Dual Screen Compatibility
nathanTustone
Post by nathanTustone »
I was wondering if this would support dual screen setups. I currently have a test rig with a USB - DVI Display Adapter.
If so, does the dual screen support feature multi monitor or does it simply span the main display over two screens.
Re: Dual Screen Compatibility
On x86, WTware supports dual screen on motherboards with two video connectors. So we can do it for Pi2.
But we have never tried USB video.
Did you try USB-DVI adapter with Windows? I think it should be terribly slow.
