Issue with serial usb
markus
Post by markus »
i want to connect a usb - barcodescanner via serial = COM....
During startup the Hardware found the scanner, but during rdp connect returns with not found.
WTware v.5.4.20
WTware v.5.4.20/Pi2 supervisor.
HTTPd listener is active.
[ KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
[ KERNEL] [ 0.000000] Linux version 4.1.19 (aka@c12) (gcc version 5.2.1 20151010 (Ubuntu 5.2.1-22ubuntu1) ) #3 SMP PREEMPT Sun Mar 13 03:04:56 SAMT 2016
[ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ KERNEL] [ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80808a80, node_mem_map ba092000
[ KERNEL] [ 0.000000] Normal zone: 1888 pages used for memmap
[ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] enter (93c0->f3003010)
[ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ KERNEL] [ 0.000000] PERCPU: Embedded 10 pages/cpu @ba05c000 s10688 r8192 d22080 u40960
[ KERNEL] [ 0.000000] pcpu-alloc: s10688 r8192 d22080 u40960 alloc=10*4096
[ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
[ KERNEL] [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2709.boardrev=0xa01041 bcm2709.serial=0xa780526c smsc95xx.macaddr=B8:27:EB:80:52:6C bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 console=ttyAMA0,115200 console=tty1 quiet wtboot=mmc
[ KERNEL] [ 0.000000] Memory: 941276K/966656K available (3439K kernel code, 261K rwdata, 1104K rodata, 3392K init, 347K bss, 17188K reserved, 8192K cma-reserved)
[ KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ KERNEL] [ 0.000000] .text : 0x80008000 - 0x80477fc4 (4544 kB)
[ KERNEL] [ 0.000000] .init : 0x80478000 - 0x807c8000 (3392 kB)
[ KERNEL] [ 0.000000] .data : 0x807c8000 - 0x808096c0 ( 262 kB)
[ KERNEL] [ 0.000000] .bss : 0x8080c000 - 0x80862c28 ( 348 kB)
[ KERNEL] [ 0.000000] Preemptible hierarchical RCU implementation.
[ KERNEL] [ 0.000000] NR_IRQS:608
[ KERNEL] [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ KERNEL] [ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ KERNEL] [ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ KERNEL] [ 0.000031] Switching to timer-based delay loop, resolution 52ns
[ KERNEL] [ 0.000230] Console: colour dummy device 80x30
[ KERNEL] [ 0.000423] console [tty1] enabled
[ KERNEL] [ 0.000449] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ KERNEL] [ 0.000471] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000612] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000631] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.001651] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.002194] CPU0: update cpu_capacity 1024
[ KERNEL] [ 0.002214] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ KERNEL] [ 0.002228] [bcm2709_smp_prepare_cpus] enter
[ KERNEL] [ 0.002325] Setting up static identity map for 0x8240 - 0x8274
[ KERNEL] [ 0.060270] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ KERNEL] [ 0.060627] [bcm2709_secondary_init] enter cpu:1
[ KERNEL] [ 0.060678] CPU1: update cpu_capacity 1024
[ KERNEL] [ 0.060686] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ KERNEL] [ 0.080222] [bcm2709_boot_secondary] cpu:2 started (0) 16
[ KERNEL] [ 0.080510] [bcm2709_secondary_init] enter cpu:2
[ KERNEL] [ 0.080539] CPU2: update cpu_capacity 1024
[ KERNEL] [ 0.080547] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ KERNEL] [ 0.100268] [bcm2709_boot_secondary] cpu:3 started (0) 16
[ KERNEL] [ 0.100522] [bcm2709_secondary_init] enter cpu:3
[ KERNEL] [ 0.100548] CPU3: update cpu_capacity 1024
[ KERNEL] [ 0.100556] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ KERNEL] [ 0.100628] Brought up 4 CPUs
[ KERNEL] [ 0.100656] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ KERNEL] [ 0.100666] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.100674] CPU: Virtualization extensions available.
