core params
11-27-38-069| [ KERNEL] [ 3.773339] Using Buffer DMA mode
11-27-38-069| [ KERNEL] [ 3.773365] Periodic Transfer Interrupt Enhancement - disabled
11-27-38-069| [ KERNEL] [ 3.773376] Multiprocessor Interrupt Enhancement - disabled
11-27-38-069| [ KERNEL] [ 3.773387] OTG VER PARAM: 0, OTG VER FLAG: 0
11-27-38-069| [ KERNEL] [ 3.773404] Dedicated Tx FIFOs mode
11-27-38-069| [ KERNEL] [ 3.773967] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
11-27-38-069| [ KERNEL] [ 3.774006] FIQ FSM acceleration enabled for :
11-27-38-069| [ KERNEL] [ 3.774006] Non-periodic Split Transactions
11-27-38-069| [ KERNEL] [ 3.774006] Periodic Split Transactions
11-27-38-069| [ KERNEL] [ 3.774006] High-Speed Isochronous Endpoints
11-27-38-069| [ KERNEL] [ 3.774030] dwc_otg: Microframe scheduler enabled
11-27-38-069| [ KERNEL] [ 3.774097] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80216cb4
11-27-38-069| [ KERNEL] [ 3.774116] WARN::hcd_init_fiq:413: FIQ ASM at 0x80217018 length 36
11-27-38-069| [ KERNEL] [ 3.774134] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb90a000
11-27-38-069| [ KERNEL] [ 3.774180] dwc_otg 3f980000.usb: DWC OTG Controller
11-27-38-069| [ KERNEL] [ 3.774233] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
11-27-38-069| [ KERNEL] [ 3.774282] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
11-27-38-069| [ KERNEL] [ 3.774336] Init: Port Power? op_state=1
11-27-38-069| [ KERNEL] [ 3.774346] Init: Power Port (0)
11-27-38-069| [ KERNEL] [ 3.774599] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
11-27-38-069| [ KERNEL] [ 3.774618] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
11-27-38-069| [ KERNEL] [ 3.774634] usb usb1: Product: DWC OTG Controller
11-27-38-069| [ KERNEL] [ 3.774649] usb usb1: Manufacturer: Linux 4.1.20 dwc_otg_hcd
11-27-38-069| [ KERNEL] [ 3.774664] usb usb1: SerialNumber: 3f980000.usb
11-27-38-069| [ KERNEL] [ 3.775602] hub 1-0:1.0: USB hub found
11-27-38-069| [ KERNEL] [ 3.775671] hub 1-0:1.0: 1 port detected
11-27-38-069| [ KERNEL] [ 3.776344] dwc_otg: FIQ enabled
11-27-38-069| [ KERNEL] [ 3.776363] dwc_otg: NAK holdoff enabled
11-27-38-069| [ KERNEL] [ 3.776373] dwc_otg: FIQ split-transaction FSM enabled
11-27-38-069| [ KERNEL] [ 3.776421] Module dwc_common_port init
11-27-38-069| [ KERNEL] [ 3.779081] bcm2835-cpufreq: min=600000 max=900000
11-27-38-069| [ KERNEL] [ 3.782436] sdhost: log_buf @ bac13000 (fac13000)
11-27-38-069| [ KERNEL] [ 3.877961] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
11-27-38-069| [ KERNEL] [ 3.878393] hidraw: raw HID events driver (C) Jiri Kosina
11-27-38-069| [ KERNEL] [ 3.879300] usbcore: registered new interface driver usbhid
11-27-38-069| [ KERNEL] [ 3.879317] usbhid: USB HID core driver
11-27-38-069| [ KERNEL] [ 3.879733] NET: Registered protocol family 17
11-27-38-069| [ KERNEL] [ 3.879933] Registering SWP/SWPB emulation handler
11-27-38-069| [ KERNEL] [ 3.889016] registered taskstats version 1
11-27-38-069| [ KERNEL] [ 3.889139] vc-sm: Videocore shared memory driver
11-27-38-069| [ KERNEL] [ 3.889161] [vc_sm_connected_init]: start
11-27-38-069| [ KERNEL] [ 3.891309] [vc_sm_connected_init]: end - returning 0
11-27-38-069| [ KERNEL] [ 3.896231] Freeing unused kernel memory: 3392K (80478000 - 807c8000)
11-27-38-069| [ KERNEL] [ 3.926539] mmc0: host does not support reading read-only switch, assuming write-enable
11-27-38-069| [ KERNEL] [ 3.928508] mmc0: new high speed SDHC card at address b368
11-27-38-069| [ KERNEL] [ 3.929189] mmcblk0: mmc0:b368 00000 7.51 GiB
11-27-38-069| [ KERNEL] [ 3.938835] mmcblk0: p1
11-27-38-069| [ hotplug] [ 3.934217] Block device 179:1. No action.
