importing license via network
smurfjesse
Post by smurfjesse »
Hello aka,
we have some computers with wtware in foreign countries wich is not easy to acces physically.
how can we install a license that has wtware installed on the hardisk without going to the computer physically.
with the usb stick i would just let them put them in a windows computer and copy the wtware.lic via the network to the usb stick and let them put it back in there computer and reboot. but with it installed on the harddrive its not so easy.
how do you do this?
regards,
jesse
Re: importing license via network
wtware 5.1.10 allows you to modify config file via http. Copy five license lines to config file. If you do something wrong, terminal may not boot. I think it is not good idea to edit something on device wich is not easy to access physically. Install tftp server somewhere near terminal and put configs here.