[ KERNEL] [ 0.101299] devtmpfs: initialized
[ KERNEL] [ 0.124062] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ KERNEL] [ 0.124647] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.125135] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.125695] NET: Registered protocol family 16
[ KERNEL] [ 0.131150] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.132146] bcm2709.uart_clock = 3000000
[ KERNEL] [ 0.139577] Serial: AMBA PL011 UART driver
[ KERNEL] [ 0.139768] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ KERNEL] [ 0.140179] console [ttyAMA0] enabled
[ KERNEL] [ 0.140852] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.221817] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ KERNEL] [ 0.221865] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ KERNEL] [ 0.223041] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ KERNEL] [ 0.223062] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ KERNEL] [ 0.223756] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.223933] usbcore: registered new interface driver hub
[ KERNEL] [ 0.224123] usbcore: registered new device driver usb
[ KERNEL] [ 0.225157] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-09 18:11
[ KERNEL] [ 0.253361] Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.270884] NET: Registered protocol family 2
[ KERNEL] [ 0.271822] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.271963] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.272155] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.272268] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.272332] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.272616] NET: Registered protocol family 1
[ KERNEL] [ 2.426487] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 2.426685] audit: initializing netlink subsys (disabled)
[ KERNEL] [ 2.426803] audit: type=2000 audit(2.419:1): initialized
[ KERNEL] [ 2.485329] alg: No test for stdrng (krng)
[ KERNEL] [ 2.486412] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ KERNEL] [ 2.486449] io scheduler noop registered
[ KERNEL] [ 2.486515] io scheduler cfq registered (default)
[ KERNEL] [ 2.492702] BCM2708FB: allocated DMA memory fac00000
[ KERNEL] [ 2.492767] BCM2708FB: allocated DMA channel 0 @ f3007000
[ KERNEL] [ 2.515925] Console: switching to colour frame buffer device 160x64
[ KERNEL] [ 2.530817] bcm2708_rng_init=bb906000
[ KERNEL] [ 3.438576] bcm2835-rng 3f104000.rng: hwrng registered
[ KERNEL] [ 3.438767] vc-cma: Videocore CMA driver
[ KERNEL] [ 3.438781] vc-cma: vc_cma_base = 0x00000000
[ KERNEL] [ 3.438793] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ KERNEL] [ 3.438803] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ KERNEL] [ 3.439133] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ KERNEL] [ 3.440965] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ KERNEL] [ 3.446955] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 3.647356] Core Release: 2.80a
[ KERNEL] [ 3.647385] Setting default values for core params
[ KERNEL] [ 3.647425] Finished setting default values for core params
[ KERNEL] [ 3.847865] Using Buffer DMA mode
[ KERNEL] [ 3.847888] Periodic Transfer Interrupt Enhancement - disabled
[ KERNEL] [ 3.847899] Multiprocessor Interrupt Enhancement - disabled
[ KERNEL] [ 3.847911] OTG VER PARAM: 0, OTG VER FLAG: 0
[ KERNEL] [ 3.847929] Dedicated Tx FIFOs mode
[ KERNEL] [ 3.848444] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ KERNEL] [ 3.848482] FIQ FSM acceleration enabled for :
[ KERNEL] [ 3.848482] Non-periodic Split Transactions
[ KERNEL] [ 3.848482] Periodic Split Transactions
[ KERNEL] [ 3.848482] High-Speed Isochronous Endpoints
[ KERNEL] [ 3.848507] dwc_otg: Microframe scheduler enabled