11-27-38-069| [ hotplug] [ 3.934599] Block device 179:0. No action.
11-27-38-069| [ KERNEL] [ 3.968324] Indeed it is in host mode hprt0 = 00021501
11-27-38-069| [ KERNEL] [ 4.147921] usb 1-1: new high-speed USB device number 2 using dwc_otg
11-27-38-069| [ KERNEL] [ 4.148066] Indeed it is in host mode hprt0 = 00001101
11-27-38-069| [ pfac] [ 4.216133] Run /sbin/initrd.
11-27-38-069| [ pfac] [ 4.216268] Ok, PID 512.
11-27-38-069| [ initrd] [ 4.220208] WTware shell v.5.4.24/Pi2
11-27-38-069| [ KERNEL] [ 4.348153] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
11-27-38-069| [ KERNEL] [ 4.348176] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
11-27-38-069| [ KERNEL] [ 4.348843] hub 1-1:1.0: USB hub found
11-27-38-069| [ KERNEL] [ 4.348979] hub 1-1:1.0: 5 ports detected
11-27-38-069| [ KERNEL] [ 4.627904] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
11-27-38-069| [ KERNEL] [ 4.728126] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
11-27-38-069| [ KERNEL] [ 4.728141] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
11-27-38-069| [ KERNEL] [ 4.967906] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
11-27-38-069| [ KERNEL] [ 5.071660] usb 1-1.2: New USB device found, idVendor=062a, idProduct=3688
11-27-38-069| [ KERNEL] [ 5.071675] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11-27-38-069| [ KERNEL] [ 5.071685] usb 1-1.2: Product: USB Device
11-27-38-069| [ KERNEL] [ 5.071696] usb 1-1.2: Manufacturer: Areson Corp.
11-27-38-069| [ KERNEL] [ 5.076845] input: Areson Corp. USB Device as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:062A:3688.0001/input/input0
11-27-38-069| [ KERNEL] [ 5.077360] hid-generic 0003:062A:3688.0001: input,hidraw0: USB HID v1.10 Mouse [Areson Corp. USB Device] on usb-3f980000.usb-1.2/input0
11-27-38-069| [ KERNEL] [ 5.157918] usb 1-1.4: new high-speed USB device number 5 using dwc_otg
11-27-38-069| [ KERNEL] [ 5.258570] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=3817
11-27-38-069| [ KERNEL] [ 5.258588] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
11-27-38-069| [ KERNEL] [ 5.258598] usb 1-1.4: Product: HP LaserJet P2015 Series
11-27-38-069| [ KERNEL] [ 5.258609] usb 1-1.4: Manufacturer: Hewlett-Packard
11-27-38-069| [ KERNEL] [ 5.258619] usb 1-1.4: SerialNumber: 00CNBW7BJ6LL
11-27-38-069| [ KERNEL] [ 5.337906] usb 1-1.5: new high-speed USB device number 6 using dwc_otg
11-27-38-069| [ KERNEL] [ 5.438252] usb 1-1.5: New USB device found, idVendor=413c, idProduct=1010
11-27-38-069| [ KERNEL] [ 5.438268] usb 1-1.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
11-27-38-069| [ KERNEL] [ 5.438279] usb 1-1.5: Product: USB 2.0 Hub [MTT]
11-27-38-069| [ KERNEL] [ 5.438901] hub 1-1.5:1.0: USB hub found
11-27-38-069| [ KERNEL] [ 5.439035] hub 1-1.5:1.0: 4 ports detected
11-27-38-069| [ KERNEL] [ 5.717915] usb 1-1.5.4: new low-speed USB device number 7 using dwc_otg
11-27-38-069| [ KERNEL] [ 5.843136] usb 1-1.5.4: New USB device found, idVendor=413c, idProduct=2110
