image of company
clemerson
image of company
Post by clemerson »
I know possible to place the logo of my
company??, example video;
VIDEO: http://www.youtube.com/watch?v=v2GufDDF ... e=youtu.be
Re: image of company
1. Download the newest WTware version 5.1.17
2. Use parameter skin http://wtware.com/docs5/config.html#skin
3. If you see no your logo send us terminal log. In graphical configurator select terminal from list > section "Logs" > "Start log" > "Save log".
PedroMC
Post by PedroMC »
im interested in this too, when selecting parameter Skin it has a combo with Sample what is this?
I have put the files in skin (renamed the Menu.png), tried to create a folder (Sample, inside folder skin), and i have tried putting the PNG's inside the skin folder only.
Non of them seem to work.
Can send the log if needed?..
Thank you
PedroMC
Post by PedroMC »
Ok found it :) C:\Program Files (x86)\WTware\TFTPDROOT\Graphic\sample