[ KERNEL] [ 3.848563] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80216e84
[ KERNEL] [ 3.848580] WARN::hcd_init_fiq:413: FIQ ASM at 0x802171e8 length 36
[ KERNEL] [ 3.848597] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb90a000
[ KERNEL] [ 3.848643] dwc_otg 3f980000.usb: DWC OTG Controller
[ KERNEL] [ 3.848694] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ KERNEL] [ 3.848741] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ KERNEL] [ 3.848793] Init: Port Power? op_state=1
[ KERNEL] [ 3.848803] Init: Power Port (0)
[ KERNEL] [ 3.849059] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ KERNEL] [ 3.849077] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 3.849092] usb usb1: Product: DWC OTG Controller
[ KERNEL] [ 3.849107] usb usb1: Manufacturer: Linux 4.1.19 dwc_otg_hcd
[ KERNEL] [ 3.849122] usb usb1: SerialNumber: 3f980000.usb
[ KERNEL] [ 3.850021] hub 1-0:1.0: USB hub found
[ KERNEL] [ 3.850091] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 3.850732] dwc_otg: FIQ enabled
[ KERNEL] [ 3.850750] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 3.850760] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 3.850810] Module dwc_common_port init
[ KERNEL] [ 3.857618] bcm2835-cpufreq: min=600000 max=900000
[ KERNEL] [ 3.860842] sdhost: log_buf @ bac13000 (fac13000)
[ KERNEL] [ 3.933408] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ KERNEL] [ 3.933787] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 3.934387] usbcore: registered new interface driver usbhid
[ KERNEL] [ 3.934396] usbhid: USB HID core driver
[ KERNEL] [ 3.934708] NET: Registered protocol family 17
[ KERNEL] [ 3.934919] Registering SWP/SWPB emulation handler
[ KERNEL] [ 3.956014] registered taskstats version 1
[ KERNEL] [ 3.956123] vc-sm: Videocore shared memory driver
[ KERNEL] [ 3.956139] [vc_sm_connected_init]: start
[ KERNEL] [ 3.967288] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 3.972867] Freeing unused kernel memory: 3392K (80478000 - 807c8000)
[ KERNEL] [ 4.043031] mmc0: host does not support reading read-only switch, assuming write-enable
[ KERNEL] [ 4.046467] mmc0: new high speed SDXC card at address aaaa
[ KERNEL] [ 4.047237] mmcblk0: mmc0:aaaa SL64G 59.5 GiB
[ KERNEL] [ 4.048740] mmcblk0: p1 p2
[ hotplug] [ 4.049301] Block device 179:0. No action.
[ hotplug] [ 4.049507] Block device 179:2. No action.
[ hotplug] [ 4.049769] Block device 179:1. No action.
[ KERNEL] [ 4.053572] Indeed it is in host mode hprt0 = 00021501
[ KERNEL] [ 4.233438] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ KERNEL] [ 4.233584] Indeed it is in host mode hprt0 = 00001101
[ pfac] [ 4.294517] Run /sbin/initrd.
[ pfac] [ 4.294671] Ok, PID 512.
[ initrd] [ 4.298370] WTware shell v.5.4.20/Pi2
[ initrd] [ 4.316238] Local media boot.
[ initrd] [ 4.316447] USB boot.
[ KERNEL] [ 4.433622] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ KERNEL] [ 4.433647] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 4.434386] hub 1-1:1.0: USB hub found
[ KERNEL] [ 4.434521] hub 1-1:1.0: 5 ports detected
[ KERNEL] [ 4.713408] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ KERNEL] [ 4.813697] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ KERNEL] [ 4.813719] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 4.893422] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ KERNEL] [ 4.995814] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0610
[ KERNEL] [ 4.995837] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 4.995852] usb 1-1.2: Product: USB2.0 Hub
[ KERNEL] [ 4.995867] usb 1-1.2: Manufacturer: GenesysLogic
[ KERNEL] [ 4.997268] hub 1-1.2:1.0: USB hub found
[ KERNEL] [ 4.997696] hub 1-1.2:1.0: 4 ports detected