11-27-38-069| [ KERNEL] [ 5.843151] usb 1-1.5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11-27-38-069| [ KERNEL] [ 5.843161] usb 1-1.5.4: Product: Dell Wired Multimedia Keyboard
11-27-38-069| [ KERNEL] [ 5.843171] usb 1-1.5.4: Manufacturer: Dell
11-27-38-069| [ KERNEL] [ 5.873145] input: Dell Dell Wired Multimedia Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.4/1-1.5.4:1.0/0003:413C:2110.0002/input/input1
11-27-38-069| [ KERNEL] [ 5.928323] hid-generic 0003:413C:2110.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell Wired Multimedia Keyboard] on usb-3f980000.usb-1.5.4/input0
11-27-38-069| [ KERNEL] [ 5.965792] input: Dell Dell Wired Multimedia Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.4/1-1.5.4:1.1/0003:413C:2110.0003/input/input2
11-27-38-069| [ KERNEL] [ 6.018583] hid-generic 0003:413C:2110.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [Dell Dell Wired Multimedia Keyboard] on usb-3f980000.usb-1.5.4/input1
11-27-38-069| [ initrd] [ 6.050867] Load ethernet drivers.
11-27-38-069| [ initrd] [ 6.051049] modprobe smsc95xx.
11-27-38-069| [ KERNEL] [ 6.066515] smsc95xx v1.0.4
11-27-38-069| [ KERNEL] [ 6.086077] usb 1-1.4: USB disconnect, device number 5
11-27-38-069| [ KERNEL] [ 6.133293] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:93:1b:47
11-27-38-069| [ KERNEL] [ 6.133621] usbcore: registered new interface driver smsc95xx
11-27-38-069| [ KERNEL] [ 6.189781] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
11-27-38-069| [ KERNEL] [ 6.317911] usb 1-1.4: new high-speed USB device number 8 using dwc_otg
11-27-38-069| [ KERNEL] [ 6.418622] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=3817
11-27-38-069| [ KERNEL] [ 6.418637] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
11-27-38-069| [ KERNEL] [ 6.418648] usb 1-1.4: Product: HP LaserJet P2015 Series
11-27-38-069| [ KERNEL] [ 6.418658] usb 1-1.4: Manufacturer: Hewlett-Packard
11-27-38-069| [ KERNEL] [ 6.418668] usb 1-1.4: SerialNumber: 00CNBW7BJ6LL
11-27-38-069| [ KERNEL] [ 8.134376] usb 1-1.4: USB disconnect, device number 8
11-27-38-069| [ KERNEL] [ 8.367908] usb 1-1.4: new high-speed USB device number 9 using dwc_otg
11-27-38-069| [ KERNEL] [ 8.468618] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=3817
11-27-38-069| [ KERNEL] [ 8.468635] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
11-27-38-069| [ KERNEL] [ 8.468645] usb 1-1.4: Product: HP LaserJet P2015 Series
11-27-38-069| [ KERNEL] [ 8.468655] usb 1-1.4: Manufacturer: Hewlett-Packard
11-27-38-069| [ KERNEL] [ 8.468665] usb 1-1.4: SerialNumber: 00CNBW7BJ6LL
11-27-38-069| [ KERNEL] [ 8.593795] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
11-27-38-069| [ initrd] [ 9.790302] dhcp: 363 bytes from 192.168.1.252.
11-27-38-069| [ initrd] [ 9.790435] 00000000:000001570000000000110000c0a801fcffffffff004300440157000002010600 ...W................C.D.W......
11-27-38-069| [ initrd] [ 9.790518] 00000020:67458b6b0000000000000000c0a8012cc0a801f200000000b827eb931b470000 gE.k...........,.........'..G..
