client boot problem
wasti
client boot problem
Post by wasti »
when i boot from client through pxe boot rom gives message (required win2kip parameter is not defined in congfiguration file) i m using wtware lite.
tell me the solution.
thanks
It means you haven't specified terminal server ip address in configuration file. Information about configuration file parameters is available at
http://wtware.com/docs/config.html