[ KERNEL] [ 5.093426] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[ KERNEL] [ 5.198490] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c018
[ KERNEL] [ 5.198511] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 5.198526] usb 1-1.3: Product: USB Optical Mouse
[ KERNEL] [ 5.198541] usb 1-1.3: Manufacturer: Logitech
[ KERNEL] [ 5.205628] input: Logitech USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C018.0001/input/input0
[ KERNEL] [ 5.206441] hid-generic 0003:046D:C018.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3f980000.usb-1.3/input0
[ KERNEL] [ 5.273414] usb 1-1.2.2: new low-speed USB device number 6 using dwc_otg
[ KERNEL] [ 5.393768] usb 1-1.2.2: New USB device found, idVendor=04f2, idProduct=0110
[ KERNEL] [ 5.393791] usb 1-1.2.2: New USB device strings: Mfr=4, Product=20, SerialNumber=0
[ KERNEL] [ 5.393806] usb 1-1.2.2: Product: USB Keyboard
[ KERNEL] [ 5.393821] usb 1-1.2.2: Manufacturer: Chicony
[ KERNEL] [ 5.406593] input: Chicony USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/0003:04F2:0110.0002/input/input1
[ KERNEL] [ 5.453426] usb 1-1.5: new full-speed USB device number 7 using dwc_otg
[ KERNEL] [ 5.464359] hid-generic 0003:04F2:0110.0002: input,hidraw1: USB HID v1.10 Keyboard [Chicony USB Keyboard] on usb-3f980000.usb-1.2.2/input0
[ KERNEL] [ 5.566297] usb 1-1.5: New USB device found, idVendor=05e0, idProduct=1701
[ KERNEL] [ 5.566322] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 5.566338] usb 1-1.5: Product: Symbol Bar Code Scanner
[ KERNEL] [ 5.566355] usb 1-1.5: Manufacturer: ᄅSymbol Technologies, Inc, 2002
[ KERNEL] [ 5.566370] usb 1-1.5: SerialNumber: S/N:Symbol Scanner**************
[ initrd] [ 5.726619] Load UTF8 charset.
[ initrd] [ 5.726845] modprobe nls_cp437.
[ initrd] [ 5.738083] modprobe nls_utf8.
[ initrd] [ 5.749747] Load VFAT filesystem driver.
[ initrd] [ 5.750077] modprobe fat.
[ initrd] [ 5.763251] modprobe vfat.
[ initrd] [ 5.792061] WTpassword empty.
| clientIP = *
| config = local
[ initrd] [ 8.713744] Load ethernet drivers.
[ initrd] [ 8.713881] modprobe smsc95xx.
[ KERNEL] [ 8.725469] smsc95xx v1.0.4
[ KERNEL] [ 8.786570] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:80:52:6c
[ KERNEL] [ 8.786875] usbcore: registered new interface driver smsc95xx
[ KERNEL] [ 8.845106] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ KERNEL] [ 10.384341] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ KERNEL] [ 13.711265] random: nonblocking pool is initialized
[ initrd] [ 13.880151] dhcp: 326 bytes from 192.168.1.4.
[ initrd] [ 13.880311] 00000000:000001320000000000110000c0a80104c0a80174004300440132000002010600 ...2..............t.C.D.2......
[ initrd] [ 13.880437] 00000020:67458b6b0000000000000000c0a80174c0a8010400000000b827eb80526c0000 gE.k...........t.........'..Rl..
[ initrd] [ 13.880559] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.880680] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 15.380138] dhcp: 326 bytes from 192.168.1.4.
[ initrd] [ 15.380289] 00000000:000001320000000000110000c0a80104c0a80174004300440132000002010600 ...2..............t.C.D.2......
[ initrd] [ 15.380416] 00000020:67458b6b0000000000000000c0a80174c0a8010400000000b827eb80526c0000 gE.k...........t.........'..Rl..
[ initrd] [ 15.380537] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 15.380656] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 15.410089] dhcp: server address 192.168.1.4.
[ initrd] [ 15.410204] dhcp: 192.168.1.116/255.255.255.0.
[ initrd] [ 15.410313] dhcp: default gateway 192.168.1.1.
[ initrd] [ 15.410431] dhcp: DNS 192.168.1.60.
[ initrd] [ 15.410537] dhcp: DNS 192.168.1.61.
[ initrd] [ 15.410641] dhcp: domain FFMistelbach.local.
[ initrd] [ 15.410748] dhcp: TFTP from siaddr 192.168.1.4.