11-27-38-069| [ initrd] [ 9.790590] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-27-38-069| [ initrd] [ 9.790661] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-27-38-069| [ KERNEL] [ 10.182676] usb 1-1.4: USB disconnect, device number 9
11-27-38-069| [ KERNEL] [ 10.417906] usb 1-1.4: new high-speed USB device number 10 using dwc_otg
11-27-38-069| [ KERNEL] [ 10.518869] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=3817
11-27-38-069| [ KERNEL] [ 10.518884] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
11-27-38-069| [ KERNEL] [ 10.518895] usb 1-1.4: Product: HP LaserJet P2015 Series
11-27-38-069| [ KERNEL] [ 10.518905] usb 1-1.4: Manufacturer: Hewlett-Packard
11-27-38-069| [ KERNEL] [ 10.518915] usb 1-1.4: SerialNumber: 00CNBW7BJ6LL
11-27-38-069| [ KERNEL] [ 10.904476] random: nonblocking pool is initialized
11-27-38-069| [ initrd] [ 11.310261] dhcp: 363 bytes from 192.168.1.252.
11-27-38-069| [ initrd] [ 11.310378] 00000000:000001570000000000110000c0a801fcffffffff004300440157000002010600 ...W................C.D.W......
11-27-38-069| [ initrd] [ 11.310476] 00000020:67458b6b0000000000000000c0a8012cc0a801f200000000b827eb931b470000 gE.k...........,.........'..G..
11-27-38-069| [ initrd] [ 11.310547] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-27-38-069| [ initrd] [ 11.310617] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-27-38-069| [ initrd] [ 11.350105] dhcp: server address 192.168.1.252.
11-27-38-069| [ initrd] [ 11.350224] dhcp: 192.168.1.44/255.255.255.0.
11-27-38-069| [ initrd] [ 11.350298] dhcp: default gateway 192.168.1.254.
11-27-38-069| [ initrd] [ 11.350369] dhcp: DNS 192.168.1.252.
11-27-38-069| [ initrd] [ 11.350441] dhcp: domain shu.local.
11-27-38-069| [ initrd] [ 11.350510] dhcp: TFTP from 066 192.168.1.242.
11-27-38-069| [ initrd] [ 11.350579] dhcp: TFTP 192.168.1.242.
11-27-38-069| [ initrd] [ 11.350646] dhcp: boot file (067) 5.4.24\kernel7.img.
11-27-38-069| [ initrd] [ 11.350717] TFTP binary "5.4.24\", configs prefix "", using "\" slash.
11-27-38-069| Send broadcast WTCU discover.
11-27-38-069| [ initrd] [ 11.448457] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
11-27-38-069| [ initrd] [ 11.448710] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
11-27-38-069| [ initrd] [ 11.448866] USB: 062a:3688 Creative Labs.
11-27-38-069| [ initrd] [ 11.448989] USB: 03f0:3817 Hewlett-Packard LaserJet P2015 series.
11-27-38-069| [ initrd] [ 11.449107] USB: 413c:1010 Dell Computer Corp..
11-27-38-069| [ initrd] [ 11.449222] USB: 413c:2110 Dell Computer Corp..
11-27-38-069| [ initrd] [ 11.449442] TFTP: download file Everyone\list.wtc from 192.168.1.242.
11-27-38-069| [ initrd] [ 11.456722] WTware TFTP v.5.4.24.
11-27-38-069| /--- FILE "/tmp/list.wtc" -----------------------
11-27-38-069| | #
11-27-38-069| | # Include files list.
11-27-38-069| | #
11-27-38-069| | # This way of terminals configuration is meant only for manual
11-27-38-069| | # terminals management. Graphic configurator doesn't read list.wtc,
11-27-38-069| | # doesn't read or edit files from ListIncludes directory. So be careful
11-27-38-069| | # not to configure one terminal in configurator and in list.wtc.
11-27-38-069| | #
11-27-38-069| | # This file uses such syntax:
11-27-38-069| | #
11-27-38-069| | # 01.02.03.04.05.06[([username@][terminalname])] [file [file ...]]] [# note]
11-27-38-069| | #
11-27-38-069| | # Examples:
11-27-38-069| | #
11-27-38-069| | # 02.03.04.05.06.07 file1
11-27-38-069| | #
11-27-38-069| | # It means that terminal with MAC-address 02.03.04.05.06.07
11-27-38-069| | # reads parameters from file ListIncludes/file1.
