Raspberry Pi 3
jpxdude
Raspberry Pi 3
Post by jpxdude »
Hi there!
Firstly, I'd like to congratulate you on this software, which works fantastic on a Raspberry Pi 2. I am really impressed! :D
As I'm sure you're aware, the Raspberry Pi 3 was just released at the start of this week, so I was wondering firstly if your current release would work on it, and secondly, if there would be an update to take advantage of the improvements offered by the Pi 3? I am excited to see the possibilities of a great RDP solution working on these new Raspberry Pi's :)
Thanks again!
-J
jpxdude
Re: Raspberry Pi 3
Post by jpxdude »
Just to update...
The software definitely doesn't work on a Raspberry Pi 3 :(
Is it possible for me to update the software myself to work with the Raspberry Pi 3, or is there active development on a new version that will support this model, along with it's integrated WiFi module?
I look forward to a response to this soon, and wish you all the very best of luck!
Kind regards,
-J
Re: Raspberry Pi 3
We'll fix it ASAP we'll get Pi 3. I don't think it will happened this month :(
Guest
Re: Raspberry Pi 3
Post by Guest »
Hi Aka!
Thanks for the response. I appreciate that this will be looked into, and hope it gets fixed ASAP! I wish there was something I could do to help speed up a fix.
I can safely say that this is the best RDP client implementation currently available for the Raspberry Pi 2. I'm considering making a video to demonstrate the fact on YouTube soon, as it is so very good!
I look forward to an RPi 3 version soon :) thanks so much!
-J
Re: Raspberry Pi 3
Thank you. Your video is a great idea. Show it to us when you'll have it.
Pi 3 is on it's way to us :)
Re: Raspberry Pi 3
Please, put all files from that archive on SD:
http://pxe.ru/files/testing/201603072141.zip
And run RPi 3. Will it print something on the screen?
jpxdude
Re: Raspberry Pi 3
Post by jpxdude »
Hi Aka!
Apologies for the late reply! I'll try this now and let you know if a moment. Thank you so much!
-J
jpxdude
Re: Raspberry Pi 3
Post by jpxdude »
Hi Aka!
I've just run a quick test, and it boots up and works!! Hurrah! :D
At the moment, it only appears to be working through the Ethernet connection only though. If I attempt to connect via the WiFi that it built into the Raspberry Pi 3, I get the following error:
Seeing as there is now only one particular WiFi model used in all new Raspberry Pi 3's, I hope there is a fix for the WiFi soon :) Otherwise, I'm very happy and glad that it is at a stage where it is working! Well done for sorting this out, I'm very grateful! I will let you know when I am able to make a video, and if you would like me to do any more testing, please do let me know. Take care!
-J
Re: Raspberry Pi 3
Sorry, WiFi will be only after we receive our Pi 3. Pi 2 has ethernet on USB instead of PCI. OK, we can deal with it. PI 3 has WiFi on GPIO instead of USB. It's so ... nontrivial.
jpxdude
Re: Raspberry Pi 3
Post by jpxdude »
Hi Aka!
Thanks for that. I can work/test with ethernet for now :) This is working pretty much the same as it did for the Pi 2, which is great.
I look forward to the WiFi working at some point. I wish you the very best of luck! :D
-J
brunoadr
Re: Raspberry Pi 3
Post by brunoadr »
This is great! as noted previously in this topic, I'm also using WTware + Pi2 here and it works really great.
Bought myself a Pi 3, I'm waiting for it to arrive and will begin the tests with the firmware posted by Aka.
hbbst
Re: Raspberry Pi 3
Post by hbbst »
Hi Aka!
I plan to buy some Raspberry Pi in April. But I would like to buy the new, 3rd edition.
What do you think? When will you release the official os?
Re: Raspberry Pi 3
In April. Sorry, not sure about the date.
hbbst
Re: Raspberry Pi 3
Post by hbbst »
Offtopic...
And what about Banana pi? Did you test it and if yes, which version did you test?
Buying Banana is better, you get higher performance for the same money... :-)
Re: Raspberry Pi 3
No. We already played with Rockchips. No more processors without good supported Linux kernels. Now the only one good Linux kernel is in Raspberry.