[ initrd] [ 15.410853] dhcp: TFTP 192.168.1.4.
[ initrd] [ 15.410956] No boot file from DHCP.
[ initrd] [ 15.411061] TFTP binary "", configs prefix "", using "/" slash.
[ initrd] [ 15.412360] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[ initrd] [ 15.413253] Common local disk config:
| bpp=32
| display=1024x768
| server=192.168.1.66
| serial=COM4(usb 05e0:1701)
| sound=on
| sound_level=50
| sound_rate=44100
| timezone=W. Europe Standard Time
| domain=FFMistelbach
| ask_password=on
| keyboard=de
| graphic=abcdefg
| microphone_level=0
| clipboard=on
| clienthostname=ffatem1
| turnoffmenu=always
| autoshutdown=30
| vnc=on
| vnc_password=FFmb123
| doubleclick=200
| chrome_language=en
| chrome_url=http://www.ff-mistelbach.at
| bpp=32
| display=1024x768
| server=192.168.1.66
| sound=on
| sound_level=50
| sound_rate=44100
| domain=FFMistelbach
| ask_password=on
| keyboard=de
| graphic=abcdefg
| microphone_level=0
| clipboard=on
| turnoffmenu=always
| autoshutdown=30
| vnc=on
| doubleclick=200
| chrome_language=en
[ initrd] [ 15.428554] Hostname: "ffatem1".
Everyone can control terminal by HTTP.
[ gm] [ 15.645271] WTware session manager v.5.4.20/Pi2.
[ gm] [ 15.647080] Add keyboard event1: Chicony USB Keyboard.
[ gm] [ 15.700147] EV_REL flag found. Add mouse event0: Logitech USB Optical Mouse.
[ gm] [ 15.700344] Display mode: 1280x1024, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 15.709675] Framebuffer device found.
[ gm] [ 15.709767] LINELENBYTES 2560
[ gm] [ 15.709850] VLEN 2621440
[ gm] [ 15.733452] Run serial daemon for ttyUSB0.
[ gm] [ 15.733599] Run '/sbin/rdpdr[serial] 0', log '', env '', pid ''.
[ pfac] [ 15.734219] Run /sbin/rdpdr[serial] 0.
[ pfac] [ 15.734409] Ok, PID 563.
[rdpdr-serial 0] [ 15.737634] RDP Serial Port Redirector, WTware v.5.4.20/Pi2, device ttyUSB0.
[ gm] [ 15.740271] Unpack /bootmedia/packages/pi2-alsa.
[ gm] [ 15.814716] modprobe snd-bcm2835.
[ gm] [ 15.836790] modprobe snd-usb-audio.
| 0: [ 0] : control
| 16: [ 0- 0]: digital audio playback
| 17: [ 0- 1]: digital audio playback
| 33: : timer
[ KERNEL] [ 15.860642] usbcore: registered new interface driver snd-usb-audio
[ pfac] [ 15.866692] Run /sbin/rdpsnd sndvol 50 0 50.
[ gm] [ 15.866820] /dev/snd/pcmC0D1p character device.
[ pfac] [ 15.866989] Ok, PID 590.
[ gm] [ 15.867075] /dev/snd/pcmC0D0p character device.
[ pfac] [ 15.867285] Run /sbin/rdpsnd 1 44100 100 0 -1.
[ gm] [ 15.867354] /dev/snd/controlC0 character device.
[ pfac] [ 15.867522] Ok, PID 591.
[ gm] [ 15.867593] /dev/snd/timer character device.
[ gm] [ 15.867729] Preconfigure ALSA.
[ rdpsnd] [ 15.867807] RDP Sound Redirector, WTware v.5.4.20/Pi2.
[ gm] [ 15.867928] Run '/sbin/rdpsnd sndvol 50 0 50', log '', env '', pid ''.
[ gm] [ 15.868024] Run sound daemon.
[ gm] [ 15.868115] Run '/sbin/rdpsnd 1 44100 100 0 -1', log '', env '', pid ''.