11-27-38-069| | #
11-27-38-069| | #
11-27-38-069| | # 03.04.05.06.07.08(vasja@) file2
11-27-38-069| | #
11-27-38-069| | # It means that terminal with MAC-address 03.04.05.06.07.08
11-27-38-069| | # reads parameters from file ListIncludes/file2
11-27-38-069| | # and sets user name "vasja" in "Windows login" window.
11-27-38-069| | #
11-27-38-069| | #
11-27-38-069| | # 04.05.06.07.08.09(term5) file6 file7 # John notebook.
11-27-38-069| | #
11-27-38-069| | # It means that terminal with MAC-address 04.05.06.07.08.09
11-27-38-069| | # is named term5, the same as specify clienthostname parameter,
11-27-38-069| | # and it reads parameters from files ListIncludes/file6 and
11-27-38-069| | # ListIncludes/file7.
11-27-38-069| | #
11-27-38-069| | #
11-27-38-069| | # To specify user name using non-latin letters open this file in
11-27-38-069| | # Notepad and save with Encoding: Unicode.
11-27-38-069| | #
11-27-38-069| \----------------------------------------------------
11-27-38-069| [ initrd] [ 11.460591] TFTP: download file Terminals\B8.27.EB.93.1B.47\config.wtc from 192.168.1.242.
11-27-38-069| /--- FILE "/tmp/config.wtc" -----------------------
11-27-38-069| | user=rpi_meo:\x52\x61\x73\x70\x69\x30\x30\x37
11-27-38-069| | rdp_printer=HP LaserJet A4/Letter PCL6 Class Driver
11-27-38-069| | domain=chaos
11-27-38-069| | connection
11-27-38-069| [ initrd] [ 11.463174] TFTP: download file Everyone\all.wtc from 192.168.1.242.
11-27-38-069| /--- FILE "/tmp/all.wtc" -----------------------
11-27-38-069| | [BOM]
11-27-38-069| | server=192.168.1.242
11-27-38-069| | keyboard=hu
11-27-38-069| [ initrd] [ 11.465485] TFTP: download file Everyone\wtware.lic from 192.168.1.242.
11-27-38-069| /--- FILE "/etc/config.compiled" -----------------------
11-27-38-069| [ initrd] [ 11.468612] Hostname: "wtwB827EB931B47".
11-27-38-069| RSH: listener is active.
11-27-38-069| Everyone can control terminal by HTTP.
11-27-38-069| [ gm] [ 11.705441] WTware session manager v.5.4.24/Pi2.
11-27-38-069| [ gm] [ 11.706494] Add keyboard event2: Dell Dell Wired Multimedia Keyboard.
11-27-38-069| [ gm] [ 11.706684] Add keyboard event1: Dell Dell Wired Multimedia Keyboard.
11-27-38-069| [ gm] [ 11.760117] EV_REL flag found. Add mouse event0: Areson Corp. USB Device.
11-27-38-069| [ gm] [ 11.760488] Display mode: 1680x1050, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
11-27-38-069| [ gm] [ 11.772870] Framebuffer device found.
11-27-38-069| [ gm] [ 11.773018] LINELENBYTES 3360
11-27-38-069| [ gm] [ 11.773139] VLEN 3528000
11-27-38-069| [ gm] [ 11.804376] TFTP: download and unpack file 5.4.24\pi2\localboot\packages\print from 192.168.1.242.
11-27-38-069| [ gm] [ 11.808821] WTware TFTP v.5.4.24.
11-27-38-069| [ gm] [ 11.812772] /sbin/printer already exist. Do not overwrite.
11-27-38-069| [ gm] [ 11.818738] /sbin/prnsrvui already exist. Do not overwrite.
11-27-38-069| [ KERNEL] [ 12.231020] usb 1-1.4: USB disconnect, device number 10
11-27-38-069| [ gm] [ 12.334552] Load usb printer driver.
11-27-38-069| [ gm] [ 12.334765] modprobe usblp.
11-27-38-069| [ gm] [ 12.344903] gm-main.cpp ( 525): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-27-38-069| [ KERNEL] [ 12.351694] usbcore: registered new interface driver usblp
11-27-38-069| [ gm] [ 12.351567] Run '/sbin/resolver 0xf72b38 dns [192.168.1.242]', log '', env '', pid ''.
