Edit configuration from http page
smurfjesse
Post by smurfjesse »
Hi Aka,
We just installed a couple of WTware stations with the new 5.2.0 version and now we can't get edit the configuration file from the http page.
If we adjust something (or just press "save") we get the error:
418 I'm a teapot
WTware v.5.2.0
Incorrect config file.
I tested this with also with version 5.1.49 and 5.1.66 with the same config file and same pc and then it works.
Could you help us out? Remote editing is preferabel for us because we have a couple of remote international sites where we use WTware.
SmurfJesse
Re: Edit configuration from http page
Sorry for such long delay :(
It's a bug. Should be fixed in the latest builds.