[ gm] [ 15.868199] Load usb <-> serial bridges drivers.
[ gm] [ 15.868280] modprobe usbserial.
[ sndvol] [ 15.872561] Card 'ALSA'/'bcm2835 ALSA'.
[ sndvol] [ 15.872822] Mixer name: 'Broadcom Mixer'.
[ sndvol] [ 15.873002] Components: ''.
[ sndvol] [ 15.873203] Controls: 6.
[ sndvol] [ 15.873490] ALSA: control 'PCM Playback Volume'.
[ sndvol] [ 15.873781] ALSA: control 'PCM Playback Switch'.
[ sndvol] [ 15.873996] ALSA: control 'PCM Playback Route'.
[ sndvol] [ 15.874189] ALSA: control 'IEC958 Playback Default'.
[ rdpsnd] [ 15.874286] Card 'ALSA'/'bcm2835 ALSA'.
[ sndvol] [ 15.874406] ALSA: control 'IEC958 Playback Con Mask'.
[ sndvol] [ 15.874517] ALSA: control 'IEC958 Playback PCM Stream'.
[ sndvol] [ 15.874634] Inactive control IEC958 Playback PCM Stream'.
[ rdpsnd] [ 15.874820] Mixer name: 'Broadcom Mixer'.
[ rdpsnd] [ 15.874972] Components: ''.
[ rdpsnd] [ 15.875148] Controls: 6.
[ rdpsnd] [ 15.875258] ALSA: control 'PCM Playback Volume'.
[ rdpsnd] [ 15.875354] ALSA: control 'PCM Playback Switch'.
[ rdpsnd] [ 15.875440] ALSA: control 'PCM Playback Route'.
[ rdpsnd] [ 15.875533] ALSA: control 'IEC958 Playback Default'.
[ rdpsnd] [ 15.875622] ALSA: control 'IEC958 Playback Con Mask'.
[ rdpsnd] [ 15.875703] ALSA: control 'IEC958 Playback PCM Stream'.
[ rdpsnd] [ 15.875791] Inactive control IEC958 Playback PCM Stream'.
[ pfac] [ 15.876916] Process pid 590 terminated, status 00000000.
[ KERNEL] [ 15.879455] usbcore: registered new interface driver usbserial
[ KERNEL] [ 15.879555] usbcore: registered new interface driver usbserial_generic
[ KERNEL] [ 15.879630] usbserial: USB Serial support registered for generic
[ gm] [ 15.877273] modprobe pl2303.
[ gm] [ 15.889090] modprobe ftdi_sio.
[ KERNEL] [ 15.891242] usbcore: registered new interface driver pl2303
[ KERNEL] [ 15.891414] usbserial: USB Serial support registered for pl2303
[ gm] [ 15.902872] modprobe cp210x.
[ KERNEL] [ 15.904260] usbcore: registered new interface driver ftdi_sio
[ KERNEL] [ 15.904500] usbserial: USB Serial support registered for FTDI USB Serial Device
[ gm] [ 15.912428] modprobe ch341.
[ KERNEL] [ 15.914635] usbcore: registered new interface driver cp210x
[ KERNEL] [ 15.914779] usbserial: USB Serial support registered for cp210x
[ gm] [ 15.922440] modprobe metro-usb.
[ KERNEL] [ 15.924421] usbcore: registered new interface driver ch341
[ KERNEL] [ 15.924555] usbserial: USB Serial support registered for ch341-uart
[ gm] [ 15.931925] modprobe symbolserial.
[ KERNEL] [ 15.934217] usbcore: registered new interface driver metro_usb
[ KERNEL] [ 15.934348] usbserial: USB Serial support registered for Metrologic USB to Serial
[ gm] [ 15.942061] modprobe opticon.
[ KERNEL] [ 15.943880] usbcore: registered new interface driver symbolserial
[ KERNEL] [ 15.944011] usbserial: USB Serial support registered for symbol
[ KERNEL] [ 15.953254] usbcore: registered new interface driver opticon
[ KERNEL] [ 15.953426] usbserial: USB Serial support registered for opticon
[ gm] [ 15.950982] modprobe cdc-acm.