11-27-38-069| [ gm] [ 12.351721] Nobody can control terminal by VNC.
11-27-38-069| [ pfac] [ 12.352497] Run /sbin/resolver 0xf72b38 dns [192.168.1.242].
11-27-38-069| [ pfac] [ 12.352800] Ok, PID 578.
11-27-38-069| [ gm] [ 12.358469] 192.168.1.242 => 192.168.1.242.
11-27-38-069| [ gm] [ 12.358824] Free ram before fork terminal client /sbin/rdpclient (session 1): 928620 Kb.
11-27-38-069| [ gm] [ 12.358972] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
11-27-38-069| [ pfac] [ 12.359790] Run /sbin/rdpclient 1.
11-27-38-069| [ pfac] [ 12.359919] Process pid 578 terminated, status 00000000.
11-27-38-069| [ pfac] [ 12.360061] Ok, PID 579.
11-27-38-069| [ rdpclient 579] [ 12.367153] RDP Terminal Client, WTware v.5.4.24/Pi2, pipe 1, pid 579.
11-27-38-069| [ rdpclient 579] [ 12.369064] Add RDP printer redirection for "HP LaserJet A4/Letter PCL6 Class Driver".
11-27-38-069| [ rdpclient 579] [ 12.369814] Make RDP session with 192.168.1.242, port 3389.
11-27-38-069| [ rdpclient 579] [ 12.369972] Username: "rpi_meo".
11-27-38-069| [ rdpclient 579] [ 12.370167] Password: present.
11-27-38-069| [ rdpclient 579] [ 12.370304] No PIN.
11-27-38-069| [ rdpclient 579] [ 12.370427] Domain: "chaos".
11-27-38-069| [ rdpclient 579] [ 12.370541] No shell.
11-27-38-069| [ rdpclient 579] [ 12.370656] No directory.
11-27-38-069| [ rdpclient 579] [ 12.370772] Window: 1680x1050@16.
11-27-38-069| [ rdpclient 579] [ 12.370890] PFlags 0x0000002F.
11-27-38-069| [ rdpclient 579] [ 12.371006] Keyboard 0000040E:00000000.
11-27-38-069| [ rdpclient 579] [ 12.371120] My hostname "wtwB827EB931B47".
11-27-38-069| [ rdpclient 579] [ 12.371240] TCP: connecting to 192.168.1.242:3389.
11-27-38-069| [ rdpclient 579] [ 12.372311] TCP: connection with 192.168.1.242:3389 established.
11-27-38-069| [ rdpclient 579] [ 12.372467] Turn keepalive on.
11-27-38-069| [ rdpclient 579] [ 12.373482] Free ram after buffers allocation: 928372 KB.
11-27-38-069| [ rdpclient 579] [ 12.396793] Process RDP server certificate.
11-27-38-069| [ rdpclient 579] [ 12.396986] RDP4 encryption.
11-27-38-069| [ KERNEL] [ 12.467916] usb 1-1.4: new high-speed USB device number 11 using dwc_otg
11-27-38-069| [ KERNEL] [ 12.568829] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=3817
11-27-38-069| [ KERNEL] [ 12.568845] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
11-27-38-069| [ KERNEL] [ 12.568855] usb 1-1.4: Product: HP LaserJet P2015 Series
11-27-38-069| [ KERNEL] [ 12.568866] usb 1-1.4: Manufacturer: Hewlett-Packard
11-27-38-069| [ KERNEL] [ 12.568876] usb 1-1.4: SerialNumber: 00CNBW7BJ6LL
11-27-38-069| [ KERNEL] [ 12.570533] usblp 1-1.4:1.0: usblp0: USB Bidirectional printer dev 11 if 0 alt 0 proto 2 vid 0x03F0 pid 0x3817
11-27-38-069| [ rdpclient 579] [ 13.837143] LOGON_EX_LOGONERRORS 0xfffffffb 0x00000001.