[ KERNEL] [ 15.964907] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[ KERNEL] [ 15.967123] usbcore: registered new interface driver cdc_acm
[ KERNEL] [ 15.967142] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ gm] [ 16.020867] gm-main.cpp ( 525): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 16.026604] Run '/sbin/resolver 0x1f2078 dns [192.168.1.66]', log '', env '', pid ''.
[ pfac] [ 16.027141] Run /sbin/resolver 0x1f2078 dns [192.168.1.66].
[ gm] [ 16.027252] Everyone can control terminal by VNC.
[ pfac] [ 16.027444] Ok, PID 639.
[ gm] [ 16.027573] VNC listener at port 5900.
[ gm] [ 16.032685] 192.168.1.66 => 192.168.1.66.
[ gm] [ 16.036019] /graphic/ppllg.png: 32x38.
[ pfac] [ 16.036671] Process pid 639 terminated, status 00000000.
[ gm] [ 99.873852] Free ram before fork terminal client /sbin/rdpclient (session 1): 927432 Kb.
[ pfac] [ 99.873996] Run /sbin/rdpclient 1.
[ gm] [ 99.874058] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 99.874272] Ok, PID 646.
[ rdpclient 646] [ 99.881967] RDP Terminal Client, WTware v.5.4.20/Pi2, pipe 1, pid 646.
[ gm] [ 99.882817] ERROR: usb-serial device 05e0:1701 not found.
[ gm] [ 99.882969] Do NOT redirect COM4.
[ rdpclient 646] [ 99.884434] Redirect sound.
[ rdpclient 646] [ 99.885394] Make RDP session with 192.168.1.66, port 3389.
[ rdpclient 646] [ 99.885552] Username: "ffclient4\markus".
[ rdpclient 646] [ 99.885675] Password: present.
[ rdpclient 646] [ 99.885791] No PIN.
[ rdpclient 646] [ 99.885907] Domain: "FFMistelbach".
[ rdpclient 646] [ 99.886022] No shell.
[ rdpclient 646] [ 99.886138] No directory.
[ rdpclient 646] [ 99.886272] Window: 1280x1024@16.
[ rdpclient 646] [ 99.886453] PFlags 0x00000180.
[ rdpclient 646] [ 99.886618] Keyboard 00000407:00000000.
[ rdpclient 646] [ 99.886737] My hostname "ffatem1".
[ rdpclient 646] [ 99.886858] TCP: connecting to 192.168.1.66:3389.
[ rdpclient 646] [ 99.888557] TCP: connection with 192.168.1.66:3389 established.
[ rdpclient 646] [ 99.888706] Turn keepalive on.
[ rdpclient 646] [ 99.889816] Free ram after buffers allocation: 927036 KB.
[ rdpclient 646] [ 99.894459] Process RDP server certificate.
[ rdpclient 646] [ 99.894631] RDP4 encryption.
[ rdpclient 646] [ 99.899835] Timezone '(UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna'.
[ rdpclient 646] [ 104.510572] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000001.
[ rdpclient 646] [ 104.910505] SessionId 0x00000001: ffclient4\markus.
[ rdpclient 646] [ 105.842794] Sound redirection: 44100 frames per second.
[ rdpsnd] [ 106.046667] ALSA: use device hw:0,0.
[ rdpsnd] [ 106.048107] ALSA: Hardware rate 44100Hz.
[ rdpsnd] [ 106.048291] ALSA: driver default chunk size 512 too low.
[ rdpsnd] [ 106.048382] ALSA: chunk size 4096 frames, 8192 bytes, 92 msec.
[ rdpsnd] [ 106.048462] ALSA: buffer size 65536 bytes, 743 miliseconds.
Send WTCU discover to 192.168.1.108.
Home WTware diskless client.
Please help
kr Markus
Re: Issue with serial usb
Do not specify USB ID.
serial=COM4(usb)
That scanner should be programmed into CDC mode.