11-27-38-069| [ KERNEL] [ 14.279649] usb 1-1.4: USB disconnect, device number 11
11-27-38-069| [ KERNEL] [ 14.280388] usblp0: removed
11-27-38-069| [ KERNEL] [ 14.517912] usb 1-1.4: new high-speed USB device number 12 using dwc_otg
11-27-38-069| [ KERNEL] [ 14.618815] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=3817
11-27-38-069| [ KERNEL] [ 14.618832] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
11-27-38-069| [ KERNEL] [ 14.618844] usb 1-1.4: Product: HP LaserJet P2015 Series
11-27-38-069| [ KERNEL] [ 14.618854] usb 1-1.4: Manufacturer: Hewlett-Packard
11-27-38-069| [ KERNEL] [ 14.618865] usb 1-1.4: SerialNumber: 00CNBW7BJ6LL
11-27-38-069| [ KERNEL] [ 14.620596] usblp 1-1.4:1.0: usblp0: USB Bidirectional printer dev 12 if 0 alt 0 proto 2 vid 0x03F0 pid 0x3817
11-27-38-069| [ KERNEL] [ 16.327497] usb 1-1.4: USB disconnect, device number 12
11-27-38-069| [ KERNEL] [ 16.327851] usblp0: removed
11-27-38-069| [ KERNEL] [ 16.567908] usb 1-1.4: new high-speed USB device number 13 using dwc_otg
11-27-38-069| [ KERNEL] [ 16.668920] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=3817
11-27-38-069| [ KERNEL] [ 16.668938] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
11-27-38-069| [ KERNEL] [ 16.668948] usb 1-1.4: Product: HP LaserJet P2015 Series
11-27-38-069| [ KERNEL] [ 16.668958] usb 1-1.4: Manufacturer: Hewlett-Packard
11-27-38-069| [ KERNEL] [ 16.668968] usb 1-1.4: SerialNumber: 00CNBW7BJ6LL
11-27-38-069| [ KERNEL] [ 16.670659] usblp 1-1.4:1.0: usblp0: USB Bidirectional printer dev 13 if 0 alt 0 proto 2 vid 0x03F0 pid 0x3817
11-27-38-069| [ KERNEL] [ 17.095609] usb 1-1.4: USB disconnect, device number 13
11-27-38-069| [ KERNEL] [ 17.095961] usblp0: removed
11-27-38-069| [ KERNEL] [ 17.327910] usb 1-1.4: new high-speed USB device number 14 using dwc_otg
11-27-38-069| [ KERNEL] [ 17.428848] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=3817
11-27-38-069| [ KERNEL] [ 17.428864] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
11-27-38-069| [ KERNEL] [ 17.428875] usb 1-1.4: Product: HP LaserJet P2015 Series
11-27-38-069| [ KERNEL] [ 17.428885] usb 1-1.4: Manufacturer: Hewlett-Packard
11-27-38-069| [ KERNEL] [ 17.428895] usb 1-1.4: SerialNumber: 00CNBW7BJ6LL
11-27-38-069| [ KERNEL] [ 17.430519] usblp 1-1.4:1.0: usblp0: USB Bidirectional printer dev 14 if 0 alt 0 proto 2 vid 0x03F0 pid 0x3817
11-27-38-069| [ KERNEL] [ 18.375777] usb 1-1.4: USB disconnect, device number 14
11-27-38-069| [ KERNEL] [ 18.376126] usblp0: removed
USB device connects and disconnects in a second. From the very beginning, when usblp driver is not loaded:
Is your raspberry powered well?
Try to disconnect everything but P2015 from USB and reboot. Will it disconnect device again?
From raspberry site: https://www.raspberrypi.org/forums/view ... 28&t=53832
Device disconnects or continually reconnects
This again is usually caused by problems with power, so double-check your supply. If it's not power, then it can also be a symptom of getting too many errors from the device which causes Linux to reset the device. Try moving the device to a different hub port as described above.
hbbst
Post by hbbst »
Hmm..
Only a laser mouse, a keyboard and the printer is connecting to the board...
All of them are necesarry to use the terminal. I use a 2,1A power supply.
I try an other printer. If it works, I will try a USB hub.
<< EDIT >>>
Yes, the problem was the power. My colleague brought a powered usb hub and it's works perfectly. Both rdp_printer=xxx and printer=xxx method work!
Thanks for your help! :)
